Project "Because Racecar"
1088 replies to this topic
#1081 speedyquest
speedyquest
  • 4,195 posts
Posted 24 May 2019 - 08:34 AM
I haven't updated this in awhile yet all kinds of things have happened. Life gets busy, what can I say? lol
About a month ago as the weather started warming up and I started the process of upgrading the flywheel and clutch.
So the motor came out and the rear main seal was replaced before installing the fidanza flywheel and ACT 6 puck clutch. I also installed beehive valve springs.
I also baffled the oil pan but sadly didn't really take any pictures of that...
Another thing I did was make a thermal barrier gasket for the intake manifold. I can tell you that after datalogging it made a very noticeable different. Totally worth it!
After putting the car back together and filling it full of fluids I brought the car up to temp only to quickly realize that I had coolant leaking from the rear coolant port. Soooo I had to take the manifold back off to properly seal that up.
But after that the car was happy and sealed up. Now I'm driving it around and enjoying it. The flywheel upgrade is great, the 6 puck clutch isn't horrible to drive on the street, and the car feels awesome!
And for the second time in the cars life I washed it. It definitely needed it hahaha!
#1082 mbruneaux
mbruneaux
  • 1,464 posts
Posted 26 May 2019 - 07:09 AM
I'm starting to think you just like taking this thing apart.....  Great work and put some miles on it!
Canterbury, CT
2001 BMW 740iL - My Daily
#1083 speedyquest
speedyquest
  • 4,195 posts
Posted 26 May 2019 - 09:22 AM
Haha trust me, your not the first person to say roughly that same thing. I know what it looks like but I really am ready to just drive the thing and enjoy it. That is EXACTLY whats happening now.... well after I install my fuel cell :P
#1084 theboyo19
theboyo19
  • 164 posts
Posted 20 June 2019 - 05:58 PM
Here, I found you a photo
#1085 mbruneaux
mbruneaux
  • 1,464 posts
Posted 22 June 2019 - 03:49 PM
What a great picture.
Canterbury, CT
#1086 speedyquest
speedyquest
  • 4,195 posts
Posted 22 June 2019 - 07:44 PM
Yea man, I totally agree. I've got a picture from the drift event I should post as well.
#1087 prototype78
prototype78
  • 1,028 posts
Posted 15 September 2019 - 12:59 PM
Love this look
#1088 Turbo Cary
Turbo Cary
  • 1,759 posts
Posted 15 September 2019 - 04:02 PM
The thermal barrier gasket, did you use two OE gaskets between it or does it just get mounted by itself? Any coolant leak issues? Considered one for my Miata but couldn't find any solid answers
#1089 speedyquest
speedyquest
  • 4,195 posts
Posted 16 September 2019 - 06:40 AM
I did try using only the thermal gasket the first time and had it leak around the rear coolant port. I believe that only happened because I didn't use gasket maker around the mating surface. I ended up just using the intake gasket on the head side for safety. So in short the thermal gasket only will leak without gasket maker etc. But otherwise should be good.
