Windsheild Removal D.I.Y.
14 replies to this topic
#1 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 21 November 2013 - 05:14 PM
Done this four times now and only cracked one :)
Step 1 carefully feed the wire through the sealer and try to get under the glass. You don't want to dig into the
glass.
Feed a 1/4 inch or smaller at a time so it doesn't fold up and kink the wire...now you have this...
Use a sawing action (having an assistant helps) being careful not to get too close the glass like so...
I used vise grips. A wooden handle is better because when a vise grips falls out of your hand things break
Use some lube it helps a lot for cutting and lets that wire slide smooth if it contact the windshield which it will
45 MINUTES and here it is. Today was 9 degrees this morning and  very cold but I was still able to get it out (a warm day is recommended and far easier)
New home safe and sound.
Be carefull with the top and bottom lip and pinch weld area. This is where you want to loop your wire and pull from the
inside along the plane of the windshield...
These corners will try to catch your wire...
Here I got going to hard and cut into the metal
Here is the bottom seal surface. Its pretty wide. If you puncture it twice and then get in the car and grab the two ends and pulled up along the plane of the windshield it works best.
Edited by JohnnyWadd, 22 November 2013 - 08:04 PM.
#2 Burton
Burton
    Addicted Starquester
  • 11,811 posts
  • Interests:Hold up wait a minute let me put some pimpin in it
Posted 21 November 2013 - 05:27 PM
45 minutes? Slowpoke ;) They make kits for this that are actually quite reasonable... a length of braided wire (the roughness of the wire helps saw thru the sealer), a tool to feed the wire thru the sealer, and wooden handles with tight connections to hold the wires. All for $10-15 shipped. I used to use just standard wire wrapped around 8" sections of a broom handle, but that braided stuff really cuts thru the sealer fast.
Good writeup!
Mark
88 Starion
87 TSI Custom (wife's)
85.5 Starion
98 Mercedes-Benz S420
11 Kia Surento(wife's)
93 Nissan 300ZX 'Vert
http://www.26liter.us/
21 chapter online Body/Paint/Detailing manual
Best SQ virtual GARAGE on the net
Stuff to make your SQ look cool!
Burtonscustoms.com
#3 SOTTY
SOTTY
  • 6,466 posts
  • Interests:Az gotz da cotton mouff
Posted 21 November 2013 - 05:47 PM
Agreed ^^  useful write up , needs to be a faq , good job. :)
#4 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 21 November 2013 - 05:57 PM
Good writeup!
Ya I know I am slow but better slow and no bloody knuckles. Last one I did was in the summer we had it cut in maybe ten minutes. Add in the coffee break maybe I pulled it in 38 minutes so there LOL
Used this. Its the braided stuff like you mentioned and has a coating too seems to be slippery.
http://www.toolsourc...dium/115278.jpg
Edited by JohnnyWadd, 21 November 2013 - 06:08 PM.
#5 Burton
Burton
  • 11,811 posts
Posted 21 November 2013 - 06:16 PM
I may get some of that stuff after the wire I have is gone. It cuts good, but will break 2-3 times per windshield.
Mark
88 Starion
85.5 Starion
Burtonscustoms.com
#6 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 21 November 2013 - 09:27 PM
a set of guitar strings goes for like $5
warm day is good  but not a 100f  day , soft sealer will reseal it's self almost as  fast as you loosen it :)
88TSI Silver
89TSI red auto
#7 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 22 November 2013 - 02:57 AM
That stuff on the door panel or in the taillight maybe but the windshield glue is not like that. Its more temperature stable. It has to be. Last one I did was in august in Eugene Oregon it was 90 plus that day. That's why it sliced it so
quick too. It doesn't seem to melt back together at all. Its like an inner tune , the rubber is already vulcanized and itjust turns to powder where the saw rope cuts it. Like sawdust but rubber dust LOL.
Yes it definitely does break. Especially on doing a starquest because you are forcing it to grind metal when you pull at
an angle away from the glass.
Edited by JohnnyWadd, 22 November 2013 - 03:05 AM.
#8 vbrad511
vbrad511
  • 8,207 posts
Posted 22 November 2013 - 08:34 AM
I've used guitar strings plenty of times, but only after I've cut as much of the seal as possible with a snap off knife. I've cracked a few with just the strings. Does the actual windshield wire cut better/faster/easier than a guitar string does?
#9 questsale
questsale
  • 804 posts
Posted 22 November 2013 - 03:53 PM
Does the dashboard have to be removed at all? How much more work if its still in place?
#10 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 22 November 2013 - 04:00 PM
I think this stuff is a little better because its weaker and has a coating. I have seen where its gets to digging in the windshield and I know guitar string is more aggressive.
Good question. I Think you are just looking at more work with the dash in. The steel lip makes you go at a weird angle on the inner side
anyway.
#11 questsale
questsale
  • 804 posts
Posted 22 November 2013 - 06:10 PM
If I take my car to a shop to replace the windshield, what will they do? Obviously they are not gonna remove the dash.
#12 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 22 November 2013 - 06:49 PM
They have a special knife that is powered by air pressure it oscillates super fast and cuts the seal. And if they are removing an old windshield they don't car about if it might break it.
Questsale, look at some youtube videos and checkout the angles. This is why pulling the dash is not a big deal, on the inside of the car. To clear the lip and pinch weld you are pulling the saw wire a certain way.
Edited by JohnnyWadd, 22 November 2013 - 07:01 PM.
#13 Shelby
Shelby
    Rookie
  • 50,164 posts
Posted 22 November 2013 - 09:20 PM
Johnny do you want me to place this in the FAQ if so what part
88TSI Silver
89TSI red auto
#14 19cturbo
19cturbo
  • 6,623 posts
  • Interests:cars
Posted 22 November 2013 - 09:40 PM
ive always heard to use guitar string..
View PostConvette, on 21 February 2016 - 11:51 AM, said:
#15 slydogg
slydogg
  • 2,969 posts
  • Interests:Boost!
Posted 23 November 2013 - 10:57 AM
piano wire.
