Starion light bulb type chart
Handy for LED swaps
14 replies to this topic
#1 Fuze
Fuze
    AKA @Battlemagnet
  • 2,779 posts
  • Interests:Chess Boxing
Posted 28 August 2011 - 09:02 AM
UPDATED 7/23/12
Reference Chart for the lighting in a Starion: Mostly based on 89 Mitsu Starion Manual, plus other sources. Some bulbs have multiple names/codes.
Mitsubishi Starion Car Light Bulb Size Chart
Headlamp Bulb Size: H6054, or convert to H4
Parking Light Bulb Size: 168 , 906
Fog Light Bulb Size: Type 35 dual post, G4, or H3 style
Front Turn Signal Light Bulb Size: 1156
Rear Turn Signal Light Bulb Size: 1157
Tail Light Bulb Size: 1157
Third Brake Light: 921
Stop Light Bulb Size: 1157
License Plate Light Bulb Size: 67
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 194
Rear Side Marker Light Bulb Size: 67
Ash Tray Light Bulb Size: 74
Glove Box Light Bulb Size: 158
Door Lights: 27mm Festoon bulb
Dome Light: 27mm Festoon Bulb
Instrument-General Light Bulb Size: 194 or 74
Brake Warning Light Bulb Size: 74
Edited by Fuze, 23 July 2012 - 01:42 PM.
Insta = @battlemagnet
#2 NotStock88
NotStock88
  • 4,529 posts
Posted 28 August 2011 - 09:23 AM
vote sticky
NOOB
#3 gerwulf
gerwulf
  • 378 posts
Posted 28 August 2011 - 09:38 AM
yes, this would have been helpfull a few days earlier, vote sticky
View PostBrazilBoy, on 15 September 2011 - 11:48 AM, said:
I use the blood of honda ricer punks my conquest destroys..
View PostLance_S, on 14 October 2011 - 04:10 PM, said:
I can die now....I have officially seen it all.  Bacon roses! :D
#4 apate
apate
  • 336 posts
Posted 14 December 2011 - 11:32 AM
What about the fog bulbs?
#5 Killtodie
Killtodie
    KTD
  • -219,298 posts
Posted 14 December 2011 - 11:36 AM
what's the difference between a 168 and 194?
and what kind if bulb is the left and right map light?
Edited by Killtodie, 16 December 2011 - 10:20 PM.
#6 kev
kev
    Moderator
  • 5,030 posts
Posted 23 July 2012 - 05:48 AM
driving lights (next to fogs) are 906
fogs use an H3 bulb
door courtesy lights are 27mm festoon bulbs
dome is 27mm festoon as well
third brake light is 921
#7 Ironside
Ironside
  • 1,912 posts
  • Interests:Hummmm Conquests ,Starions , Dodge diesels welding and life....
Posted 23 July 2012 - 05:52 AM
View PostNotStock88, on 28 August 2011 - 09:23 AM, said:
vote sticky
+1
87 White 5-Speed Starion.Gen 2 maft, 3" lt1 mass,rebuilt motor, ss valves, schnider springs, roller rockers new head from Dad, stage 3 clutch, tdo6 18g
88 White 5-Speed Starion, parts car.
89 Red Automatic Conquest TSI, on the road running. Getting ready for paint. All stock.
#8 kev
kev
    Moderator
  • 5,030 posts
Posted 23 July 2012 - 05:54 AM
It is already a sticky...and is carbon copied over in the FAQ section.
kev
#9 Komeuppance
Komeuppance
    Amused.
  • 13,590 posts
Posted 23 July 2012 - 12:51 PM
Vote sticky.
-Robert
#10 Fuze
Fuze
    AKA @Battlemagnet
  • 2,779 posts
Posted 23 July 2012 - 01:37 PM
fogs use an H3 bulb
Thanks, updated the original post.
#11 The Rabbit1
The Rabbit1
  • 2,943 posts
Posted 28 July 2012 - 08:13 PM
a115 is what I found
Replaced: vac advance, Delphi injectors, all vac lines, tees and check valves, all brake hoses and pads, Master cylinder, flex plate, torque convertor, T-stat(180), CTS, TPS, both fan switches to primary, rear speakers, door speakers
Overhauled: Distributor, TB, wiper system, electrical ground connections, dash switches, auto seat belt tracks, entire auto trans, entire fuel system, A/C system
Upgraded: 1st gen Mas, HKS bov, Walbro 255lph pump, S16G Turbo and increased boost to 15psi, Aeromotive rrfpr 13105, MSD 8910 Tach adapter, Comp Cams Fireball digital ignition system, 35 watt HID headlights (6000k) 1000w 4ch amp, 100A alternator, engine to chassis to battery ground (4ga), charging wire from Alt to Batt (6ga), 2.5" Catalytic converter, Magnaflow muffler, R134 A/C, Yellow top optima battery
Added: AEM wideband, rail mounted fuel pressure gauge, dual alternator fusible links
Eliminated: Cruise, ABS, Emissions, Vac pump
#12 TexasQuest
  • 9,002 posts
Posted 29 July 2012 - 03:34 PM
I tried replacing my rear cargo hatch bulb with a 27mm festoon but it was too big? Anyone know what size it is?
88 Fiji Blue -TSi
#13 The Rabbit1
The Rabbit1
  • 2,943 posts
Posted 29 July 2012 - 06:46 PM
didn't know there was one back there, will get on it.
#14 M Code
M Code
  • 352 posts
Posted 02 August 2012 - 09:27 PM
You left out the minature bulbs (4) behind the Temperature Control panel..
Just my $0.02...  ;)
#15 NikoFab
NikoFab
    Go Blue Fan
  • 9,937 posts
Posted 20 August 2012 - 09:48 PM
Great resource Fuze...thanks
