Gas petal tough to press in, and car falling on its face
19 replies to this topic
#1 Vuouymons
Vuouymons
  • 160 posts
  • Interests:Car Meets, Sitting Sideways, Racing, Motorcycles, Motorsports
Posted 28 July 2018 - 10:17 AM
Not sure if both of the problems are related, but I literally took the car out the other day and she was running more smooth than ever before. Came back and parked her at the shop, was going to take her for a little spin tonight and warmed her up, hopped in with my lady and right when we are going to take off I let off the clutch while going to gas and the petal nearly gets stuck (while applying normal pressure) and didn't really want to budge. Car also is acting like it was when one of the injectors was clogged and when going near boost starts loosing power. So, I turned it off and went to the store to get the drink we wanted and come back and hop in and toy with the petal while it's not running and it's making a weird, almost grinding, creaking noise when you press down on the petal. I went out to my throttlebody and gasses it there and it wasn't having any issue when I manually gasses it from the throttlebody. Anyone have a idea of what it could be?
Red 87' Chrysler Conquest TSi
Terrorizing Austin Streets
We Don't Call 911
#2 croquest87
  • 1,358 posts
Posted 28 July 2018 - 11:45 AM
It's binding some place cable or linkage got to look under to check where noise is coming from listen and visual
Good luck
Edited by croquest87, 28 July 2018 - 11:46 AM.
#3 Vuouymons
Vuouymons
  • 160 posts
Posted 28 July 2018 - 12:16 PM
I've been looking. I think it's just old... Was going to unlink it from the TB and spray WD-40 down it and let it work its way down the line some and see if that helps. I worked the petal out some with my hand while it wasn't running and just took it on a drive and blasted down the gears and dropped the gas to the floor and it deff wasn't having the same issue as last night. It's still a little rough but I'm starting to think it may just be from old age... weird though because I had driven it with no issue then started it up the other day and the petal felt still (almost thought it was because my powersteering was low for some reason) made sure to fill that up and restarted it and got the power steering through the lines and went to gas out of there when it warmed up and the car barely rocked when i let the clutch out haha.
We Don't Call 911
#4 scott87star
scott87star
  • 4,965 posts
Posted 29 July 2018 - 05:42 PM
Check your negative ground cable, if itís not making good contact to the block then the throttle cable gets used to the demise of the cable.
#5 importwarrior
  • 18,210 posts
Posted 29 July 2018 - 08:35 PM
Like Scott said.
Like arc welding the throttle cable because of a bad engine block negative ground.
Clean it up. Or it will happen again.
#6 techboy
techboy
  • 3,234 posts
Posted 29 July 2018 - 09:29 PM
Do you still have CC?  The CC cable also attaches the throttle and could be getting bound up for some reason.
#7 Vuouymons
Vuouymons
  • 160 posts
Posted 07 August 2018 - 12:00 PM
Well, I've just gone ahead and decided I'm going to get a new throttle cable. Does anyone have the part # for our cables? Or know where to get one new.
We Don't Call 911
#8 Vuouymons
Vuouymons
  • 160 posts
Posted 16 August 2018 - 08:30 AM
Okay, got a new throttle cable and installed it,  now when my gas petal got tough it bent the petal some so I bent it back up, but when I let off the gas now sometimes it gets slightly stuck on open throttle. I was pretty sure I adjusted the cable good, I'm going to recheck it today does anyone have any other idea?
We Don't Call 911
#9 croquest87
  • 1,358 posts
Posted 16 August 2018 - 09:45 AM
Do you still have the extra return spring on your throttle body?  There is one spring that is coiled up on the throttle shaft and one more that's on the outside so there should be two Springs returning the throttle plate to its position.
#10 Vuouymons
Vuouymons
  • 160 posts
Posted 22 September 2018 - 05:22 PM
So actually, I ran this thing maybe once or twice since I replaced this and had to park it so I could get it road legal. I go to take it for a test spin today to make sure everything is fine because I have a kid on the way and this is the car it is suppose to come home in.
My farging throttle cable is stuck again, what the actual f*** could be the issue here? I fixed the major ground and just wasted $30 on this damn throttle cable for this same problem... Not sure what else it could even be but I need to be able to gas the car.
We Don't Call 911
#11 croquest87
  • 1,358 posts
Posted 22 September 2018 - 09:04 PM
You have to go step by step and move and feel every place and look for something that's binding. Usually there is evidence somwhere of something binding. If l was you l would get a buddy to help out moving things while you observe every movement and see what you come up with. Good luck
#12 Vuouymons
Vuouymons
  • 160 posts
Posted 24 September 2018 - 02:31 PM
Allrighty, I got her figured out everyone after a angry night and hunting it down today. Checked all my grounds and we were golden, what it ended up being was. I took my turbo heatshield off when I rebuilt my motor, I saw several others running no heatshield. Not sure if I'm just unlucky, or if people heatwrapped their throttle cable, but there is a rubber/ plastic coating inside of the throttle cable that it slides through and my turbo heated it up too much and stuck it to my cable. I ended up having to tear my cable apart to figure out what was happening because I didn't want to be oblivious again, but if anyone has a spare throttle cable I'm looking. Send pics to my pms and a price. Please and thanks.
We Don't Call 911
#13 importwarrior
  • 18,210 posts
Posted 24 September 2018 - 08:27 PM
The factory cable did have some sort of heat wrap with a foil like outer layer.
It was where the cable circled by the header spark plug area.
#14 importwarrior
  • 18,210 posts
Posted 25 September 2018 - 05:14 AM
#15 Vuouymons
Vuouymons
  • 160 posts
Posted 25 September 2018 - 08:36 AM
Yeah. My original one had it and the second one that I bought was mostly gone, so it probably just took a while to eat through my original heatwrap and melted the plastic to the cable some, and then with the heatwrap basically trashed it just melted it after one start. I've already figured what I'm going to do is get another cable, heatwrap it fully in the bad stuff that they have. Maybe even put my heatshield back on, and see how that runs. Still need to throw a 180 thermostat in it and see if it brings my temp down too.
We Don't Call 911
#16 Vuouymons
Vuouymons
  • 160 posts
Posted 24 November 2018 - 02:09 PM
So after the third cable I'm pretty sure I got her situated this time around. I had heatwrapped the throttlecable (which did work longer than the second cable) but still eventually did melt the plastic to the cable on the inside. No biggie, so I thought the car was just running too hot, but that wouldn't burn the cable and my pops thought it was the turbo, but I see plenty of people running without their heatshield. So finally I took off my exhaust manifold and I had already had one bolt strip on me inside of the head, but apparently a second bolt was stripped as well. ( I think it pulled the threads when there was some vibration from the exhaust originally before I fixed it.) but I'm going to helicoil the head, if not buy the NJV I want all together, but I also figured out my manifold is cracking pretty good now so I need a replacement. Either way I'm about 97% positive the stripped bolt was leaking just enough that hot air was shooting up onto the cable and melted the plastic to it. Was crazy hunting it down, but once I find myself a manifold and get everything put back together correctly I will let you guys know.
We Don't Call 911
#17 importwarrior
  • 18,210 posts
Posted 24 November 2018 - 02:41 PM
Thanks for the update!
#18 croquest87
  • 1,358 posts
Posted 24 November 2018 - 02:47 PM
You can weld that manifold just have to follow some cast iron welding steps.
#19 Vuouymons
Vuouymons
  • 160 posts
Posted 24 November 2018 - 03:07 PM
We were thinking about trying some brass I believe my old man said over the cracks. If it works, I'll run it until I upgrade to a T3 or whichever turbo I decide. I honestly took it off so I could tap the hole in the head and saw more cracks than before. It's definitely time for a NJV head though, so if I can save the manifold I should be able to have a head here soon.
We Don't Call 911
#20 croquest87
  • 1,358 posts
Posted 24 November 2018 - 05:30 PM
What l do is following.
Drill a 1/8 hole on each very end of the crack to stop crack from spreading.
Make a v shaped groove all the way down the crack w carbide grinding/deburing tool almost all the way down.
Preheat your gas grill and get your manifold in there dont open the grill for one hr.
Pull it off the grill and weld it with Weld Mold 700 Ni electrode  at around 85 amps w stick welder. Put 2 beads on it.
Let it naturally cool w no wind or breaze.Or you can put it in some play sand and wait to cool completely.
Cut the webs w one narrow slice each and have a local big truck shop sand down your manifold flange flat.If you have a large stationary sander you can sand it flat yourself but depending how warped it is it may take a while.
Install manifold and torque to specs re torque after couple of heat cycles.
Use OEM gasket from Engine Machine Service.
Simple as that
Edited by croquest87, 24 November 2018 - 05:39 PM.
