Intake Plate by Elutions Design
intake mpi itb
17 replies to this topic
#1 scott87star
scott87star
  • 4,932 posts
Posted 22 August 2014 - 09:24 PM
Made up a few intake plates for a roll your own MPI or ITB system.  $105 each which includes USPS priority mail shipping, there are seven available.
These are 6061 aluminum, 3.8" thick and fit perfectly on an M7 or M8 head, fits just fine on all others.  I deliberately did not cut any excess material which serves three purposes:
1)  The excessively large water jacket on the back port on the aussie (magna) head is completely covered.
2)  The useless to us fuel pump port is completely covered.  NO MORE LEAKS!
3)  The distributor hole is covered.  If you have enough moxie to roll your own intake you likely don't intend to use a distributor, but if you do you can just cut that end off beyond the water jacket.  If you want to run a Mighty Max optical distributor (for crank and cam signals) you can drill an appropriate hole and you *shouldn't* need a spacer.  I say shouldn't because I have not tested it.  I run a Mighty Max dizzy on my MPI car and its using a 1/4" spacer, I don't believe another 0.125" is going to throw it out of the range of adjustment it already has.
Obviously you'll need to fab your own gasket using a roll of gasket material, any auto parts store carries it.
So what do I mean by "fits just fine on all others"?  Well, there are slight variances in the actual intake ports for each runner on the many heads designed for the G54b, both in overall diameter and port placement.  I'm being real picky and giving complete disclosure, we've put this intake plate on the M7, AMC Marnal, factory JV and D50 heads and while it is perfect on the M7/8 because that is what it was designed on you can feel some slight differences on the other heads with your finger between the plate and the bore.  Again, if you have the moxie to fab an intake then you can certainly compensate, its just a few thousands of an inch.
AMC MARNAL HEAD
AMC MARNAL LEFT SIDE
AMC MARNAL RIGHT SIDE
M7/8
So, anyone want one?  Again, these are a finished product suitable for your next extravagant G54b build, like mine!  I'm going 48 MM ITB.  If demand is high we can make more.
Edited by scott87star, 22 August 2014 - 09:27 PM.
#2 randy
randy
  • 4,092 posts
Posted 22 August 2014 - 10:56 PM
Nice looking product and what is the price on these?
#3 scott87star
scott87star
  • 4,932 posts
Posted 23 August 2014 - 09:49 AM
First line of the post Randy.
#4 SOTTY
SOTTY
  • 6,466 posts
  • Interests:Az gotz da cotton mouff
Posted 23 August 2014 - 01:49 PM
That's a SMOKING DEAL at 105 bux shipped ,  ITBeez FTW  .
#5 randy
randy
  • 4,092 posts
Posted 05 October 2014 - 08:57 AM
Quick question can I use one of these if I cut the intake flange off the fip intake? I'm trying to use the stock thermostat
housing if possible, so that I don't have to use the meziere thermo housing.
#6 scott87star
scott87star
  • 4,932 posts
Posted 05 October 2014 - 12:12 PM
I'm sure there is a bit more fabricating involved than just slicing off the FIP flange but the port spacing will be the same.  All based on the same head.
#7 randy
randy
  • 4,092 posts
Posted 05 October 2014 - 05:18 PM
Thanks i'll look into it a little more.
#8 scott87star
scott87star
  • 4,932 posts
Posted 06 November 2014 - 05:49 PM
For those of you contemplating or calculating your intake system requirements, tuned runner lengths courtesy of Larry Meaux's (Larry Meaux's racing heads) Pipemax calculation program.  Lengths are in inches.  Each harmonic causes the Helmholtz resonation and they go from strongest to weakest.  These are based on the physical measurements of valve size, cylinder volume, all that stuff.
1st harmonic, 45.8"
2nd harmonic, 26"
3rd harmonic, 18.1"
4th harmonic, 14.3"
5th harmonic, 11.6"  <= Stock Magna intake length
6th harmonic, 9.7"
The runner length is from the back of the intake valve to the first open plenum.
It also calculates the maximum and minimum plenum volume, in CC they are 2555 and 239.  There isn't a recommended value here, only a max and min.
Example use of Pipemax:  http://hotrodenginet...d-truck-engine/
Edited by scott87star, 06 November 2014 - 05:53 PM.
#9 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,326 posts
Posted 07 November 2014 - 09:04 AM
resisting temptation ... must stay stock, must stay stock, must stay stock :mellow:
          MOPAR POWERED
#10 markhansenconquest
markhansenconquest
  • 3,195 posts
Posted 10 November 2014 - 02:13 AM
Harry ^^^^^^^^^^^just take one of your stock parts ...and polish the sh** OUT OF IT......AND DRINK SOME BEER IN BETWEEN   changing polishing bonnits... :lol: :lol: :D :D
it will work for while.....
Edited by markhansenconquest, 10 November 2014 - 02:25 AM.
#11 88351wtsi
88351wtsi
  • 964 posts
  • Interests:My kids, music, and cars, not always in that order.
Posted 01 December 2014 - 05:08 PM
Anyone built their own yet?   Please post pics and details of your builds.  Thank you
1988 Conquests
His:  Durban maroon with 351w
#12 Mook1994
Mook1994
  • Newbies
  • Pip
  • 9 posts
Posted 13 February 2015 - 11:13 PM
Still have these for sale?
#13 scott87star
scott87star
  • 4,932 posts
Posted 14 February 2015 - 11:23 AM
Yes sir.
#14 scott87star
scott87star
  • 4,932 posts
Posted 21 October 2015 - 08:29 AM
Bump, good winter project to build your own MPI.
#15 speedyquest
speedyquest
  • 3,855 posts
Posted 12 January 2017 - 12:33 PM
Bump! So others can find this.
#16 scott87star
scott87star
  • 4,932 posts
Posted 08 August 2018 - 09:34 AM
#17 Funky Phil
Funky Phil
    Super Pooper
  • 6,377 posts
Posted 08 August 2018 - 06:21 PM
Whats it flow?
#18 scott87star
scott87star
  • 4,932 posts
Posted 08 August 2018 - 07:14 PM
As much as the ports behind it.
Also tagged with one or more of these keywords: intake, mpi, itb
