MPI Manifold + EDIS Components + Turbos
spoon32
Over the past few years I've reconfigured quite a few items on my car and now have some extra items I no longer need........
Intake manifold was run on the car for 2 years with me in addition to the 2 prior owners of the car. The manifold was originally built by quest925 ( http://www.starquest...topic=58298&hl= ). It has had some modifications along the way.
Firstly at some point the throttle body was welded to the manifold. Secondly a the rear coolant port was opened up in order to flow to the heater core. The original paint had gotten pretty bad from heat/chemicals so I cleaned the majority of it off.
Other bits: throttle body is a 65mm BBK for a 86-93 5.0L mustang, works with stock throttle cable, uses an inline thermostat housing (not in photos but will supply with intake).
Manifold made good power and was very streetable. I would recommend the throttle body be cut off and a different TB put on. Like ALL BBK throttle bodies it suffers from vacuum lock at small throttle openings.
http://i1101.photobucket.com/albums/g428/sq_spoon32/P1010049_zps90955cd3.jpg
http://i1101.photobucket.com/albums/g428/sq_spoon32/P1010050_zps42efa360.jpg
http://i1101.photobucket.com/albums/g428/sq_spoon32/P1010051_zps550f42fc.jpg
http://i1101.photobucket.com/albums/g428/sq_spoon32/P1010052_zpsaf8afa3b.jpg
Also for sale is an EDIS setup excluding the VR sensor and trigger wheel. EDIS module was purchased new and has less than 1000mi on it. Coil pack is a high discharge unit from ACCEL.
http://i1101.photobucket.com/albums/g428/sq_spoon32/P1010053_zps1e1fee9c.jpg
http://i1101.photobucket.com/albums/g428/sq_spoon32/P1010054_zps16b9ba37.jpg
Asking 350$ for the manifold and 70$ for the EDIS components. Will consider offers.
Thanks,
--Eric
Edited by spoon32
I also have 2 turbos for sale.......... 18G with a polished cover and a 17c typhoon/cyclone turbo. The 18G needs rebuilt and a new compressor wheel. The 17c is of unknown condition. I can sell them as is or I can PERSONALLY rebuild them for the buyer. Price is negotiable on both depending on the condition the buyer chooses. Photos available upon request.
--Eric
More items found around the house for sale or trade........... Make offers on any items.
(1) 240mm stock flywheel in good condition
(1) OEM radiator with no leaks...... has never been cleaned but car did never overheated even in traffic.
Primary and secondary fans are still attached and both work.
(1) Torque tube drive shaft. spline teeth are clean and in good condition
(1) Spline hub for differential input. Was used with the torque tube above and also cleaned with spline teeth in excellent shape.
Can get photos of any of the above upon request.
The EDIS package includes everything needed except the VR sensor (5-10$ of ebay new) and the crank trigger wheel. I used the Mookeh crank trigger wheel.
No need for a dizzy block off plate....... knocking a brass freeze plug in the head seals the dizzy hole and looks good.
I was running the whole MPI setup with megasquirt 3. I can help with wiring and diagrams if needed.
Thanks for the questions,
--Eric
  • 3 weeks later...
  • 1 year later...
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
