Fidanza install and Clutch Problems
22 replies to this topic
#21 psu_Crash
psu_Crash
  • 7,238 posts
Posted 13 May 2018 - 11:31 AM
I know about the restrict or there, but it's been to long to remember if I took it out. After playing around with the slave rod length I have things working much better now. Of course I didn't grab a length though... I'll try to remember to do that
The Valencia Project
My Feedback Link
#22 Indiana
Indiana
    Addicted Starquester
  • 14,757 posts
Posted 26 May 2018 - 10:06 PM
That setup without new pins and bearings for them to rotate in will chew up those stock type crap parts and mash that plastic shock absorber thingy on the end that were never meant to be under so much force to release that HD pressure plate.  That hole goes from round to oval very very quickly then you try to compensate with longer rods and extending the rob etc. etc.
You got sloppy linkage.
#23 psu_Crash
psu_Crash
  • 7,238 posts
Posted 27 May 2018 - 05:30 PM
Last fall I put a bearing and bushing in that linkage. It's tight as a frogs bottom. I replaced the rubber in there with a piece of delrin too. So I don't believe any of that caused the issue
Edited by psu_Crash, 27 May 2018 - 05:31 PM.
My Feedback Link
