Steering wheel stereo controls adapter
2 replies to this topic
#1 Leeintheconquest
Leeintheconquest
  • 205 posts
  • Interests:Sold. She lives in NJ now.
Posted 22 December 2011 - 04:50 PM
Has anyone used a PAC SW1 adapter or any kind of adapter for the steering wheel controls when putting in a new head unit?  I'm trying to figure out what wires to use from the factory harness to get the signal to tie into the adaptor.  The wires the adapter manual says to use do not match with the factory wiring...........
Any help?
#2 Leeintheconquest
Leeintheconquest
  • 205 posts
Posted 22 December 2011 - 05:13 PM
OK, found the thread about this so sorry for asking again.   I would like some clarification as to the Green/White wire from the factory plug:  It looks to me like it should be left alone and connected to anything during the install.  Is this correct?
#3 mstieg
mstieg
  • 6,172 posts
Posted 29 March 2016 - 10:30 PM
bump for follow up.
Found this thread also, but that's it:
http://www.starquest... +wheel +button
I've used the SWI-X before which is not a direct wire to the stereo but uses an IR bulb as a simulated remote.  Works okay but not in direct sunlight.
I'd like a hard-wired solution and also need to know if it really is of any help to narrow down potential deck units to those claiming to have steering wheel button control??
In Progress: breakin & tune
