TPS "INSPECTION".....pics
43 replies to this topic
#21 Professor Quest
Professor Quest
  • 9,987 posts
Posted 15 November 2004 - 09:07 PM
The more I "LEAN INTO IT".........the more it moves toward ZERO RESISTANCE. AND the POINTER is moving SMOOTHLY towards zero. No jumping around.......no "HIC-UPS" unlike the bad one.
#22 Professor Quest
Professor Quest
  • 9,987 posts
Posted 15 November 2004 - 09:10 PM
#23 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 15 November 2004 - 09:11 PM
#24 Professor Quest
Professor Quest
  • 9,987 posts
Posted 15 November 2004 - 10:08 PM
WFO now, ZERO RESISTANCE.............the motor is lovin it. We'll move on to performing one other test. But if you failed this one...........TOSS IT! wink.gif
#25 GoFastBeater
GoFastBeater
  • 2,599 posts
Posted 16 November 2004 - 07:22 AM
If  you plan to do this test and need to buy a voltmeter, Sears has a nice one that is both analog and digital.  The sweep needle is above the digital display.  I think I paid about $50 for mine.
ADAM
SOLD--89 SHP, sy/ty 20g, custom header, 52mm intake/tb, 284 cam, MAFT, 3" exhaust, hardpipes, Greddy BOV............
#26 edjee
edjee
  • 212 posts
Posted 16 November 2004 - 07:21 PM
We can do this test with our tps in the car right?  Does the battery need to be connected?  Sorry, I just want to try this now  ;D
#27 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 16 November 2004 - 07:26 PM
This is resistance.. So, it doesn't matter if the battery is hooked up or not..  I've done it in the car, and with a spare TPS on my bench..  You just wanna see if it operates smoothly as you slowly open the throttle... ;D
#28 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 November 2004 - 08:58 PM
"Can you do it in the car?" you can do it in a car...........you can do it in a bar.......BUT JUST DO IT! ;D
#29 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 16 November 2004 - 09:05 PM
#30 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 November 2004 - 09:14 PM
OK, this is the OTHER "INSPECTION". Use the TOP pin and the LEFT LOWER pin. The "STANDARD VALUE" is 3.5 to 6.5 KILO OHMS. Why am I not surprised that the BAD TPS also failed this test. :smile.gif
#31 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 16 November 2004 - 09:15 PM
#32 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 November 2004 - 09:23 PM
And the WINNER is................THIS TPS! ;D
#33 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 16 November 2004 - 09:25 PM
#34 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 November 2004 - 09:27 PM
Now then............Once you have a GOOD TPS.......you can ADJUST IT using  VOLTS. Open manual to page 14-32, 14-33, 14-34   Make the little harness adapter above. Start the car, let it warm up. Adjust the VOLTAGE at idle to 0.48-0.52 volts. When you open the throttle all the way you should see AROUND 4.5 -5.5 VOLTS. You might make 4 of those wires......you'll need them for the ISC adjustment. wink.gif
#35 Professor Quest
Professor Quest
  • 9,987 posts
Posted 16 December 2004 - 10:22 PM
Moving to "Starquest.i-x. net" See "Professor's Manual for Dummies"  ;)
#36 JAinsworth
JAinsworth
  • 16,873 posts
Posted 17 December 2004 - 03:52 AM
Wayne/John,
Can you get a close up pic of the ends of the harness adapter?
Jimmy
#37 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 17 December 2004 - 04:28 AM
They look to be the same size as I used for the fuel pump test port's jumper wire..
What I've always wanted to know, is how do you take off some of the wire's sheathing like that?  I need to know before my A/F goes in, and I can't figure out how to take off just a middle section...
Hmmn, maybe I should just play with some wire and figure it out.. ;D
#38 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 17 December 2004 - 10:07 AM
Jimmy i think they are commonly refer'd to as a  1/2 spade
88TSI Silver
89TSI red auto
#39 Professor Quest
Professor Quest
  • 9,987 posts
Posted 17 December 2004 - 12:04 PM
Look closer..............that is not a "midway" strip.  Cut  the insulation about 2" from the END OF THE WIRE...........pull the insulation off about 1/2"..........THEN strip  just the end off! wink.gif  CLEVER! ;D
#40 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 17 December 2004 - 07:52 PM
Sneaky... ;D
But in my case, that's not going to work... For a A/F gauge, I don't wanna have to disconnect a wire from the ECU to get the sheathing off...  Maybe I could burn it a little bit..Just to the point where it gets soft, then I can pull it off without damaging the ECU connection..
