Eci checker results
1 reply to this topic
#1 Spooled_Starion
Spooled_Starion
  • 396 posts
Posted 07 October 2018 - 09:28 PM
Hey guys ran an ECi checker today on my car and it came up with a couple issues when it was testing the injectors it had 12v on injector 1 and injector 2 as it should but when I revved it up as instructed it dropped to 7-8v on both injectors. The fsm says it should have a slight drop in voltage when you rev it but is 4-5v considered a slight drop? What could be causing a 4-5v drop to injectors when I rev the motor? This is using the green connectors on the eci checker, select switch B, check switch 7 and 11.
Also, check switch 5 (atmospheric pressure sensor) same green connectors gave me 0v at key on and idle and I'm supposed to be in the 3.8 ro 4.2 volts. What is the atmospheric pressure sensor as I hadnt heard of that on an 87?
On the white plugs, select switch A, check switch 2 (ignition pulse) I should be getting 4-10v and I'm seeing a constant 12v
White plugs, select switch A, check switch 4 ( spark advance) I'm seeing 0v when I should be up to .6v
Any input on any of these issues would be appreciated. Thanks.
#2 Turbo Cary
Turbo Cary
  • 1,541 posts
Posted 12 October 2018 - 04:15 PM
I have never used an ECI checker but check all your power and grounds. How are the injector clips?
