FuelinjectionPro
117 replies to this topic
#21 Jms
Jms
  • 454 posts
Posted 17 September 2008 - 09:40 PM
QUOTE (Lusion972 @ Sep 17 2008, 08:31 PM) <{POST_SNAPBACK}>
Do you still have any trigger wheel pulleys and vr sensor adapters available?
Lusion972,
Take a look at the following sites:
http://www.megamanual.com/ms2/EDIS.htm
http://www.311s.org/tech/ignition/edis.html
Bom ver outro Portugues neste forum (Sorry guys, this is code).
Rgds,
Jms
Posted Image   1988 TSi SHP
#22 substock
substock
  • 3,993 posts
Posted 18 September 2008 - 05:06 AM
Ed,
also, what are the wattage and ohms of the resistor pack?
i need to get some new ones for my ecu
'89 Conquest
#23 Lusion972
Lusion972
    I need a quest
  • 3,824 posts
  • Location:Sherman, TX - Home of the neighbors with no legs.
Posted 18 September 2008 - 07:35 AM
My Portugues is a bit rusty since I haven't had anyone to speak to in 20 years but here goes...
Não bastante de nós sobre aqui
Dad's the man for all your parts needs Engine Machine Service
#24 gofastredstar
gofastredstar
  • 709 posts
  • Interests:Starquest! Duh!
Posted 18 September 2008 - 05:54 PM
Ed,
Quick one for ya. My FC-1 has quit sending the priming pulse. Ideas?
Oh, and glad to see ya back.
I'm your turbo lover!
88 Conquest (Fiji)
Magna, 75 lbers, 6062 turbo, 86 interior, 8 and 9's, 83 Hood, FIP Fuel and Ignition Ecu's, Sreaming Banshee mechanical, and other goodies I'm forgetting.
#25 jahjah
jahjah
    Dazed and Confused
  • 5,014 posts
  • Interests:Family, friends, Cars
Posted 18 September 2008 - 10:21 PM
QUOTE (Lusion972 @ Sep 18 2008, 08:35 AM) <{POST_SNAPBACK}>
"Not enough of us about here" ??
#26 Lusion972
Lusion972
    I need a quest
  • 3,824 posts
Posted 19 September 2008 - 10:40 AM
around
#27 BaltTSI
BaltTSI
  • 2,086 posts
Posted 19 September 2008 - 06:17 PM
Thats exactly what I wanted to know Jms, and this temp set point can be adjusted in the software like Ed said right?
Former Conquest owner, 2001 to April 2009
#28 Jms
Jms
  • 454 posts
Posted 20 September 2008 - 02:19 PM
QUOTE (BaltTSI @ Sep 20 2008, 05:17 AM) <{POST_SNAPBACK}>
BaltTSI,
I have yet to start my motor even though all is setup to go. I'm waiting on powdercoating. When I talked to Ed, he gave me the impression that this temporary ground, was dictated by the CTS. I'm not aware that there are adjustments in the software for this item. To clear this point up, contact him and please do let us know what he said.
Rgds,
Jms
#29 BaltTSI
BaltTSI
  • 2,086 posts
Posted 20 September 2008 - 08:32 PM
Contact him? he has been showing up on here lately, he ask to post any questions here right?
#30 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 22 September 2008 - 06:43 PM
Ed,
I have your TBPRO...not MPI but I figured the forum was appropriate. Can you please send me some stuff via e-mail or post in here. I need the wiring diagram for msd6al with 8910 tach adapter. I also need your base tune map for TBPRO2. I CANNOT get rid of eratic tach signal and eratic o2 readings....Please let me konw what you think.
Braden
87 Starion 2jz
#31 BaltTSI
BaltTSI
  • 2,086 posts
Posted 26 September 2008 - 09:17 PM
Hey BOHO, I had the same problem with my TBPro2r, Tach spikes, all mine turned out to be was the wire coming off the distributor needed to be moved, I simply moved that wire towards the firewall a few inches and wire tied it, and the problem went away, so it can be a little sensitive to where you have things I think, worth a try.
#32 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 28 September 2008 - 09:22 AM
Was your caravan ign module inside the distributor or out? I can't do anything with the car until I get this figured out...its impossible to tune.
87 Starion 2jz
#33 zactek
zactek
    Artistic Technician
  • 3,935 posts
Posted 28 September 2008 - 11:25 PM
QUOTE (BOHO @ Sep 28 2008, 10:22 AM) <{POST_SNAPBACK}>
If you're using the caravan module (the CR-125). it should be inside the dist. instead of the stock module.
Also, are you using a tach adapter with whatever ignition box you're using?
  Zack
Life's too short to be like everyone else.
Savour kindness because cruelty is always possible later.............
Uploaded with ImageShack.us
#34 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 29 September 2008 - 07:29 AM
Zac....Right now the cr-125 is the only ignition module I'm using...I could not get it to work with msd 6al....I'm trying to get the wiring diagram so I can try it again. I've got it mounted inside the dizzy...and a coil...thats it.....but can't get rid of eratic tach. I had the setup with the msd 6al and 8910 tach adapter and was losing tach signal....
Braden
87 Starion 2jz
#35 zactek
zactek
    Artistic Technician
  • 3,935 posts
Posted 30 September 2008 - 12:06 PM
QUOTE (BOHO @ Sep 29 2008, 08:29 AM) <{POST_SNAPBACK}>
Braden
That's the same exact setup I'm using (except I'm using the Mallory 6A box). Do you have the orange wire that comes from the FIP ecu wired correctly?
All the wires that come from the dist., the tach adapter, and the ignition box are wired in a junction together......
  Zack
#36 Lusion972
Lusion972
    I need a quest
  • 3,824 posts
Posted 30 September 2008 - 03:08 PM
I guess this thread fell thru on them providing technical support
#37 FuelinjectionPro
FuelinjectionPro
  • 336 posts
  • Interests:CARS!
Posted 13 October 2008 - 08:48 PM
QUOTE (BOHO @ Sep 23 2008, 12:43 AM) <{POST_SNAPBACK}>
Ed,
Braden
Here is the connection diagram.
Also be sure to keep all sensor wires away from the coil, msd, spark plug wires.
Edited by FuelinjectionPro, 13 October 2008 - 08:51 PM.
Fuel=Power  http://WWW.FuelinjectionPro.com
Works best under pressure!
New Distributorless Ignition System http://www.angelfire.com/mech/edwardcase00/edsion.html
#38 FuelinjectionPro
FuelinjectionPro
  • 336 posts
  • Interests:CARS!
Posted 13 October 2008 - 08:54 PM
QUOTE (BaltTSI @ Sep 20 2008, 12:17 AM) <{POST_SNAPBACK}>
Yes, see my previous post about your question.
Ed
#39 FuelinjectionPro
FuelinjectionPro
  • 336 posts
  • Interests:CARS!
Posted 13 October 2008 - 09:03 PM
QUOTE (gofastredstar @ Sep 18 2008, 11:54 PM) <{POST_SNAPBACK}>
Ed,
Be sure you have the priming pulse set as show.
#40 FuelinjectionPro
FuelinjectionPro
  • 336 posts
  • Interests:CARS!
Posted 13 October 2008 - 09:16 PM
QUOTE (Jms @ Sep 17 2008, 07:59 AM) <{POST_SNAPBACK}>
Hi Ed,
Can you list the pinout for the serial connector (DB-37?) on the FC-1?
Rgds,
Jms
I have a drawing I will post.
Ed
