polarisman14 Posted October 3, 2015 Report Share Posted October 3, 2015 Hey guys, Looking for a little advice on WUE settings. I know it will vary by car and setup but I mean generally speaking--not what the curve looks like but what all your other constants are set to. My current WUE is all screwed up and I plan on using the analyzer to fix that anyway but still want your $.02 for ha-ha's. Once the car is up to temp it idles fantastic so I know it's tune related rather than hardware. Link to comment Share on other sites More sharing options...
scott87star Posted October 3, 2015 Report Share Posted October 3, 2015 All you are trying to do with WUE is start with a richer AFR cold and gradually lean it out as coolant temp rises to your desired warm idle AFR. For 90% of Starquests that would be an AFR of 12 at coolant temps under 100 F ramping up to 13-13.5 at 175 F and higher. I've found the auto tune for this to be less than satisfactory. Link to comment Share on other sites More sharing options...
polarisman14 Posted October 3, 2015 Author Report Share Posted October 3, 2015 Yeah for whatever reason my car appears happiest idling around 12.7:1 when warm. I gotta look around a bit and see when ASE falls off and WUE takes over, I would imagine it switches from one to the other as a function of how long it's been since the car started coupled with the coolant temp. Definitely getting somewhere with it now though, the car seems a lot happier at warm idle. Thank you Scott. Link to comment Share on other sites More sharing options...
polarisman14 Posted October 4, 2015 Author Report Share Posted October 4, 2015 (edited) Here is a follow up question to this--Since richer AFRs lower rpm speed compared to leaner ones, how do you compensate for this? My car is idling at ~900rpm when warm, if it goes too much lower (below 750-800) it won't idle and will just stall. Does cold advance adjustment have an affect on that? I am not running an IAC or fast idle valve right now and ideally I would like to make it so that I can limit the amount of time I have to keep my foot on the gas after starting the car to keep it running when it's chilly out. The coldest temps I start the car in are around the freezing mark or a few degrees below that on late fall days. Car comes off the road when it starts snowing. I have WUE pretty well dialed in now where I only have to keep my foot on the gas at 1200-1500rpm for 8-10 seconds after initial start and I can let my foot off after that and let the car do its thing. I think I can get it a bit better than that but I don't know how good I can expect it to perform when it's programmed correctly--Meaning, if it's set up perfect, will I still have to race the idle a little for 5 seconds to idle smoothly after? Edited October 4, 2015 by polarisman14 Link to comment Share on other sites More sharing options...
StarquestRescue Posted October 4, 2015 Report Share Posted October 4, 2015 I use right foot high idle control for as long as needed. Freezing weather upwards of 5 minutes till I can take my foot of the peddle. You could add a lower rpm bin to try and compensate for the afr going out off whack below 900. Link to comment Share on other sites More sharing options...
polarisman14 Posted October 5, 2015 Author Report Share Posted October 5, 2015 I will probably end up compensating by just turning the idle set screw up a half-turn, that'll give me another 50rpm of idle or so once all is said and done. I just want to get everything as close as possible so that I won't have to hold my foot on the gas for that long. When I started it yesterday it was about 54 degrees coolant temp and like I said that only required input from me for 10 seconds just above idle speed to keep it running. Given that the car is coming off the road in a month it isn't gonna get more than 20 degrees cooler than it is now for cold starts so there isn't too much work left. Sounds like I just need a fast idle valve to do that work for me for 10 seconds and I won't even have to touch the pedal. Until that happens, though, I'll have to get better at tuning instead . Link to comment Share on other sites More sharing options...
Funky Phil Posted October 5, 2015 Report Share Posted October 5, 2015 I use a lower ve bin (as sqr stated) and more ignition advance. I sometimes just have to blip the gas when its cold. Other wise, prime and light. 8-1000rpm warm idle Link to comment Share on other sites More sharing options...
polarisman14 Posted October 5, 2015 Author Report Share Posted October 5, 2015 Gotcha. I'll spend a little more time with the fuel side of things and get it to where I'd be happy with it if I just left it alone, then I'll try a couple adjustments with cold advance. I have some already worked into the tune but I can always add a bit more. Thanks! Link to comment Share on other sites More sharing options...
