Idler Bushing Replacement
4 replies to this topic
#1 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,072 posts
Posted 02 December 2015 - 04:16 PM
My '85 Auto started making a clunk at certain times when the RF wheel would go over a small driveway curb, etc... So when I looked for the cause, I realized there were no bushings at all at the idler arm! They must have cracked (hard poly or nylon), and then they spit out entirely! With the wheel off the ground, I could cause the arm to slide up and down the frame mounted post with very little effort.
So I ordered a idler arm repair kit from NAPA, even though I think I have one laying around somewhere. LoL!
It took me longer to put the front of car up on jackstands and pull the RF wheel, than it did to install the bushings! One nut to remove. Very easy, and cut and dry as far as what to do. I simply leaned up the post and the inside of the idler. Inspected it and saw no damage whatsoever. I inserted the new bushings and put marine grease on the inside diameter of them. the 'kit' came with the new bushings (one for top and one for bottom), a washer and a new locknut. The washer had flat spots on it that the OEM post didn't have, so I just used the OEM washer since it was still good.
It now steers better than ever. Much more response with less effort, and no clunk noise when I go over bumps. Big difference for about $30. I could have got away with just the bushings for $8 plus shipping.
There is absolutely no play in that joint with new bushings. So if you see any play at all, I would replace them.
'84 Dodge Conquest Parts car
#2 importwarrior
  • 18,111 posts
Posted 02 December 2015 - 08:30 PM
I got the idler arm bushings from rock auto.
#3 TexasQuest
  • 8,686 posts
Posted 02 December 2015 - 08:39 PM
Whiteline makes poyurethane idler arm bushings FYI.
88 Fiji Blue -Tsi
#4 Tim_C.
Tim_C.
  • 10,072 posts
Posted 26 December 2015 - 08:10 PM
Yes, the Rockauto ones are cheaper and would do the job just fine.
Thanks for the info about Whiteline. My '87 with all poly bushings, is now making the same noise. I'll have to check the idler arm bushings before I drive it again. I bet poly is a lot better for these bushings. Especially for people like us who drive it hard into corners, etc.. From the noise it makes with bad or no bushings, I can tell they take a beating from potholes, and bumps in the road.
#5 psu_Crash
psu_Crash
  • 7,036 posts
Posted 10 April 2016 - 10:20 AM
Anyone thought of putting a grease fitting on the idler arm? Have mine out right now and I plan to put a grease fitting in.
My Feedback Link
