Conquest TSI/Starion rear hatch struts must be 1989
11 replies to this topic
#1 Diamondjoe
Diamondjoe
  • 145 posts
Posted 19 April 2017 - 08:57 PM
Conquest TSI/Starion rear hatch struts must be 1989 needed must be in good working order
JOE
#2 EricSQ
EricSQ
  • 123 posts
  • Interests:'86 Starion - LS Swap
    '87 Starion - SOLD!!
    '02 Silverado Z71
Posted 20 April 2017 - 09:26 AM
Good luck in your search.  Can you explain the difference in struts between a 1989 and any other year?  I was not aware they were different.
Thanks,
#3 Diamondjoe
Diamondjoe
  • 145 posts
Posted 20 April 2017 - 10:06 AM
the plugs are diff on 89 all others are the same
#4 EricSQ
EricSQ
  • 123 posts
    '02 Silverado Z71
Posted 20 April 2017 - 10:18 AM
I did not know that.  Thanks for the info. :)
#5 kev
kev
    Moderator
  • 4,639 posts
Posted 20 April 2017 - 11:23 AM
I thought 88 and 89 both had the different plug (on the input end, lower side)?   I cannot remember if it was larger or smaller.   I popped out the leads on mine and swapped the plug.
#6 vbrad511
vbrad511
  • 8,151 posts
Posted 20 April 2017 - 01:38 PM
There's a place, I believe in Canada, that'll rebuild your old ones. Do a search on it here on SQC. Seems it was a couple hundred bucks.
#7 Diamondjoe
Diamondjoe
  • 145 posts
Posted 20 April 2017 - 02:37 PM
a few hundred dam dont want to pay that much ill find some for sure
#8 88351wtsi
88351wtsi
  • 818 posts
  • Interests:My kids, music, and cars, not always in that order.
Posted 20 April 2017 - 02:39 PM
https://youtu.be/ANrEJjeHyho
1988 Conquests
His:  Durban maroon with 351w
#9 StarquestRescue
StarquestRescue
  • 4,503 posts
Posted 20 April 2017 - 07:21 PM
I have some from older cars. You can probably change out the plugs.
#10 mstieg
mstieg
  • 6,045 posts
Posted 21 April 2017 - 01:51 AM
I got mine done by Strutwise.  Fairly quick turnaround despite border crossing.  Apparently I got a "deal" for $170 or $180 IIRC because of outdated pricing that they gave me, but said afterward that they'll charge more because our are a PITA to do, given the internal contacts for 3rd brake light and rear defroster.
Crazy nice though.  It pops up on its own most times upon pulling the hatch release like the vid, but mine goes up at a nice little pace.  Far too many years of propping it up with one arm.
In Progress: breakin & tune
FOR SALE:  Rear Camber plates (basic); NIB beefy U-joints(2); etc.see-->  http://www.starquest...howtopic=133262 Custom 5 guage overlay panel: http://www.starquest...pic=136703&st=0
#11 Diamondjoe
Diamondjoe
  • 145 posts
Posted 21 April 2017 - 05:18 AM
thanks
#12 Preludedude
Preludedude
  • 1,742 posts
Posted 21 April 2017 - 08:49 AM
http://www.ebay.com/...qFY9jNg&vxp=mtr
