Intermittent back fire under boost
6 replies to this topic
#1 mbruneaux
mbruneaux
  • 1,426 posts
Posted 18 March 2018 - 05:54 PM
Under boost (14 or 15 psi) I sometimes get a single backfire when revs are climbing no specific but above 3500. Lambda gauge reads about 11, New plugs, wires and a known good distributor. I couldn't tell you what kind of plugs they are. Car pulls really hard and feels great.
SS valves, Ported exhaust manifold, Chads upgraded f/I with precision injectors. Lower shores manual boost controller.
Feedback and ideas are  much appreciated.
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#2 croquest87
  • 1,293 posts
Posted 18 March 2018 - 06:42 PM
BUR7EA-11 gap set at .035 easy to try on the cheap! Maybe lean out just a touch
#3 mbruneaux
mbruneaux
  • 1,426 posts
Posted 18 March 2018 - 07:25 PM
Thanks, I have a Maf-t to install maybe I can lean it out with that. I'm so paranoid of going too lean!
Canterbury, CT
#4 croquest87
  • 1,293 posts
Posted 18 March 2018 - 08:39 PM
Maybe do the plugs and try it out first could be other things but plugs are easy. Hope you have forged pistons and head studs at bare minimum if you plan on pushing 14-15 +psi
#5 Hoosierquest
Hoosierquest
  • 1,407 posts
Posted 19 March 2018 - 02:16 AM
I have to run my plugs closer to .030. Think last time set them at .027 actually.
#6 importwarrior
  • 18,176 posts
Posted 21 March 2018 - 06:58 PM
Vac advance suck test
And gap plugs.
I gap mine at .028
#7 mbruneaux
mbruneaux
  • 1,426 posts
Posted 21 March 2018 - 07:58 PM
I testet vacuum advance and and it's good, I'm checking the gap and installing the the Maf-t
Canterbury, CT
