Front Wheel Bearing
11 replies to this topic
#1 Contsis
Contsis
  • 193 posts
Posted 17 September 2018 - 02:39 PM
87 Quest -
Went for safety inspection and they found a slight up/down play on the right front wheel.
They didn't fail me but said it could be the wheel bearing since there is no upper ball joint.
Went home and tried it and confirmed, I can even feel and hear a clunk - left side is solid.
Any tip for confirming that it is the bearing?
Thanks
#2 87redcat
87redcat
    10 years and counting...
  • 3,749 posts
Posted 17 September 2018 - 02:57 PM
Easiest way is to pull the wheel and tire off, remove the brake caliper, and yank on the rotor. If it moves and clicks pull it off and visually inspect the bearings. They are not that exspensive to replace.
#3 TexasQuest
  • 8,681 posts
Posted 17 September 2018 - 06:08 PM
Just replace them, it's not hard and cheap maintenance.
88 Fiji Blue -Tsi
#4 Bradrock
Bradrock
  • 896 posts
Posted 17 September 2018 - 06:12 PM
I'd go ahead & do both sides. It's fun scooping out a gob of grease & packing bearings!
Run's with scizzor's
#5 TexasQuest
  • 8,681 posts
Posted 17 September 2018 - 07:25 PM
I use one of these. Makes way less mess lol.
https://www.bing.com...x=16&ajaxhist=0
88 Fiji Blue -Tsi
#6 Bradrock
Bradrock
  • 896 posts
Posted 17 September 2018 - 09:27 PM
Geeze;  What's next? A box of rubber gloves in the shop? Heh...Heh.. :D :D
#7 Contsis
Contsis
  • 193 posts
Posted 18 September 2018 - 07:22 AM
Thanks all
These readily available?
#8 TexasQuest
  • 8,681 posts
Posted 18 September 2018 - 05:57 PM
Yes. Rockauto.com is your friend.
88 Fiji Blue -Tsi
#9 Indiana
Indiana
    Addicted Starquester
  • 14,741 posts
Posted 18 September 2018 - 06:59 PM
If the grease under the dust cap doesn't have water in it then its just loose and a shop should have taken 2 minutes and fixed it for you because its adjusted wrong.  Look it up.
Edited by Indiana, 18 September 2018 - 06:59 PM.
#10 Contsis
Contsis
  • 193 posts
Posted 19 September 2018 - 07:53 AM
Thanks for this info Indiana - I'm guessing you mean tightening the hub nut if loose and nothing is damaged.
https://www.howacarw...wheel-bearings
This was found during a safety inspection for a sticker so I didn't expect them to fix it. Just happy they didn't fail it, all set for another year.
I will take a look - appears simple enough for me to replace or adjust.
#11 importwarrior
  • 18,107 posts
Posted 19 September 2018 - 08:50 AM
The FSM says tighten to 14 foot LBS. loosen to 0. final tighten to 4 Ft Lbs
www.starquestgarage.com
section 2 Front Suspension
page 2-10
file:///C:/Users/vipsupport/AppData/Local/Microsoft/Windows/INetCache/IE/1M0GEW9F/88_conquest_service_manual_-_group_02_-_front_suspension.pdf
#12 BuGG
BuGG
  • 1,929 posts
Posted 19 September 2018 - 10:47 AM
This
