station Posted October 13, 2014 Report Share Posted October 13, 2014 I'm wanting to swap the fuel pump for a Bosch 044 type, and want to know which terminals/connectors I'll need?I'm connecting to the immediate fuel pipe (to the fuel filter/engine) using a barb connector that should screw onto the 044 fuel pump. I have no idea on sizes so not sure which one to get. I removed the old one as it seized, but I got it running. It needs a tap when it's left for a while, so it needs replacing. The damper on the end is shot (but somehow manages to not leak yet): Unions were blowing fuel out as soon as the fuel system was pressurised, so I need to do it properly and safely: It's not possible to avoid corrosion and rust in the UK, we are constantly getting battered by all weathers and they grit the roads with rocksalt in the winter. I read ProfessorQuest's threads about 'CORROSION' and laugh. Must be nice living in the desert. My tank was full of orange and gloop. All the wire hooks were dissolved, all bolts seized. It has had an acid bath inside, but the outside is hopeless until I can find a decent replacement. Link to comment Share on other sites More sharing options...
markhansenconquest Posted October 13, 2014 Report Share Posted October 13, 2014 (edited) Got gas tank ,,filler neck,,pick up tube and fuel sending unit for sale...calif car..will send u a PM with my number...where are u in UK ??? Edited October 13, 2014 by markhansenconquest Link to comment Share on other sites More sharing options...
station Posted October 13, 2014 Author Report Share Posted October 13, 2014 I'm on 'The Wirral', which is about 5 miles from Liverpool.I'd seriously consider paying for a 100% rust free tank. Link to comment Share on other sites More sharing options...
ucw458 Posted October 13, 2014 Report Share Posted October 13, 2014 Just use a hose barb on the pump and 1 foot of 8mm fuel injection hose. Slip the hose over the hardline and use a good hose clamp. Are you planning on modding the crap out of your car? A bosch 044 is about 3x bigger than a TBI car needs. It will work but it's a bit overkill. TBI has 1700cc worth of injector. An 044 will support over 5000cc worth. Link to comment Share on other sites More sharing options...
markhansenconquest Posted October 13, 2014 Report Share Posted October 13, 2014 got one from my dads garage kept car (RIP)....tank neck,,pick up tube,,sending unit ...post reply here....will check back later...tank is clean.........call me it easer.sent u my number.... Link to comment Share on other sites More sharing options...
StarquestRescue Posted October 13, 2014 Report Share Posted October 13, 2014 You can get the metric hose barb fittings from Matt Lewis Racing in the UK. Inlet http://www.ebay.com/itm/BOSCH-044-FUEL-PUMP-INLET-FITTING-UNION-FOR-12MM-ID-HOSE-PIPE-ZH-/121394122864?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c43a75070&vxp=mtr I do not see a listing for the metric outlet barb. But they can probably fix you up with something. http://stores.ebay.com/Matt-Lewis-Racing/Fuel-system-injection-/_i.html?rt=nc&_fsub=7499950&_sid=112452222&_trksid=p4634.c0.m14.l1513&_pgn=4 You can get the out let barb from Taiwan. Or use a metric to 6an, and then get a 6 an hose barb. But the 5/16 / 8 mm fuel line you need will not go on a 6an push lock barb very well. You want some thing like this. http://www.jegs.com/i/JEGS+Performance+Products/555/100845/10002/-1 Cheeper and easier to get a walbro gsl392. At least here in the States. Here is a reliable vender. http://stores.ebay.com/Matt-Lewis-Racing/Fuel-system-injection-/_i.html?rt=nc&_fsub=7499950&_sid=112452222&_trksid=p4634.c0.m14.l1513&_pgn=4 Link to comment Share on other sites More sharing options...
station Posted October 14, 2014 Author Report Share Posted October 14, 2014 Thanks for the help!I'm just going to get a Walbro pump (like the one listed above) and get a duplicate copy of the Starion fuel line up to the screw on connector just in front of the rear bulkhead.Final question - what is the size of the screw in connector? Hopefully I can get it off (they're meant to be quite tight aren't they). Link to comment Share on other sites More sharing options...
