Bill Hincher Posted October 15, 2008 Report Share Posted October 15, 2008 (edited) these bellhousings are for narrow block 4G63's I always strive to improve my bellhousings, this is an early casting I built that I cut up to find and improve on my original work, I test and design all my own stuff http://www.billsautofab.com/images/W55redsign2.jpg I cut it down to find critical thickness values and thinned it down to loose excessive wieght http://www.billsautofab.com/images/W55redesin3.jpg Then I re shaped it to include extra outside gussets and a upper heat vent http://www.billsautofab.com/images/W55redesign7.jpg then the final shape was put into it for desired strength and draft for casting purposes http://www.billsautofab.com/images/W55redesign12.jpg The final pattern is sent out for casting http://www.billsautofab.com/images/W55finished3.jpg and these are raw castings http://www.billsautofab.com/images/W55rebuilt4.jpg then the final products are machined and test fitted one at a time http://www.billsautofab.com/images/W55rebuilt.jpg you can see how its assembled at http://www.youtube.com/watch?v=QvjLuQP8V0A Edited October 15, 2008 by Bill Hincher Link to comment Share on other sites More sharing options...
Technology Posted October 15, 2008 Report Share Posted October 15, 2008 Awesome. Is this your full time job or a hobby? Just wondering if you make a profit from these (which you should, I just hope they are worth your time because eventually I might buy something from you). Link to comment Share on other sites More sharing options...
Bill Hincher Posted October 15, 2008 Author Report Share Posted October 15, 2008 I got turned down for a job at the post office because I didnt have a concealed weapons permit so I thought I would build some bellhousings Link to comment Share on other sites More sharing options...
Bill Hincher Posted January 26, 2010 Author Report Share Posted January 26, 2010 I took the last w series bellhousing and put it on a diet I thinned the walls and expanded the rear facing, I included the EVO 4/9 bolt pattern along with the first and second gen narrow block and placed the bolt pattern for the pre 96 R 150 and 150 trans as well as the original W 55/59 transmission , while I was at it I moved the starter bolts in a way that it will accept either the FWD flywheel or the AWD flywheelhttp://www.billsautofab.com/images/WRseiesbellhousing1.jpghttp://www.billsautofab.com/images/WRseiesbellhousing2.jpghttp://www.billsautofab.com/images/WRseiesbellhousing3.jpg Link to comment Share on other sites More sharing options...
thagremlin Posted March 29, 2010 Report Share Posted March 29, 2010 How much do you sell these for. Are there any mods I would need to do to the tranny tunnel to fit this trans? With this adapter I can just buy any 6bolt 4g63 and bolt up the tranny with out having to Frankenstein a motor together. Link to comment Share on other sites More sharing options...
Bill Hincher Posted April 3, 2010 Author Report Share Posted April 3, 2010 (edited) the W series sells for under $300.00 bucks, comes with the slave cylinder and pilot bearing spacer, I also include a video of how it gets installed It fits either the first or second gen 4G63 with six or 7 bolt cranks and FWD or AWD flywheel depending on how you order it This housing will include the EVO 4 through 9 bolt pattern but it will use the AWD 7 bolt flywheel from the second gen 4G63 and a push style clutch Edited April 3, 2010 by Bill Hincher Link to comment Share on other sites More sharing options...
