Dsm coolant oil cooler??
8 replies to this topic
#1 boostinmini
boostinmini
  • 911 posts
  • Interests:G54b, 4G63, anything mitsubishi especially pre 2000s, custom fabrication and mountain biking.
Posted 29 July 2017 - 10:53 PM
Any one know know if the coolant oil cooler from a 4g63 would fit the 2.6 block?
#2 TexasQuest
  • 8,882 posts
Posted 31 July 2017 - 09:17 PM
They look similar. Only one way to find out. ;)
88 Fiji Blue -Tsi
#3 boostinmini
boostinmini
  • 911 posts
Posted 01 August 2017 - 08:38 AM
Been waiting for one to show up at the auto wreckers for about two years, dsms are non existent in Canada now😯
#4 TexasQuest
  • 8,882 posts
Posted 02 August 2017 - 10:09 PM
Yeah they're getting scarce here in the states too.
88 Fiji Blue -Tsi
#5 AUstarion VR4
AUstarion VR4
  • 39 posts
  • Interests:Motor Racing
Posted 14 August 2018 - 12:19 PM
Unfortunately no they won't, 4G63 bolt to the timing cover & are completely different. Would a pic help? BTW does anyone have a 2.6L 4G54 oil by-pass housing they aren't using? Need one for my new project.
#6 speedyquest
speedyquest
  • 4,149 posts
Posted 14 August 2018 - 03:00 PM
Why not just buy a good quality aftermarket one?
#7 Maxzillian
Maxzillian
    Car Shaman
  • 2,653 posts
  • Interests:Autocrossing, atv riding, general tinkering, machining, a few other things.
Posted 17 September 2018 - 12:05 PM
I can't comment on the DSM cooler, but I did use one from a F-150 on my car. I had to machine a new threaded adapter for it, however, due to the extra length required.
What's the fun in making something simple?
'87 TSI - StarOrion braided brake lines, StarOrion radiator, StarOrion alternator, StarOrion 2.5" stainless exhaust w/Magnaflow muffler, 1G MAS, Competition Clutch 15 lb flywheel, Competition Clutch Stage 4 clutch, Mookeh polyurethane bushings, ABS elimination, 8:1 Wiseco Pistons, TD05 14G turbocharger, Axiss ceramic rear brake pages, Hawk HP+ front pads, heat wrapped and ported exhaust manifold/turbine housing, Accusump oil accumulator, remote oil filter, NJV head, EVO intercooler, remote battery, D2 coil over struts, flatty front struts and control arms, 8" non-SHP wheels all four corners, 12.75"x1.25" front rotors with 4 pot Wilwood calipers, manual brakes using dual master cylinders and balance bar, gutted (deleted) brake proportioning valve and modified steering pump speed sensitive valve.
#8 jinx
jinx
  • 1,918 posts
Posted 18 September 2018 - 07:31 AM
Expedition excited my cousin, so he bought a new one cash. Zero problems... until.... that oil cooler failed. Luckily caught it in time
Some of his cutomers didn't. Cost them a motor - mixing oil & coolant. He's yanked those things out of more than a few Fords, mixing oil.
Quote
the oil filter housing you have an external oil cooler that is bad and letting oil into the coolant.We see this problem all the time
https://www.fordf150...pic.php?t=24371
Ford had some issues with the cooler, metal formula on alot of trucks it appears. Hope they sorted it out
nissan CA18s still have their coolers functioning.... from the late 80s, without leaking
#9 jinx
jinx
  • 1,918 posts
Posted 18 September 2018 - 07:43 AM
my 1st three DSMs were all 1990s. Wasn't seeking them out, it's what found me.
A fool year, with wierd electronics and ext oil cooler like a 2.6... so I thought all 1st gens had em
When shuffling around parts, putting spares together in a car to sell... is when I noticed 91+ DSMs had a coolant-cooled oil cooler?
http://www.dsmtuners...ler-jpg.412120/
Thread starter is probably asking if this part can screw onto a G54 oil filter base
Try DSM forums. Those dudes have a ton of parts
