How To Install MR2 Inserts in your Starion
51 replies to this topic
#41 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 07 February 2012 - 11:05 PM
View Postsleeper tsi, on 02 January 2012 - 12:50 PM, said:
I'm gunna run mr2 rears all the way around. Is this a good or bad idea?
LOL...
View PostKomeuppance, on 03 September 2011 - 11:16 PM, said:
Patra_was_here might be using Konis.
I'm using Tokico Illuminas, all rears.  As far as weight balance, I did "the math" vs an MR2...
MR2's (SW20 turbo) weight from 2750, to 3050, with a weight distribution of:
Front axle: 1260 lbs (43%)
Rear axle: 1660 lbs (57%)
I don't remember exactly, but the SQ weight distribution is better at 53:47 I think.  That's about 1600 front, and 1400 rear.  So we are very close to what an MR2 is pushing.
-Robert
#42 SFBMX88
SFBMX88
  • 1,522 posts
Posted 08 February 2012 - 02:15 AM
1988 ST165 Celica Alltrac:
Curb Weight: 3270 lb (with options)
Weight Distrobution F/R: 59/41
***The MR2 KYB AGX inserts front and rear are the same length.
Edited by SFBMX88, 23 October 2012 - 11:54 AM.
#43 89BananaQuest
89BananaQuest
  • 625 posts
Posted 02 November 2012 - 09:31 AM
Sorry i know this is okd.  But the link isnt working.  Does any one have a link to a how to on this?
#44 Coke
Coke
    Member Since January 2003
  • 5,581 posts
Posted 22 November 2012 - 04:14 PM
Broken link.  WHATS UP WIT DAT BERT?
#45 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 22 November 2012 - 04:32 PM
Gotta make you work for it... lol...
-Robert
#46 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 27 December 2012 - 11:00 PM
Get the link back up...I got work to do.
Gnothi Seauton 515 rwhp/527 Lbs.@21psi....nuff said.
2JZ-HX40 Na-T swap Conquest.  FAST Classic ECU, dual walbros -8an PTFE, stock NA pistons & Turbo HG, Arps, Custom FFIM for 1200cc injectors ..93 oct. daily driven.
http://i156.photobuc...ct/DSC01364.jpg
#47 spadey
spadey
  • 230 posts
Posted 30 January 2013 - 12:53 PM
still no link no work:((( i got money to spend lol
#48 farrk007
farrk007
  • 14 posts
Posted 26 April 2013 - 07:09 PM
Yeah...put this link up again!! please.
#49 dpstarion88
dpstarion88
  • 173 posts
Posted 11 September 2013 - 07:40 PM
http://home.comcast....MR2Inserts.html
BOOST......oh yeah
#50 The Rabbit1
The Rabbit1
  • 2,942 posts
Posted 13 September 2013 - 07:23 PM
ok, I R confused, I have stock fronts and MK1 rears, so they all should have gland nuts, and I have to order two front gland nuts and 2 rears? do the replacements called out in the walkthru and this thread screw right into the housings? or do I need MR2 upper sections that will accept the gland nuts?
Replaced: vac advance, Delphi injectors, all vac lines, tees and check valves, all brake hoses and pads, Master cylinder, flex plate, torque convertor, T-stat(180), CTS, TPS, both fan switches to primary, rear speakers, door speakers
Overhauled: Distributor, TB, wiper system, electrical ground connections, dash switches, auto seat belt tracks, entire auto trans, entire fuel system, A/C system
Upgraded: 1st gen Mas, HKS bov, Walbro 255lph pump, S16G Turbo and increased boost to 15psi, Aeromotive rrfpr 13105, MSD 8910 Tach adapter, Comp Cams Fireball digital ignition system, 35 watt HID headlights (6000k) 1000w 4ch amp, 100A alternator, engine to chassis to battery ground (4ga), charging wire from Alt to Batt (6ga), 2.5" Catalytic converter, Magnaflow muffler, R134 A/C, Yellow top optima battery
Added: AEM wideband, rail mounted fuel pressure gauge, dual alternator fusible links
Eliminated: Cruise, ABS, Emissions, Vac pump
#51 Laodicea
Laodicea
    Celebrity
  • 1,341 posts
  • Interests:Heaven
Posted 24 May 2016 - 10:37 AM
link no more work
#52 importwarrior
  • 17,818 posts
Posted 24 May 2016 - 08:25 PM
I believe he now has a site called mitsubishihero.
