Keeping your Starquest Cooler....
23 replies to this topic
#1 KO
KO
  • 2,751 posts
Posted 14 June 2002 - 09:14 AM
Here are some things you can do to keep your car running cooler.
1. Get your radiator rodded, usually $40-$50. Your radiator is over 12 years old and it's probably nasty.
Rod Out - Rodding out a radiator means to remove usually one or more tanks from a radiator and to insert a flat rod, which is smaller than the width of the tube, into the tube by pushing that rod through until it comes out the other side of the radiator or core.This is done repeatedly through all the tubes in the radiator.  The purpose is to try and free up or unclog the radiator.  This will result in a better flow of coolant once the radiator is assembled again. (definition from [url http://www.radiatorinfo.com/glossary.html[/url]
2. Change the thermostat to a 180 degree Robert Shaw Generation 2.
3. During the Summer run 60/40 Water to Anti Freeze along with 2 bottles of Redline Water Wetter. Some run more like 80/20 Water to Anti Freeze, just make sure you have anti freeze as it is an anti corrosive. Distilled water is a good idea instead of tap water because tap water build mineral deposits, etc. more quickly.
3. Make sure both fans are running, you shouldn't be able to see the individual fan blades while they are turning, they should be spinning like crazy! You can also wire the primary and secondary fans to the 180 degree thermosensor under the primary fan. Both fans come on at 180 instead of waiting until 210 degrees for both to come on.
4. Check the primary catalytic convertor for clogging, if your convertors are clogged they will choke the turbo and cause the car to run hotter, not to mention kill your turbo. Do your car a favor and hollow them out or at least get new hi flow convertors if you are worried about emissions.
5. Replace any swelling hoses.
6. Get a new radiator cap (often overlooked)
Insta=extexascoach
Posted Image Posted Image
89 TSi 14G, 2.5"Ex,21lb.Flyw, Sht.Shift, SS Hoses,1G MAS/K&N,
125psi F.Pump, Type-H BOV /H-Pipes, 9" Rears, ST's, KYB's.
2016 Escalade Platinum Edition
2014 Silverado
#2 da_drgn
da_drgn
  • 725 posts
  • Interests:TRUE DRAGON
Posted 14 June 2002 - 04:20 PM
kool info KO,
    how is your red Quest running since you set the fan on to the engine,
is it cooling good?
It's like a finger pointing to the moon...
Don't concetrate on the finger or you will miss All That Heavenly Glory...   BRUCE LEE  6/20/73
#3 cdatt
cdatt
  • 237 posts
  • Interests:Meaner, Lower, Faster!!!
Posted 01 August 2002 - 04:39 PM
Where do you get water wetter ?
And where can I get the new high flow cat.
cdatt
#4 Ryan_V
Ryan_V
  • 3,911 posts
  • Interests:Art, Music, Starquests
Posted 10 August 2002 - 10:46 AM
If you haven't found water wetter yet. You need to go to any speed shop
in town. There are even better alternatives that the BIG dogs use.
Cost will be and shouldnt exceed 9.00 max
Big dog stuff is around 23.00
Good luck, if you do what KOs' post says ur golden!
#5 Distorted.Clarity
Distorted.Clarity
  • 5,541 posts
  • Interests:*shrugs* what ever.
Posted 12 August 2002 - 12:59 PM
i use "40 below" for my transmision fluid, brake fluid, and radiator fluid
the car runs so much cooler and better.
i would recommend using this
Conquest Parts Manual Download
Conquest Service Manual Download
A little inaccuracy sometimes saves a ton of explanation.
#6 travs87tsi
travs87tsi
    learning everyday
  • 1,185 posts
Posted 12 August 2002 - 02:44 PM
i looked at 40 below at advance auto it was like 25.00 isnt that kinda high?
#7 Distorted.Clarity
Distorted.Clarity
  • 5,541 posts
Posted 01 September 2002 - 08:09 PM
yea i thought so to.
at first i was very skeptical but then tried it just to see if it would work and it did.
so as soon as my car is back from the shop im putting in the 40bellow into it again after i flush my system.
also going to buy the same for my breaks, and power steering.
the solutions for breaks and steering are susposed to stop minor leaks as well so theres another goodie.
but i would recommend it to anyone and will from now on keep on using it.
try it out, 25 bucks isent all that expensive for how well it cools i think
#8 Distorted.Clarity
Distorted.Clarity
  • 5,541 posts
Posted 10 September 2002 - 08:27 AM
Any one try there products *40 below* and notice a change?
#9 Rayman4449
Rayman4449
  • 365 posts
  • Interests:1987 Conquest
Posted 21 September 2002 - 07:16 AM
Yes.  Both my brother and I put the 40 below in and it runs much cooler now!  I will always make sure that I keep this stuff in there from now on.  Autozone sells the stuff for $20 in my area.
Raymond
Raymond
1987 Conquest
#10 tsiman
tsiman
  • 48 posts
Posted 08 October 2002 - 05:32 AM
How much 40 below do you put in.  And what all can you put it in??  Thanks
#11 Distorted.Clarity
Distorted.Clarity
  • 5,541 posts
Posted 08 October 2002 - 01:40 PM
im pretty sure the brand 40 below is only for the rad.
but then you can get other ones that are like 28 below for your breaks, transmission, and power steering... might have it for the oil but not sure.
i do belive the directions for how to add it to each are on the bottles.
#12 GodSpeed
GodSpeed
  • 15 posts
  • Interests:One Bitchin  'Bishi
Posted 07 November 2002 - 08:02 PM
I put 40 below in my oil and it actually made the car run cooler.. I was amazed at the difference.. its getting cold here so i am not going to put it in the rad yet but i am impressed with their product so far.. and i figure cooler oil can only help!!
#13 jeff
jeff
  • 210 posts
  • Interests:THEBEATINGSWILL CONTINUEUNTILMO RALITYIMPROVES
Posted 17 November 2002 - 10:47 PM
here is one for ya. i put a aditional heater core in my nissan turbo car. it is between the inlet at the firewall for the heater and the engine. i put a little crossover on so it bypasses in the winter so the heater get hot quick. put the heater core in a little cage down bt the subframe so it gets some air.
will try it in my starion soon as i get a suitable heater core
Jeff
#14 Distorted.Clarity
Distorted.Clarity
  • 5,541 posts
Posted 16 December 2002 - 10:44 AM
ok well a while back i gutted my pre-cat and also gutted the whole back of my car from behind the drivers seat back... having a hell of a time staying warm in my car lol... since the precat is gutted even on hot days my car dosent warm up to much... would be great if i was in FL or TX...
#15 IceMan8247
IceMan8247
  • 76 posts
  • Interests:Smoke Fools
Posted 21 January 2003 - 05:12 PM
I got a mechanical fan and shroud for a montero, and it keeps my engine running cooler than ever.  It pulls an insane amount of air thru the front of the radiator...more than I ever thought.  Its also got a real mean sound at high rpm; a great upgrade to never worry about overheating again.
-MoJ
#16 svo
svo
  • 341 posts
Posted 23 January 2003 - 01:48 AM
a few years ago I had a friend put replace my radiator core with a 3 row...I never get beyond 1/2 way on the meter.  One the high way it runs a 1/4 or below.
#17 Tom
Tom
  • 1,394 posts
Posted 14 February 2003 - 08:15 PM
i got great results with the robert shaw 180 thermostat and a clutch fan and shroud from an older quest.i have an 88 tsi and now it never reaches the midpoint.
#18 cdatt
cdatt
  • 237 posts
Posted 10 March 2003 - 06:36 PM
t
#19 Starion_88
Starion_88
  • 1,152 posts
  • Interests:"That could have sucked"
Posted 12 March 2003 - 12:54 PM
where can I get a 180 therm.? ???
#20 Tom87tsi
Tom87tsi
  • 24 posts
Posted 12 March 2003 - 02:00 PM
I just got a robert shaw Gen 2 180 thermostat this past weekend at Autozone - $6.  Also got 2 thermoswitches at 190 degree for $16 ea. (as previous posts have recommended).
Tom
