Cracked Chad Header
18 replies to this topic
#1 SSG_CARTER
SSG_CARTER
  • 140 posts
  • Interests:Fast cars bikes and speed.
Posted 11 August 2019 - 05:49 PM
Inherited thus with the car . Hairline crack at #2 cyl up and around the collector. Braze or reweld?
#2 croquest87
  • 1,671 posts
Posted 11 August 2019 - 06:14 PM
Weld it! That material will be easy to tig/mig just clean it good first. Brazing would work to but nothing like when you melt base material for good  fusion. Perhaps use ss rod/wire
Edited by croquest87, 11 August 2019 - 06:21 PM.
#3 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 11 August 2019 - 08:11 PM
Roger that. Will do. Will update .
#4 ucw458
ucw458
  • 11,611 posts
Posted 12 August 2019 - 12:13 AM
Brazing shouldn't be used on turbo systems.  Some may disagree with me on that.  But if you are driving hard you can get the exhaust glowing red.  That's about the temp brazing material melts.  So your brazed crack repair may blow open again the first time you get that exhaust really hot.
My 87
#5 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 12 August 2019 - 05:32 PM
Well unfortunately took it to a shop . Hole blowed in it with ss stick. Now I have an expensive paperweight . You get what you pay for.
#6 SSG_CARTER
SSG_CARTER
  • 140 posts
Thank you I apologize if i sound pissed. I am.
#7 BC_99
BC_99
    Plays in traffic
  • 5,224 posts
Posted 12 August 2019 - 08:09 PM
Oh no! wt....? Who in the hell would try to stick weld a header??? I am sorry that this happened, however...all might not be lost. Contact Chad and see if he would cut that section out and replace it. I’m sure that it can be saved.... if Chad won’t help you out, Pm me. I am a fabricator/welder. I will take a look at it. Preferably Chad will be willing to fix it, as he would be much more familiar with it, but certainly someone can cut out and splice in a new piece of tubing.
BC
#8 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 12 August 2019 - 09:16 PM
Roger that. I will pm Chad and send pics and details. Thanks for the info, I will keep all posted.
#9 croquest87
  • 1,671 posts
Posted 13 August 2019 - 05:10 AM
Good experienced welder could fix that w no problem. Small piece fabricated and welded in that's all. Good luck.
#10 ucw458
ucw458
  • 11,611 posts
Posted 13 August 2019 - 12:07 PM
Stick weld,  sounds like you took it to someone who doesn't know what they were doing.  While not impossible to stick weld thin pipes together it's any competent welders last choice to do so.  Stick is reserved for thicker metal.  Mig and tig are the preferred choices.  I would take it to another welding shop.
My 87
#11 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 13 August 2019 - 02:28 PM
Done ✅  reputable shop has it surgery will begin shortly
#12 croquest87
  • 1,671 posts
Posted 13 August 2019 - 02:55 PM
Agreed 100%  l only use stick for 1/4 and up structural not so good looking stuff you can paint over. Lol.  It does work well for our OEM cast manifolds w special electrode  drilled end of crack  v grooved heated to 600F  welded at 80 amps  never had one crack after.
Edited by croquest87, 13 August 2019 - 03:04 PM.
#13 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 15 August 2019 - 07:31 PM
She is repaired and good as new. Used a reputable welding company. Lawless Welding Martinsville Va. they repaired the crack along #2 runner cleaned old weld rewelded the collector. It had a crack half way around the base. Excellent work. Thanks all helping me explain what I wanted done. Now back to boost .
#14 croquest87
  • 1,671 posts
Posted 15 August 2019 - 08:26 PM
Glad you fixed it.
#15 BC_99
BC_99
    Plays in traffic
  • 5,224 posts
Posted 15 August 2019 - 08:33 PM
Pics or it didn’t happen.....
BC
#16 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 15 August 2019 - 08:53 PM
Someone pm me a cell number and I will provide after pics.
#17 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 15 August 2019 - 10:00 PM
Pictures are in my Gallery under Chad header repair.
#18 03CL55AMG
03CL55AMG
  • 634 posts
  • Interests:cars and more cars, and hot girls
Posted 05 September 2019 - 04:01 PM
how long did you have that header on the car....and how often do you drive it.
Forged motor, weisco pistons ,3" exhaust, garret 60 cold/ 70 hot turbo, bosch 1000cc injectors. meth kit. chads intake and header. holly EFI stand alone. *DM intercooler. grimspeed boost controler. stock cam.
#19 SSG_CARTER
SSG_CARTER
  • 140 posts
Posted 06 September 2019 - 09:53 PM
I imagine 10 years or so from previous owner info. It is as good as new now.  I drive this car about everyday if i can. Not far but driven daily to to diagnose and learn the mpi tuning with this Haltech E6K.
