Holset HX 40 set-up
well since holset are hot right now on SQ's. I will show my set-up as well.
I'm using a moded stock manifold from TEP. T3 w/out ex-waste gate
HOLSET HX-40w. 18cm exhaust side. 4" in 4" out
DODGE 4" downpipe for hx 40
the turbo sits in the stock location. very little is needed to put one on a SQ. Next i'll be working on the intercooler piping
THIS ALL TEST FITMENTS ONLY
http://i713.photobucket.com/albums/ww135/starquestJOE/P4130092.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/P4130093.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/P3150086.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/P3150087.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/P3150088.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/P3150091.jpg
That is huge! A friend of mine has a 2g talon, 6 blot, 2.3 stroker, set up for track and uses the same HX-40 turbo. He runs well over 1000cc injectors and hits boost over 35psi...That Holset is no joke....
What do you plan to run for fuel?
well i was thinking about tryin it with the TB and 2 1000cc inj. but i have JE block, P/P clearwater head adj rocker set up, adj cam gear, paxtom kamikaze fuel, pump, EIP cannon intake with 1000+ cc injectors, Electromotive Tec 2, fidanza flywheel, and more
i'm hoping 450hp at around 26-28 psi
The stock exhaust manifold is not going to be able to flow enough air to spool that HUGE 18cm2 turbo. You will need a header at minimum for that turbo IMO.
From what I have been reading about holsets, your best bet is to buy the bullseye performance turbine housing that they offer for DSM's and then just adapt the exhaust. Here is where I read up on it;
http://www.dsmtuners.com/forums/turbo-syst...set-turbos.html
  • 1 month later...
Best thing to do is get the specs on the turbine and talk to someone at bullseye and they should help you out. I was actually able to get factory specs from the maker of the turbo and just email them to bullseye and they hooked me up with the right housing that I need/looking for.
i'm tryin to find the right housing for it but i havent had any luck
What housing are you looking for? If you are looking for holset housings for it, the smallest direct fit housing for the hx40 that i know of is gunna be a 16cm. Another alternative would be to have a 12cm hx35 housing machined out for the hx40 turbine. If you want a BEP housing there are only 2 sizes, .55ar and .70ar. The .55 is mitsu flanged inlet and the .70 is t3 flanged inlet. They use to offer a .55ar t3 inlet, IIRC.
well as soon as i find some funds. Iwill be putting the holset on. the 12a just doesnt cut it anymore. i have alot of mods. but the 12a doesnt let me use them. i will run tbi first. i will be goin the same route as blue did with his. but a little different~~!!~~
stock manifold is gonna flow whatever our heads let through.
i have two heads. The one on the car is a tep stage 3. It came on the long block. And i have a P/P clearwater head with a mech setup. And both have cams.
I also have the option to run A t3 or Stock mits housing on the turbo. I think i will be goin with the .70ar t3 BEP
  • 7 months later...
ok guys back from the dead!
my BEP housing will be here tomorrow afternooon! I went with the .70ar t3 in, 3"v-band out. Also just got a AJUSA headgasket as well.
So the set-up will be as follow:
HX-40 in a 70ar BEP housing
Modded stock manifold T3 flanged
Tial 38mm ext wastse gate
P/P clearwater haed with 1mm ov, hd spring, 274cam, mech setup, adj cam gear
MAF-T and GM 3"mas
I'll start posting pics as i start working on the car. I have alot of parts i bought from last year that never made it on the car as well
http://i713.photobucket.com/albums/ww135/starquestJOE/Pic0287.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/Pic0289.jpg
http://i713.photobucket.com/albums/ww135/starquestJOE/Pic0290.jpg
and next to a 20g housing
http://i713.photobucket.com/albums/ww135/starquestJOE/Pic0288.jpg
