New Turbo Manifolds, headers, multiple options available
54 replies to this topic
#21 AshyBone
AshyBone
  • 389 posts
Posted 18 March 2017 - 03:39 PM
I'm in for the T3 log. I'm going to bolt a HX35 to it. Can you PM me details?
#22 Chad
Chad
    noob
  • 9,182 posts
  • Interests:Starquest Fanatic
Posted 19 March 2017 - 09:41 AM
Perhaps PM me with questions, I don't have any details that aren't laid out in this posting.  I'll be working on another batch of T-3 logs over the next week, so I should be restocked soon.
#23 '87quest
'87quest
  • 839 posts
Posted 21 March 2017 - 11:58 PM
Great work! What's the id of the turbo mounting flange on the stock replacement?
Edited by '87quest, 22 March 2017 - 08:03 AM.
#24 Chad
Chad
    noob
  • 9,182 posts
Posted 22 March 2017 - 11:01 AM
2-1/4" or 57 mm.  The pipe transition that feeds into the flange is 2.157", or 55 mm.  pretty sure stock is 50 mm. It's a good amount bigger than stock, but not so much that you will have problems with the transition on a stock un-ported turbine housing.
On the prototype shown it was a mitsu flange for a different series of turbo, I don't use those flanges on the production model.
#25 pcristquester
pcristquester
  • 2,277 posts
Posted 22 March 2017 - 11:43 AM
The design is way better than stock, not just flow wise.  Now i can actually verify torque on the nuts with a regular deep socket and torque wrench
#26 '87quest
'87quest
  • 839 posts
Posted 22 March 2017 - 12:07 PM
That's what I was wondering chad, great work! Definitely something on my list just can't quite swing it right now.. I'll let you you in the future when I'm ready for one.
#27 G54Bstore
G54Bstore
    SQC Commander
  • 5,139 posts
Posted 22 March 2017 - 01:51 PM
Bit chin arse header man.
Chad makes the best stuff.
Great flowing and cost effective.
I run one of those same type design log headers and spool a hx35 pretty decently.
Very nice.
W18 Rocky White Starion
Daily Driver
#28 Matt888
Matt888
  • 372 posts
  • Interests:Not breaking down in the TSi
Posted 25 March 2017 - 07:30 PM
Chad, I'm looking to do this also and will PM when ready.
I have Chad's modified Magna intake in my garage and can attest to his skills!  I will definitely be getting a manifold from him.
#29 Chad
Chad
    noob
  • 9,182 posts
Posted 25 March 2017 - 07:46 PM
Matt, will you need an internal or external wastegate?  I have a few that are almost done, some with and some without external wastegates.
#30 Chad
Chad
    noob
  • 9,182 posts
Posted 28 March 2017 - 08:06 PM
I have 2 @ stock manifold replacement models in stock, $410(add $10 if using pal-pal = $420)
2 @ T-3 internal waste gate models in stock.  $340 shipped (add $10 if using pal-pal = $350)
I have 3 @ T-3 external waste gates in progress, I expect those to be done in about 2 weeks
#31 creakyjoints
creakyjoints
  • 1,923 posts
Posted 28 March 2017 - 10:50 PM
How much for one like you made for Ivan but divided t4?
#32 Chad
Chad
    noob
  • 9,182 posts
Posted 29 March 2017 - 09:35 AM
Tube or pipe?  That one is 16ga 321 stainless, the material is pretty expensive.  I made one other years ago.
I'm working on a 316 pipe version of that same design right now, I'm about 2/3 the way done.  I made a template of Ivan's manifold so I could reproduce them.  The one I'm working on is divided t4 with dual WG's to keep it truly divided. I'll share a pic when I'm done with mockup.  Target price is under $1000, depends on how long they will take to fabricate.  That model in 321 tube is about $1300.  Material alone is over $800
#33 importwarrior
  • 18,174 posts
Posted 15 April 2017 - 08:09 PM
Pm sent.
#34 Matt888
Matt888
  • 372 posts
Posted 18 April 2017 - 08:49 AM
I haven't sourced an HX35 yet, but I'm assuming I'll need an external wastegate version...
#35 Chad
Chad
    noob
  • 9,182 posts
Posted 18 June 2017 - 12:21 PM
In stock and ready to ship:
2@   Stock replacements  $410 shipped.  Add $10 if using pay-pal to cover part of the fees ($420).
4@   T-3 with external wastegate  $370 shipped.  Add $10 if using pay-pal to cover part of the fees ($390).
2@   T-3 for internal wastegate  $340 shipped.  Add $10 if using pay-pal to cover part of the fees ($350).
2@   T-3 equal length.  $520 shipped.  Add $10 if using pay-pal to cover part of the fees ($530)
I will be making some T-4 versions as well.
#36 prototype78
prototype78
  • 993 posts
Posted 01 July 2017 - 04:14 PM
So the t3 log will sit low like the treadstone manifold?...
#37 Chad
Chad
    noob
  • 9,182 posts
Posted 02 July 2017 - 03:16 PM
No, it sits about 5" higher.  The flange on the Treadstone is parallel to the downward facing head flange.  Mine is about 65* out of parallel, putting the turbo on on the top of the log, not the side of it.
Attached is a pic of a T3 log I took during prototyping, it's a decenlty largeT4 turbo just clamped to the flange for getting the geometry and clearances checked out.  If  T4 fits, any T3 will fit too.  This also shows where the wastegate ends up in relation to other parts/systems.  This ends up in a way better placement compared to the treadstone WG placement, which forces you to use adapters or a funky down pipe.
#38 Contsis
Contsis
  • 204 posts
Posted 06 July 2017 - 08:34 AM
What would be a direct replacement for a stock 87 TSi? Keeping everything exactly the same with a straight swap.
#39 Chad
Chad
    noob
  • 9,182 posts
Posted 06 July 2017 - 09:43 AM
Check out post 13 in this thread.  Doesn't have provisions for the heat shield, but I can add some studs for mounting the shield if you want to keep it.
#40 bluecollar
bluecollar
  • 41 posts
Posted 10 August 2017 - 09:34 PM
Any stock manifold replacement models available with EGT  mount.
