$8 Fuel PSI test, FILTERS & more ...pics
32 replies to this topic
#21 Professor Quest
Professor Quest
  • 9,987 posts
Posted 18 November 2004 - 10:58 PM
These are the filter screens located right above the injectors in the UPPER TB housing. Never attempt to remove these. Flush some carb cleaner back and forth over them. wink.gif
#22 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 18 November 2004 - 11:08 PM
#23 Professor Quest
Professor Quest
  • 9,987 posts
Posted 18 November 2004 - 11:16 PM
A little push on the conical filter and it snaps into the FACTORY FUEL PUMP. Now there needs to be CLEARANCE AROUND this filter for it to flow fuel. FORCING it into an AFTERMARKET PUMP DON'T MAKE IT!  :smile.gif When you pull the hose from the pump, the filter will be stuck INSIDE THE HOSE.
#24 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 18 November 2004 - 11:23 PM
#25 Professor Quest
Professor Quest
  • 9,987 posts
Posted 18 November 2004 - 11:30 PM
This is what locates the IN-TANK filter. It is the 12mm pick-up tube. The smaller tube is the fuel return line. Notice how clean the outside of the tank looks. Notice the oxidation on the tubes! Wire wheel time. On top of the new filter you can see a "nipple". The filter has two of them. They retain the filter. They also tend to snap off when you try to remove the filter. Better to have a new one ready to replace the old one. Run bore brushes thru both steel lines. That will also give you an idea of what the long steel line that runs to the front of the car MIGHT have in it. wink.gif
#26 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 18 November 2004 - 11:50 PM
#27 Professor Quest
Professor Quest
  • 9,987 posts
Posted 18 November 2004 - 11:58 PM
NO........that is not NORMAL. This is not a good sign. :smile.gif
#28 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 19 November 2004 - 12:06 AM
#29 Professor Quest
Professor Quest
  • 9,987 posts
Posted 19 November 2004 - 12:11 AM
This is the inside of the tank. The "FENCE" on the left is where the in-tank filter goes. It helps keep fuel around the filter. This tank will need a trip to the radiator shop. sad.gif
#30 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 19 November 2004 - 12:16 AM
#31 Professor Quest
Professor Quest
  • 9,987 posts
Posted 19 November 2004 - 12:19 AM
Notice the FENCES front and aft of the pick-up fence.
#32 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 December 2004 - 10:17 PM
#33 Professor Quest
Professor Quest
  • 9,987 posts
Posted 10 June 2005 - 11:04 AM
:wink:
