Yellow 4g63
72 replies to this topic
#61 techboy
techboy
  • 3,479 posts
Posted 02 December 2019 - 08:43 PM
Amazing. I've been tossing around doing a 4G63 swap in my car almost since I got it.
#62 mbruneaux
mbruneaux
  • 1,478 posts
Posted 03 December 2019 - 09:18 AM
That car is super clean, looks really good with the coated IC pipes and how neatly packaged everything is.  Very nice job.
Canterbury, CT
2001 BMW 740iL - My Daily
#63 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 08:33 PM
Finished up the fuel pump wiring. It's ran by one of the GPIO outputs from the ecu. Had to run a ignition power source to the trunk and used the original black white wire to ground the relay through the ecu output.
#64 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 08:41 PM
Unfortunately the clearance between the cas and the heater core pipes was not enough. I could install the cas properly but if I had to advance or retard the timing it would hit the pipe and not allow me to adjust it any further. Coupled with that and the area being congested I decided to re-route the lines. I removed the heater core and removed the flow control valve. I'll probably loose some degree of heater control but i'm not 100% sure what the operation of the actuator was. Then installed it backwards and hosed it to the firewall where the Ac lines used to go.
#65 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 08:46 PM
Made cover plate for firewall
#66 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 08:49 PM
Powdered the cas cover for fun
#67 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 08:54 PM
Since the shifter for the w58 was taller and not in the best spot the tunnel needed the hole enlarged quite a bit. To cover that hole and keep fumes out I fabbed up a cover.
#68 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 09:04 PM
Also finished up the downpipe. Some things that I'm sure most of you know but I learned from making this. Always bolt down flanges to something flat or a heat sync before welding on them. My turbo to downpipe flange warped and I had to get it re-surfaced at a machine shop. Lesson 2 if you go recirculated on your external wastegate use a bellows or flex joint. Getting the wastegate to go back in was a nightmare. Or just build a screamer pipe. :)
Edited by cheesey, 13 January 2020 - 09:05 PM.
#69 cheesey
cheesey
  • 802 posts
Posted 13 January 2020 - 09:07 PM
Getting close....
#70 mbruneaux
mbruneaux
  • 1,478 posts
Posted 14 January 2020 - 06:46 AM
Looks great
Canterbury, CT
#71 speedyquest
speedyquest
  • 4,243 posts
Posted 14 January 2020 - 08:29 AM
As always your fabrication is spot on and I cannot wait to see you get this sucker fired up and driving around.
#72 AtlanticBlue87
AtlanticBlue87
  • 91 posts
  • Interests:Cars, Computers, Whiskey, Coffee, Not having money.
Posted 14 January 2020 - 08:40 AM
Looks great!
1987 Atlantic Blue Conquest - To swap or not to swap?
1987 Black Flatty Automatic - Organ Donor
Daily: 2013 Accord Sport 6MT
Other Fun Car: 1988 Corvette Convertible
Quote
I'm a Mechanical Engineer, wiring scares me! :D
#73 TexasQuest
  • 9,051 posts
Posted 14 January 2020 - 11:59 AM
Fantastic work!
88 Fiji Blue -TSi
