Gregster1234 Posted May 19, 2022 Report Share Posted May 19, 2022 What is necessary to remove and replace the pump. It looks like the battery then maybe the tank? Link to comment Share on other sites More sharing options...
Caliber308 Posted May 19, 2022 Report Share Posted May 19, 2022 1. Remove the battery and battery tray. 2. Remove the washer tank mounting bolt. 3. Remove the washer tank. Everything on these cars should be this easy. ☺️ Link to comment Share on other sites More sharing options...
Gregster1234 Posted May 19, 2022 Author Report Share Posted May 19, 2022 Thanks sounds easy, I just went through the entire wiper motor and wiper transmission. It works perfectly now! Link to comment Share on other sites More sharing options...
kev Posted May 19, 2022 Report Share Posted May 19, 2022 Well, there is one thing to look out for. The typical problem with our tanks is the rubber seal on the pump degrades with time or the pump gets jarred in it causing a leak. On the tank, there is an L bracket that bolts to the core support. You can remove the nut securing the tank to the L bracket, but I have found it difficult to pull the tank out (and reinstall it) without contacting the pump and potentially damaging that seal. I'd advise you to remove the L bracket and pull it out still bolted on the tank. Unfortunately, you have to come from the front of the core support to remove the bolt for the L bracket, but it isn't too hard to get to. Some photos to show what I mean: With this next one, you can see how the pump would contact the bracket when you remove the tank from the car. Link to comment Share on other sites More sharing options...
tux Posted May 20, 2022 Report Share Posted May 20, 2022 It's actually a pain in the tail to do Link to comment Share on other sites More sharing options...
Caliber308 Posted May 20, 2022 Report Share Posted May 20, 2022 Maybe for some, but easy for others😏 Link to comment Share on other sites More sharing options...
Gregster1234 Posted May 26, 2022 Author Report Share Posted May 26, 2022 Ok now I have a new problem, the low fluid sensor gasket is bad and the reservoir now leaks. Does anyone know of a replacement gasket? I know you cannot use sealer on this kind of plastic. Here's a pic of what it looks like. I have found some for an Audi. Link to comment Share on other sites More sharing options...
kev Posted May 31, 2022 Report Share Posted May 31, 2022 JB weld water weld, that is how I fixed the last one I did. It's been holding for a year now. For the pump seal, I was able to use vacuum grease around the seal but vacuum grease wouldn't do the trick with the float penetration. Link to comment Share on other sites More sharing options...
Gregster1234 Posted May 31, 2022 Author Report Share Posted May 31, 2022 Awesome thanks I'll try that, I tried silicone but no go. Link to comment Share on other sites More sharing options...
