WHERE IS THE FUEL PUMP RELAY?!?!?!?
patra_is_here
Technically, there isn't one.
However, I believe what might point you in the correct direction, is the "main relay" located above the ECU.
Tim
The "main relay" has two circuits...
1) one to provide power for injectors
2) the other, to provide power to fuel pump
(note - unlike most japanese 80's cars, our "relay" doesn't provide power to the fuel pump when key is in "ON" position. It waits until key is in "START" position before providing power to fuel pump. Usually our cars won't start on the first cranking attempt, because it takes some time for our fuel pressure to build up.)
the fuel pump relay is half of the control relay
http://www.b2600turbo.com/images/IM000985.JPG
http://www.b2600turbo.com/images/IM000993.JPG
http://www.b2600turbo.com/images/IM000933.JPG
BW-black/white stripe 01 / (+) output / turns on the Fuel Pump when starter is cranking or engine is running
WR-white/red stripe 02 / (-) input / signal from ECU to activate fuel pump relay after
ign. switch moves from "start" position and engine is running
BR-black/red stripe 03 / (+) output / when ignition "on", this sends power to the injectors
B -black 04 / (-) grounded to body
BY-black/yellow stripe 06 / (+) input / from ign. switch "start" position
this activates a relay that turns on the fuel pump
R -red 05 / (+) output / when ignition "on", this powers the ECU
L -blue 08 / (+) input / from ign. switch "on" position
this activates a relay that powers the ECU and the injectors
B -black 07 / (+) input / fuse link back to Battery positive terminal
Just above the ECU
If I'm right do I get a prize?
Dad
Not from me :D But I will agree with your answer.....but...are you smarter than a 5th grader :shock:
Jimmy
I won a million dollars on the "Are You Smarter Than a 5th Grader" home version...where's my check?
That relay right there caused about 2 days of heart ace for me. I unplugged it when changing the ECU, and the relay got pushed under the seat. For 2 Days I tried to get my car to run. I was getting no Spark or Fuel! After switching between ECU's dozens of times I realized There was something missing. After I found it, I Plugged that bad boy in and it started right up.
  • 3 months later...
Im having a problem with my new fuel pump cutting out then coming back on then cutting out again. Could the relay be the culprit?
