85 Conquest Technica Parts
Technica
19 replies to this topic
#1 cam2363
cam2363
  • 15 posts
Posted 05 July 2018 - 04:27 PM
All parts are from a 1985 Chrysler Conquest Turbo with a silver exterior and a maroon interior that has sat in a junkyard for 15 or 20 years. Most interior parts are destroyed and moldy, but some are still ok. Many exterior trim and parts are still fine. If anyone needs a specific part, I can get it and we can work out a deal. Parts gone are everything listed here, the trunk lock, the TURBO door handles and the upper windshield trim. The glass in both headlights is smashed and the windshield has a large crack in it, so those parts are no good. It has all 4 (correct me if I'm wrong with the term) Double cowbell rims which seem to be in good shape.
Pm me or email me at cwshoudt@gmail.com. I respond faster to email
All prices are negotiable, if I'm way off on pricing please tell me, and I will adjust accordingly
Also, you pay for shipping. You can also pick them up, I live in Allentown.
All Images can be found here https://imgur.com/a/MhkKLLq
In order of what they are
Technica Digital Gauge Cluster $90
Cluster lights up and works fine
All burnt out bulbs replaced
Glass and graphics are separating in some spots
I have been able to make the speedo change but nothing else
A/C controls $70
The ac controls work fine
1 or 2 of the bulbs are burnt out
The plastic is broken and the metal on the computer is bent and corroded
The buttons are worn
The speaker works sometimes
The lights on the main display don't turn on, I took the unit apart, made them work and then they didn't work when I put it back together, so it needs to be fixed but I think it could just be a loose connection
Talking TAC Unit $65
The TAC unit works perfectly fine and I have been able to make it say all of its phrases, and play the music. I have videos of it. If you want to see, PM me.
Maroon Manual TURBO Seatbelts $50 each $85 for both
Seatbelts work fine, the plastic trim is faded otherwise in good condition
Clock $10
Just the clock, works fine, bulb replaced.
Light Switches $15 each
The screw pegs on the back are broken, so would need to be glued, otherwise, buttons are in good condition
Hazard and signal relays $7 each $10 for both
Both work
OD relay $10
Unsure if it works, but I don't see how it could break
Antenna relay (I think) $10
Unsure if it works, don't see why it wouldn't
Key reminder Switch $7
ECM $20
ECM is in pretty rough shape on the outside
No clue if it works, but inside is clean despite the outside
Missing a transistor which I desoldered to fix TAC Unit, transistor value and orientation is labeled on board right next to where it was removed from
If you want more detailed pictures or have any questions, please message me and ill take care of it
Edited by cam2363, 03 April 2019 - 01:39 PM.
#2 87redcat
87redcat
    10 years and counting...
  • 3,910 posts
Posted 05 July 2018 - 04:37 PM
PMd you
#3 bflann
bflann
  • 269 posts
Posted 05 July 2018 - 06:40 PM
I'll take the talking tac unit, need PayPal info
#4 mrvwbug
mrvwbug
    SQC Veteran Member
  • 721 posts
  • Interests:Keep the turbo spooled! Flattys before Fattys! I don't need the extra weight.
Posted 08 July 2018 - 11:54 AM
I need a sensor switch or relay part number MD082804
#5 Paul87Quest
Paul87Quest
  • 72 posts
Posted 08 July 2018 - 11:55 AM
I am interested in the gauge cluster and other parts.  Please PM me if the messenger is working -I believe it is down right now, alternatively email me at pandre@portla.og.
Thanks! Paul
Edited by Paul87Quest, 08 July 2018 - 01:30 PM.
#6 BuGG
BuGG
  • 1,963 posts
Posted 08 July 2018 - 04:47 PM
Ill respond to your PM (cam) when "Personal Messenger" is back up.
#7 bflann
bflann
  • 269 posts
Posted 08 July 2018 - 07:43 PM
Can u text me your paypal address, 9043710716, can't get it from messenger
#8 cam2363
cam2363
  • 15 posts
Posted 08 July 2018 - 09:18 PM
Ok You can also email me at cwshoudt@gmail.com
#9 cam2363
cam2363
  • 15 posts
Posted 08 July 2018 - 09:21 PM
Ok. Hopefully soon I will be able to go back and really strip out the car. Ill get back to you when that happens
#10 cam2363
cam2363
  • 15 posts
Posted 03 April 2019 - 01:38 PM
Just an update to everyone who wanted parts. The junkyard is getting cleaned out, and this car is buried, so its slowly being worked to, but it should be out soon, and I can then start getting the parts. Sorry for the delays.
If anyone needs anything else, let me know. I plan to strip most of the car, getting all of the smaller stuff and some of the larger stuff if it is in good shape.
#11 delayed replay
delayed replay
  • 174 posts
Posted 04 April 2019 - 05:39 AM
Following
Edited by delayed replay, 05 April 2019 - 06:20 AM.
#12 prototype78
prototype78
  • 1,009 posts
Posted 04 April 2019 - 03:50 PM
Do you have thr techica badges...if so how much shipped to 11706
#13 cam2363
cam2363
  • 15 posts
Posted 11 April 2019 - 09:49 AM
Not sure, will check when I can see the car again
#14 prototype78
prototype78
  • 1,009 posts
Posted 12 April 2019 - 05:41 PM
Sounds good thanks...if you do text me at 786 312 3626
#15 cam2363
cam2363
  • 15 posts
Posted 17 April 2019 - 12:14 PM
Scratch that. Apparently some guy bought it, so I cant get anything off of it.
#16 prototype78
prototype78
  • 1,009 posts
Posted 27 May 2019 - 08:13 AM
Hey buddy, do you have door panels?.. txt me or send me pic at 786 312 3626
#17 Conquest 1988
Conquest 1988
  • 208 posts
Posted 05 June 2019 - 03:33 PM
Iím looking for a Isc servo  Assyrian how the conditions How much would hope to hear from you soon
#18 markhansenconquest
markhansenconquest
  • 3,432 posts
Posted 05 June 2019 - 10:07 PM
^^^^^^^^  Conquest 1988 u need a 87-89 one... 86 and down are a different system............1 plug on 87-89 and 2 plugs on 86 and down to 84...................if U have the wrong year u will have 1 extra plug on wiring harness or on ISC motor................
make sure u have the right year for your car ........IMO
Edited by markhansenconquest, 05 June 2019 - 10:27 PM.
#19 4cylFury
4cylFury
  • 1,286 posts
  • Interests:Praising God, My son, and racing
Posted 07 June 2019 - 06:44 AM
Need the boost sensor.
87 Quest, Gato MPI, Gato Header, 6766Turbo, 2200cc injectors, E85, FAST ECU, 422 gears, Stock Non Jet Valve Head with no work done to it, Custom Cam, 3" hard pipes, Custum Powerglade tranny and much more.
Fury track time = 5.9 in the 1/8 mile
                  9.5 in the 1/4 mile
#20 mrvwbug
mrvwbug
    SQC Veteran Member
  • 721 posts
Posted 20 June 2019 - 07:56 AM
I need the radio console bezel.  Looking for something on the minty side.  Please let me know?  Thanks Jim
