Test Fire/Clean Injectors...pics
44 replies to this topic
#21 Professor Quest
Professor Quest
  • 9,987 posts
Posted 14 November 2004 - 12:21 AM
DO NOT TRY THIS!!! This is gasoline mixed with some ATF to HELP TAKE A BETTER PICTURE. Too bad the injector stuck OPEN. Better run some more carb cleaner threw it. sad.gif  Well, there you have it.............a 9 volt battery can also CONTINUOSLY fire the injector as well. BTW......this injector continued to be stuck open after being fired a few times. I got stupid and hit the pulse button when there was not enough carb cleaner left. This made the injector fire DRY. DON'T DO THAT! ;D You can also REVERSE FLOW THE INJECTORS. Just put the hose on the other end. If you have an injector stuck open..............TRY IT!
#22 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 14 November 2004 - 02:01 AM
for test clips ,  remove the spring  retainers  , you'l be pluging and unpluging the injs  too much , and you  won't need them
88TSI Silver
89TSI red auto
#23 Professor Quest
Professor Quest
  • 9,987 posts
Posted 14 November 2004 - 03:20 AM
That's EXACTLY what I was thinking right after I broke it. ;D The "PULSE TOOL" has no wire clips. I just wanted to see how much resistance the new connector had while checking the OHMs. You can't run the OHM test with a "PIG-TAIL" on. Way too much resistance. I better get some new leads for the OTC  DVOM. Never could get the OTC to "zero-out". >:(
#24 Shelby
Shelby
    Rookie
  • 50,164 posts
Posted 14 November 2004 - 03:26 AM
not  to get off track  too  far but what'd  you do with all your  free time befor you found this site hehe  lol
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
88TSI Silver
89TSI red auto
#25 Professor Quest
Professor Quest
  • 9,987 posts
Posted 14 November 2004 - 03:38 AM
Played golf, worked on the boats,  hang out at the lakes, drove the little Mrs. CRAZY,  ;D
#26 albanyGA87TSI
albanyGA87TSI
  • 149 posts
Posted 14 November 2004 - 07:28 AM
so I can use a 9 volt battery to clean my injectors???    Whats you recommended cleaning solution?
87 Conquest
#27 Professor Quest
Professor Quest
  • 9,987 posts
Posted 14 November 2004 - 01:36 PM
NEW pic above will help you. wink.gif You just soder a connector to a 9 volt battery. Fill about 3 feet of hose with carb cleaner and provide 40-50 psi of air to that hose after you fill it. Then apply the currant. Pretty easy. wink.gif Some injectors will "pee" or drip fuel. If after several attempts to run carb cleaner threw them they still do it, they're done. wink.gif
#28 Shelby
Shelby
    Rookie
  • 50,164 posts
Posted 14 November 2004 - 04:30 PM
spraying the inj's into a  gas safe container  will  enable you to  reuse or save the carb  cleaner , you can also  soak the inj with the  tip open to help remove stoburn   deposits
88TSI Silver
89TSI red auto
#29 albanyGA87TSI
albanyGA87TSI
  • 149 posts
Posted 14 November 2004 - 09:23 PM
WOW great post ... I got setup adn plugged in my black injector and it sputtered spit and pee'd then shot out a pretty mist  I ran inj cleaner then ATF then Gas  repeate dfor my othe inj.
that may have solved my 3000 rpm problem!  Wont know for sure until I get my radiator back tomorrow
87 Conquest
#30 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 November 2004 - 04:26 AM
Well, Bill, if it doesn't and you have a new injector clip see  "TPS INSPECTION...pics" on this forum. wink.gif
#31 edjee
edjee
  • 212 posts
Posted 16 November 2004 - 12:56 PM
I WANNA DO THIS!!  Is ther directions and equipment needed on ur site?  This is great  ;D
#32 Professor Quest
Professor Quest
  • 9,987 posts
Posted 17 November 2004 - 12:59 AM
Oops! Modified!!
#33 Professor Quest
Professor Quest
  • 9,987 posts
Posted 19 November 2004 - 01:58 AM
#34 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 December 2004 - 10:14 PM
#35 Professor Quest
Professor Quest
  • 9,987 posts
Posted 22 December 2004 - 12:23 AM
8)
#36 kev_rm
kev_rm
  • 489 posts
Posted 22 December 2004 - 10:56 PM
good stuff,  I like the clear hose idea, so you don't run air thru them.
#37 Professor Quest
Professor Quest
  • 9,987 posts
Posted 22 December 2004 - 11:08 PM
Here's another tip............if you think they are stuck open.........suck on them. wink.gif
#38 87Montero
87Montero
  • 24 posts
  • Interests:Bounce it.
Posted 02 January 2005 - 08:09 AM
Very nice, I just did this on my engine and I believe it fixed my leaky secondary problem.
Just one question..
when I hooked the hose up to the spray part of the injector to shoot the cleaner in backwards... The primary injector would just spray the fluid out before I even hooked up the battery, but the secondary needed the battery in order for the cleaner to spray through backwards... Any reason why?
thanks!
#39 kev_rm
kev_rm
  • 489 posts
Posted 02 January 2005 - 09:20 PM
because your primary is leaking....
#40 Professor Quest
Professor Quest
  • 9,987 posts
Posted 07 January 2005 - 01:59 AM
