"Grace Silver" MPI/06SL2-20G/MegaSquirt
95 replies to this topic
#81 Preludedude
Preludedude
  • 2,589 posts
Posted 17 May 2018 - 01:34 PM
Picked up pulley yesterday...I took him a spare and he did it right...
As of today, its slowly getting back together..
Edited by Preludedude, 21 May 2018 - 01:35 PM.
#82 tsi_tom
tsi_tom
  • 2,224 posts
Posted 17 May 2018 - 01:59 PM
Itís funny because the powder coater I used did the same thing even after I told him not too.  Not sure how the surface will turn out now after it will be sand blasted twice,
Engine
20 over forged pistons
Stock injection system
#83 Preludedude
Preludedude
  • 2,589 posts
Posted 17 May 2018 - 02:10 PM
 tsi_tom, on 17 May 2018 - 01:59 PM, said:
It's funny because the powder coater I used did the same thing even after I told him not too.  Not sure how the surface will turn out now after it will be sand blasted twice,
My guy said he could take it to his machinst and have him turn it on a lathe and get it back down to metal....But I just gave him a spare and had him do it over...Not a big deal...Im glad you pointed it out before i got ready to install it....
#84 importwarrior
  • 18,020 posts
Posted 17 May 2018 - 03:25 PM
Did he do the water pump pulley also?
#85 Preludedude
Preludedude
  • 2,589 posts
Posted 17 May 2018 - 03:49 PM
Yes he did.
#86 Preludedude
Preludedude
  • 2,589 posts
Posted 21 May 2018 - 03:13 PM
Now it's time to clean up wiring in the engine bay. It's all a mess since it was all bundled together for paint....
Time to start routing everything correctly and get ready to drop this engine back in....
#87 Turbo Cary
Turbo Cary
  • 1,505 posts
Posted 25 May 2018 - 05:28 AM
Looks awesome dude! Next time I'm up your way I'd like to come by and check it out. I've also done quite a bit to my Miata since the last time I saw you.
#88 FRO
FRO
  • 573 posts
Posted 29 May 2018 - 09:36 PM
Yes Yes,, Upstate meet.
#89 Preludedude
Preludedude
  • 2,589 posts
Posted 19 June 2018 - 01:48 PM
Finally some time to work....
I purchased a new brake booster and master cylinder, so I went ahead and got those installed....
I also went ahead and started getting the engine bay put back together. I put back in the ignitor and coil and started routing all the harness...I also removed the battery tray and sprayed it black with some "VHT wrinkle plus" paint...It cleaned it up pretty good and now I need to clean the bolts for the battery tray since they are rusty....
You can also see the new Summit 10-Micron fuel filter, and Aeromotive AFPR I just installed. I just placed an order through Summit for new braided -6AN fuel line, and the correct -6AN fittings I needed...I did not know it would cost $117 to plumb the car for Fuel with this MPI swap...The $$$ keeps slowly adding up... <_<
And my cheap ebay badge I put on the firewall....just because... ^_^
#90 Funky Phil
Funky Phil
    Super Pooper
  • 6,376 posts
Posted 20 June 2018 - 11:02 AM
I never powdercoated my main pulleys for fear of further destroying thae already old rubber insulator
#91 Preludedude
Preludedude
  • 2,589 posts
Posted 18 July 2018 - 10:51 AM
With this XTD clutch, I had to move my dowels on the flywheel, but they wouldnt budge. I tried a little heat (as you can on the new friction plate), but they still would not come out. So I called Fidanza, and they mailed me 3 new dowels free of charge.
So I baked the flywheel in the oven, and put the dowels in the freezer all day. Then the new ones were easily tapped right in to the proper location.
Got the new friction plate, and flywheel finally put on. Torqued to 120ft lbs. I used the 12mm socket trick I found on this thread:
http://www.starquest...howtopic=135466
And here is the new XTD Stage3 6-puck Ebay special. I've read many members here being satisfied with this clutch, so I thought I would give it a try. You can't beat the price at less than $100 currently...
Hopefully, more to come tomorrow....Ill have an extra set of hands to help tomorrow, and we should get the tranny bolted on, and maybe get it dropped into the engine bay....
Edited by Preludedude, 18 July 2018 - 10:52 AM.
#92 croquest87
  • 963 posts
Posted 19 July 2018 - 02:51 AM
Nice clutch and price is right.Have been using stage 3 xtd for 3 years now and it works perfect.
#93 Preludedude
Preludedude
  • 2,589 posts
Posted 09 August 2018 - 11:12 AM
Got the engine put in today....
#94 Preludedude
Preludedude
  • 2,589 posts
Posted 09 August 2018 - 11:13 AM
Look at this tight fit for Chad's intake to the brake booster.....He really nailed the dimensions on this thing:
#95 mbruneaux
mbruneaux
  • 1,394 posts
Posted 09 August 2018 - 10:25 PM
Looks great!!  Running solid engine mounts?  Not much room for flex,
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#96 Preludedude
Preludedude
  • 2,589 posts
Posted 10 August 2018 - 04:34 AM
Engine mounts are a Funk lock driver side, and stock passenger side...
