SFBMX88 Flatty build
Starting in May 2008
95 replies to this topic
#81 SFBMX88
SFBMX88
  • 1,522 posts
Posted 18 January 2018 - 08:50 PM
December 2017 - even more...
Had everything bolted up in car to help mitigate distortion during welding.  Still have to weld up some support on the bottom ends of
the rack mounts.  Picked up some Energy Suspension Poly rack bushings.
Stock length S13 steering shaft connected to rack.  Gonna cut this down soon.
Heated the steering shaft to pull everything apart.  Ended up doing more to it in January, so see those updates later.
Got the 7/8" clutch master cylinder in.  Stuby, so it fits in the factory location easily.  Wanted to retain the factory
hardware, so I had to modify a couple things.
Swapped the pushrods out so I could retain the metric threaded clevis.  Would probably be a better idea to pick up a new SAE clevis...
Gonna need some trimming
FYI 3/8" and 10mm banjo fittings are interchangeable.  M10x1 inverted flare to banjo fitting and 3/8" banjo bolt.
#82 SFBMX88
SFBMX88
  • 1,522 posts
Posted 18 January 2018 - 08:51 PM
December 2017 - almost done.  Maybe.
Heated up the Starion remote reservoir cover and fit it over the Tilton master.  Should be fine.  Even the adapters that came with
the master cylinder had a tight interference fit.
Starion clutch pedal is about an inch longer than the GTOs.  Fulcrum points are almost the same.
Ill be using a 4 pin brake switch I had from my last Starion to take the place of 2 clutch switches from the GTO.  The brake switch circuits
do exactly what the GTO clutch switches do in the clutch pedal up and down positions.
Factory Starion clutch switch(left) removed.
Get in there already!
Clutch set got delivered.  Monster Stage 2 w/18lb flywheel - seems to be what a lot of GTO owners are using with great results.
Ill get to installing it when the motor and trans get lined up to go in the car.
OEM friction surface vs Monster
Some flywheels: D16 Honda(top), Starion 240mm(right), Monster(left), OEM LS2(bottom)
Got sick, so with lots of Dayquil and Ricola, I worked on the Evap and fuel level sensor.  All going on to satisfy Californias engine
change requirements.  The GTO actually has very few emissions components(like 2 less) compared to the F-body LS Camaro/Firebird.  Just
the basics, but no EGR or air injection to worry about.
1999 Suburban canister was used for the smaller canister to fuel tank fitting.
Cleaned all the dirt out of the vent valve.
Plenty of room!
Tank and fuel lines out.  Will be going to a single 3/8" fuel line when the time comes.
Saved the evap canister mount from the GTO.
#83 SFBMX88
SFBMX88
  • 1,522 posts
Posted 18 January 2018 - 08:52 PM
December 2017 - Probably the last post for the year....
Evap mount spot welded in then painted.
Not a bad fit.
Gonna try to use the quick connect fittings with the rubber hose.
Time for the fuel level sensor.
Finished the sensor and float in January and didnt even use the measurements I took initially.  Had a day or two
to think about it, and came up with a pretty good solution.  Ill post that next month, sorry for the cliff hanger ending!
#84 GSRVR
GSRVR
  • 169 posts
Posted 19 January 2018 - 01:57 AM
Great update & pics, keep up the good work she's getting there!
|1988 RHD Mitsubishi Starion GSR-VR|
#85 mbruneaux
mbruneaux
  • 1,391 posts
Posted 19 January 2018 - 09:04 AM
Very impressive, looks great.
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#86 SFBMX88
SFBMX88
  • 1,522 posts
Posted 23 January 2018 - 01:31 PM
January 2018
Probably not gonna have much time to work on the swap in the coming weeks, as I have to do actual work in the shop, so heres a new year photo dump!
After a day or two of thinking about how to mount the fuel sensor, I drew up a diagram on the bench.
Used a coat hanger as a template for the float rod.  The bends have to be just right so the whole assemble will fit through the gas tank sender hole.  I didnt initially take this into consideration, and got lucky when installing everything back in.
CAREFULLY bent the factory Starion float rod to match the template.  These things are brittle.  I actually snapped the two GM rods I had originally wanted to use.
Bracket lined up for a few tacks.  The part that held the low fuel level light switch works as a mount for the level sensor.
I used a section of the in tank fuel line off the GTO as a conduit for the sensor wires to avoid any chaffing.  The nylon zipties are actually safe to use in fuel according to the material safety data sheet.
Float rod maintained the same plane of travel as stock, so after a lot of checking, the float shouldnt hang up anywhere in the tank.
Soldered the in tank GTO wiring to the factory Starion terminals.
I see now why my car would never show a full tank whenever I filled it up.
Added in some new circuits(evap vent+tank pressure) to the tank sub harness.  Will most likely use the newer GTO connector in the trunk area to connect everything.  Also replaced all the vapor lines while the tank was down.
New fuel line too!  Decided to stick with the Walbro 255 that I had previously installed to fuel the LS2, as the factory GTO pump is rated around 190lph.
Edited by SFBMX88, 23 January 2018 - 04:17 PM.
#87 SFBMX88
SFBMX88
  • 1,522 posts
Posted 23 January 2018 - 02:16 PM
January 2018 - last one
Hoses, wires and tank pressure sensor getting situated.  I ended up using a P-clamp to mount the pressure sensor on the tank near the fuel pump.
Built up a mount for the evap vent valve.  Went right above the canister.  Suburban parts save the day again!  Vent hose to valve was a perfect fit.  Cut the vent mounting tab of the Suburban bracket and welded it to my tank mount.
Using one of the threaded holes for the original fuel/brake line routing, I mounted up a C5 Corvette fuel filter to feed the single "returnless" LS2.  3/8" feed, 5/16" return to tank, and will have a single 3/8" line to fuel rail.  Used quick connect adapters to hook everything up.
Leak checked everything, and its passable for a 1995 and older - leak size less than 0.030".  For OBD2 cars 1996+, the limit is a leak through a 0.020" size hole.  Ill just have to get the swap done so I can drive it to set all the OBD readiness monitors.
Thanks for all the support guys!  Hopefully Ill have this motor in by my next post!
#88 Turbo Cary
Turbo Cary
  • 1,493 posts
Posted 23 January 2018 - 03:32 PM
Why not just drill the top of the fuel level sending unit to fit the FTP sensor? Great build by the way. Are you incorporating a GM body control module into the car as well?
#89 SFBMX88
SFBMX88
  • 1,522 posts
Posted 23 January 2018 - 04:22 PM
Thanks man!  There actually isnt enough room for it.  That hole is deceptively small.  Also, I wanted to keep the sensor away from liquid fuel slosh, so I placed it after the plastic fuel separator.  I have to run the BCM in order to use the GTO cluster, so itll go where the stock Starion ECU went.  Ill have the option to add in all the keyless features, but I probably wont in all honesty.  I plan to use an RFID box to disable something in the car for anti theft.
#90 SFBMX88
SFBMX88
  • 1,522 posts
Posted 12 February 2018 - 12:56 PM
January 2018 - Some progress I forgot to post...
Took some measurements of the intermediate shaft and shortened it while trying to retain its collapsibility.
Because I dont trust my Horror Fright chop saw to make a straight cut, I welded the shaft to a piece of angle steel for stability.
Couple more measurements.  Cut two inches out of the female side and used the scraps to help clamp the male side down while welding it.
Cut came out pretty good.  Took about an inch out of it.  Beveled the ends for the connecting weld.
Cut another 5/8" out by removing this length of splines.  I found out later that these splines may have an interference fit with the receiving shaft.  The modded piece now goes back in too freely.  Im just going to put a tack weld to keep the two pieces together.  If I ever wreck, the weld should break easily, and the intermediate shaft assembly should collapse....hopefully.
So the S13 lower column housing fits over the Starion upper housing.  Gonna have to figure out a lower column to firewall mount and seal.
Measured the two columns side by side to figure out how long the steering shaft needs to be.
To be continued.....
Edited by SFBMX88, 12 February 2018 - 12:58 PM.
#91 SFBMX88
SFBMX88
  • 1,522 posts
Posted 12 April 2018 - 11:06 AM
February 2018 - a - server crashing updates
After I mounted everything up, the swaybar didnt really have any clearance from the pan, so Im gonna have to notch the subframe+mounts and push the motor back..
"Connected" the lower s13 steering column to the upper Starion end.  Tried to get it welded up as straight as possible with "jig".  Ended up
using a piece of filler wire on a magnet to check runout as I went along.  Came out pretty straight!  The collapsability of the column is also retained.
Revisited the evap system and added a roll over valve based on the advice from another swapper trying to get California legal in a Miata.
-10 fittings, and I had to clock one of the factory fittings on the pick up to make room:
Had to take some material out of the roll over valve for clearance.  Also had some -10 fittings left over from earlier projects ready to go.
Edited by SFBMX88, 12 April 2018 - 12:11 PM.
#92 SFBMX88
SFBMX88
  • 1,522 posts
Posted 12 April 2018 - 11:08 AM
February 2018 - b
The -10 lines match the inner diameter of the factory GTO evap tank to canister lines, so flow should be even with no restrictions
Had to relocate the tank pressure sensor, plug the tank line to filler neck, and tee the large evap line to the filler neck
Rechecked for leaks, and it seems okay!
Everything fits fine, and looks a little cleaner too
#93 SFBMX88
SFBMX88
  • 1,522 posts
Posted 12 April 2018 - 11:43 AM
February 2018 - c
Kept the tunnel out of the GTO just in case.....The Starion auto trans tunnels are almost as wide!  The height is the main issue, so I may end up patching the GTO tunnel in.
Gotta notch the subframe.  I also took some material off the rack for oil pan clearance.  Flapper wheels eat aluminum pretty quick!
Subframe to motor mount clearance, and card stock templates. Lined everything up on the floor, which probably wasnt a good idea down the road..
Factory style motor mounts with the passenger side GTO engine bracket actually contact the swaybar.  I found out later that Corvette engine brackets will help with clearance on the passenger side.  I picked up some stock height Hinson polyurethane mounts instead.
A plasma cutter would be a great investment!  Kept things straight by welding on a piece of steel which I cut off after everything cooled off.
#94 SFBMX88
SFBMX88
  • 1,522 posts
Posted 12 April 2018 - 11:44 AM
February 2018 - d
Ive gotta work on those uphill welds.  Overhead came out better than I thought they would.
Stuborn pilot bearing I ground down to weaken.  Theres actually a plug in the back of LS cranks, so you dont want
to fill the back cavity with grease and hammer it to get the bearing out, or you'll blow out the plug.
18lb Steel flywheel with ARP bolts and new Monster stage 2 clutch in.
Took measurements of the clutch and throw out bearing clearances, and determined the slave cylinder needs a spacer.
Motor finally in there on its own!  Checked clearance all around.
Motor was actually sitting lower than I liked
Room between brake booster and firewall, radiator support and pulley
Thats it for February!  I got even less done in March... :wacko:
#95 mbruneaux
mbruneaux
  • 1,391 posts
Posted 12 April 2018 - 12:26 PM
Incredible work and thanks for all the pictures.
Canterbury, CT
#96 importwarrior
  • 17,960 posts
Posted 12 April 2018 - 12:32 PM
That engine sitting so low would be great for low center of gravity and handling.
looks like it was meant to be in there.
