Fidanza Flywheel
29 replies to this topic
#21 Metric-man
Metric-man
    Stoichiometric
  • 4,000 posts
  • Interests:Astronomy
    Electrical engineering
    Suspensions
    BBQ
    Surfing
    Trucks
    Weather
Posted 06 June 2010 - 09:41 AM
Make sure you have the gear reduction starter, same starter as on the automatic trans.
#22 TopDawg_43
TopDawg_43
    Ignorant Know-It-All
  • 5,265 posts
Posted 07 June 2010 - 11:13 AM
Well, I now know we can not find parts for SQ's at the dealership anymore.
Hated by many, Loved by few, Respected by ALL!!
When we do right nobody remembers, When we do wrong nobody forgets.
#23 Metric-man
Metric-man
    Stoichiometric
  • 4,000 posts
    Suspensions
    BBQ
    Surfing
    Trucks
    Weather
Posted 08 June 2010 - 03:35 PM
They Mitsubishi have a rebuild division for small electrical like starters and alternators
there will be an "R" in front of the part number.
If the part number hasn't changed it would be R-MD072585.
#24 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
  • Interests:Lots of boost!
Posted 08 June 2010 - 10:39 PM
I might be able to measure the stock starter bolts tomorrow morning, maybe tonight and tell you the length, then you can just get the correct length bolts from ACE hardware or something.
#25 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 08 June 2010 - 10:51 PM
I measured each of the three different bolt lengths for the trans-to-block and the top two are 40mm long (only the shaft, not the head). The bottom two are 65mm, and the starter bolts are 60mm. Again, that's not the overall length, just the threaded shaft section, from the bottom of the bolt head to the tip of the threaded part.
Hope that helps. I can't remember the thread pitch, but you might take out one of the bottom bolts and bring it in when you get your starter bolts so you can match the pitch.
#26 Indiana
Indiana
    Addicted Starquester
  • 14,735 posts
Posted 08 June 2010 - 11:40 PM
Starter bolts have a fatter shoulder on them that extends down an inch or so then the bolt is smaller and threaded on the end.
Edited by Indiana, 08 June 2010 - 11:41 PM.
#27 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 09 June 2010 - 08:55 AM
I have mixed up starter and lower bellhousing bolts before. They do thread in to either location, but it doesn't work very well. :)
#28 TopDawg_43
TopDawg_43
  • 5,265 posts
Posted 09 June 2010 - 10:10 AM
I have a new starter.  I need the bolts.
#29 TopDawg_43
TopDawg_43
  • 5,265 posts
Posted 09 June 2010 - 10:20 AM
yeah, that must be what I did two rebuilds ago.  I may need to go through and pull each tranny bolt one by one.  My starter bolts might be in there somewhere.
#30 devilsfutbol17
devilsfutbol17
  • 101 posts
Posted 14 October 2017 - 09:21 PM
Did you ever get a resolution to this? I'm experiencing the exact same problem and have already replaced my starter twice.
796/2000 Summit White Galant VR-4
1994 Pear White 3000GT VR-4
1997 Eclipse Spyder GST (Wife's car)
1988 Fiji Blue Conquest TSi SHP
