A/C delete how-to without removing the dashboard
*BEFORE REMOVING ANY COMPONENTS DISCHARGE THE A/C SYSTEM*
Start by removing the lower dash panel and glove-box assembly retainer screws from the cross bar.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1128_zps4e204e01.jpg
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1127_zps942b2091.jpg
Then remove the passenger side inner kick panel for better access.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1126_zps744c26dc.jpg
After loosening the crossbar nuts on both sides and positioning it up for clearance, remove the clips securing the evaporator box halves together as well as the metal straps holding the evaporator unit to both the heater core box and blower motor housing.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1089.jpg
Now seperate the two box halves. You'll have to be a little persuasive since they've been in there for 20+ years.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1092.jpg
After removing the bottom section, pull out the evaporator assembly. It may be easier to go ahead and unbolt the upper box section from the firewall for better access. *NOTICE* there are electrical connectors screwed into the upper box. Unscrew and remove the retaining tabs holding the connectors in place.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1110.jpg
Notice the vacuum lines and solenoids pictured. Make a note where they go for re-assembly. NOTE this is a good time to remove the evaporator drain hose going to the floorboard under the carpet.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1114.jpg
Here are the electrical components you will need to re-install:
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1121_zpsa8669148.jpg
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1123_zpsa6ce51f8.jpg
Now is a good time to install the firewall plug.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1117_zps484a1637.jpg
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1116_zpsdf35968d.jpg
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1119_zpsbb51e3ce.jpg
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1118_zpsde093e77.jpg
NOTE the hole next to the plug would be perfect for a wideband a/f meter or something similar.
Now install the a/c delete duct
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1122_zpse25ae349.jpg
After the delete duct is installed, position the solenoids and electrical switches out of the way for the glove box assembly using zipties or equivalent.
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1124_zps3afc49d6.jpg
Now re-install the glovebox and lower panel. Clean up debris and your ready to roll! :)
http://i614.photobucket.com/albums/tt230/gguy84/DSCN1129_zps8136fa1a.jpg
Edited by TexasQuest
  • Like 1
  • 3 weeks later...
  • 3 months later...
