MPI sensors crank sensor part numbers
11 replies to this topic
#1 importwarrior
  • 18,294 posts
Posted 08 September 2015 - 12:51 PM
Provided by :
Button
Here is his store:
http://stores.ebay.c...=p2047675.l2563
Conquest Store:
http://stores.ebay.c...d=p4634.c0.m322
Plug:
http://www.ebay.com/...=item58acaec281
Pulley:
http://www.ebay.com/...sd=141207061644
Bracket:
http://www.ebay.com/...=item255ba579cf
Sensor:
http://www.ebay.com/...ab845a2&vxp=mtr
BWD Part No. CSS12P
BWD Part No. CSS12P
STANDARD MOTOR PRODUCTS Part # PC19T
AIRTEX / WELLS Part # 5S1739
AIRTEX / WELLS Part # 5S1740
Pigtail:
http://www.ebay.com/...WPT579&_sacat=0
Dorman Part # 49813
STANDARD MOTOR PRODUCTS Part # HP4710
AIRTEX / WELLS Part # 1P1258   {#3U2Z14S411SMA, 626}
MOTORCRAFT Part # WPT579
The sensor and pigtail are for a 1998 Ford Escort with the 2.0L SOHC
Alternate Sensor
Provided by:
Scott87Star
Hall Effect Sensor
Pig tail
http://www.digikey.c...7665-ND/1764180
Sensor
http://www.digikey.c...CH704-ND/418211
#2 stesir
stesir
  • 1,025 posts
Posted 08 September 2015 - 05:23 PM
MKI?
#3 importwarrior
  • 18,294 posts
Posted 08 September 2015 - 06:37 PM
What's the question???
#4 TexasQuest
  • 8,876 posts
Posted 08 September 2015 - 07:17 PM
Good job importwarrior. This should be stickied.
88 Fiji Blue -Tsi
#5 importwarrior
  • 18,294 posts
Posted 08 September 2015 - 08:10 PM
Thank you.
I believe it is. ;)
#6 psu_Crash
psu_Crash
  • 7,161 posts
Posted 09 September 2015 - 08:01 PM
Just FYI for anyone wanting to run that pulley with an aftermarket radiator. I run the *DM rad which is 3 core I believe. It puts the trigger wheel VERY close to the radiator. You will have to trim the stock shrouds (if that's what you use) to make it fit. One of the reasons that I went with the MM CAS instead in the long run.
Edited by psu_Crash, 09 September 2015 - 08:02 PM.
My Feedback Link
#7 importwarrior
  • 18,294 posts
Posted 09 September 2015 - 08:30 PM
Good info thank you.
#8 scott87star
scott87star
  • 4,998 posts
Posted 10 September 2015 - 08:22 AM
You can also use a Hall Effect sensor with those trigger wheels:  http://www.digikey.c...ywords=CH704-ND
The Hall effect ones are less prone to signal noise, VR sensors are quite sensitive to noise as the signals are very weak and the best place to run one on our motors is right next to the alternator.  Don't forget the pigtail!  They also work great as VSS (Vehicle Speed Sensors) which allows the use of the traction control feature in the megasquirt family of aftermarket ECU's.  If you drag race and DON'T have traction control, well, that's why you're getting beat.
#9 TSIREX
TSIREX
  • 282 posts
  • Interests:Family,conquests
Posted 02 January 2016 - 08:41 PM
Does the Hall effect sensor attach to the above said bracket pretty easy and do you know the Hall effect pigtail part number?
Njv m28 head,wiseco pistons,ARP head and connector rod bolts,3.5 gm maf with maft 2.0. Ajusa head gasket. Engine rebuilt by Kennedy performance in Lexington Kentucky
#10 scott87star
scott87star
  • 4,998 posts
Posted 03 January 2016 - 11:04 AM
Pigtail.
http://www.digikey.c...7662-ND/1764177
#11 TSIREX
TSIREX
  • 282 posts
Posted 06 January 2016 - 12:10 PM
Thanks Scott87star
#12 importwarrior
  • 18,294 posts
Posted 10 February 2016 - 05:53 AM
Mighty MAX Distributor info here.
http://www.starquest...howtopic=113656
