MPI general guide lines
41 replies to this topic
#1 Bag-O-Chips
Bag-O-Chips
    Too close for missles, switching to guns!
  • 1,250 posts
  • Interests:welding toothpicks to battleships.
Posted 20 October 2012 - 10:03 PM
I feel as though there are many questions that have been answered through the years regarding the MPI conversion process but have been lost through changes in the site. Due to the format of this I will be posting this in multiple parts,
In the bigger picture, The MPI conversion is the process of converting from the ECI Throttle body injection setup which consists of a primary and secondary injector. Depending on the date of manufacture, your SQ will either be equipped with sequential injection or alternating injection.
Sequential injection will be utilized in 87.5 - 89 vehicles according to production date and will be seen with a Green and Black injector.
Alternating injection will be utilized in 87.5 and below with two injectors of the same color.
Both will do the job great when you leave the car stock. But If you're reading this you already know the flaws of TBI.
Now for the fun bits!
MPI conversion consists of 4 main principles,
- Intake manifold
- Fuel delivery
- Intercooler piping
- Engine management
Intake Manifolds are the easier part of the equation. The selection boils down to availability, which one can you find so to speak.
Here is a list I've complied through the years and I'll keep it simple. I will add pictures as I go along.
OEM Mitsubishi Magna - Most commonly found, and the most articulate of the Intake manifolds. The Manga Intake manifold is not a direct bolt-on. There have been many variations in the years as to how these are modified from a FWD application to a RWD application.  More often than not you will find a Magna that has been already modified to fit. There are some that require an adapter plate and some that have been welded and milled to acommodate the larger rear coolant passage that the Australian G54 heads have.  *be aware* there are Magna's that WILL NOT FIT due to longer intake runners that interfere with the brake booster and master cylinder.
Will fit
Fuel Injection Pro Hurricane - This manifold is no longer in production and is a custom made unit. This Manifold has been engineered to be a purpose built direct bolt-on MPI manifold for the G54. Although almost impossible to be had many people here have been running them with success both on the street and at the track.
EIP tuning Cannon - There are two versions of the Cannon. The "street" and the "race". The main difference between them is the Intake Plenum and runner length. The "race cannon" has a larger plenum with slightly shorter runners optimized with emphasis for High RPM and High volumes of air.  The street version is not that much different, the plenum volume is slightly less and runner length is slightly longer with higher port velocity in mind for driving on the streets
Chad's MPI manifold -This is another purpose built MPI manifold that has been engineered to perform well through all conditions whether on the street or the track, the R&D put into the making of this has been pushed to the limits of the space constraints of the SQ engine bay.
Gato Performance - I don't know too much about this manifold but from the years of talking to members equipped with this unit, there has been nothing but good numbers produced with this setup. Just like all the Purpose built Intake manifolds, the fit is clean and more inclined towards the Race applications.
Top End Performance MPI - Well.... It's a Stock TBI manifold modified with 4 injector bungs and a new fuel rail. The concept proved will in the late 90's and worked for it's intended purpose but the price was and still is outrageous for something with minimal amounts of effort put into it.
There are others that I have not mentioned such as
Maxboost's MPI manifold - There are variations of his manifolds and although I've never seen them in person, the craftsmanship and concepts are very innovative.
Which ever one you can get your hands on is going to dictate the direction for your build. If you have a choice of which to select, select according to your power expectations and your driving style.
I have personally owned a Magna, EIP Race Cannon, and am currently using one of Chad's MPI manifolds.
Edited by Bag-O-Chips, 23 October 2012 - 05:44 PM.
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
E85, GT4088R, Dual Synapse 50mm wastegates, Apexi AVC-R, Griffin Radiator, 2G Eclipse Flexalite fans, AEM 30-1300, HKS 301 cam, LSP built Marnel head, Del West 1mm oversized Titanium valves, Del West Titanium Valve lock/retainers, LSP Valve Springs, 1600cc injectors, SX AFPR, Fuelab Prodigy 140gph pump, Fuelab Filter, Bag-O-Chips  Twin scroll header, Chad's MPI Manifold, 70mm Throttle, 4.62 gearset, Wiseco .030", R&R Aluminum billet Rods, ARP everything, Toyo R888's.
#2 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 21 October 2012 - 12:00 AM
Fuel delivery
Depending on the Manifold you are using it should have a fuel rail to compliment. Before you even consider purchasing a manifold do your best to get one as "complete" ans possible. Many of them I have seen do not include important parts such as fuel rails and fuel pressure regulators. On the Magna's the "other" option is a fuel rail from Trilogy Turbos, during their production run, some fit well and some have a slight offset that causes fitment issues. All of the other Manifolds have their respective fuel rails, The only concern you should have is making the feed line and return line work with the fuel rail.
Most people at this point will have upgraded their fuel pumps to something larger and along with that they've upgraded the lines to -6 (3/8") for street/ mild horse power to -8 (1/2")  for high horsepower applications. Depending on your choice fuel such as Ethanol or Race  fuel choose lines that will be able to resist their corrosive properties. The myth has been busted though, Both Technology and a few others have converted their cars to E85 with stock lines at one point with no difference in deterioration to their rubber lines. I personally use a Fuelab Prodigy fuel pump and Parker lines.
As long as the rubber lines are chemical resistant you should be safe.  I my self recommend "parker push-lok" lines. I have been running E85 through -8 AN lines rated for 250psi working pressure and have had no signs of deterioration.
Filters - Filters are often overlooked when an MPI build is pieced together. You're making a big investment at this point. Because the SQ platform utilizes an external fuel pump, it makes things easy. Generally you'll want to have the cleanest fuel system possible. Inbetween the pump and rail usually consists of 2 filters in most race applications. A 100 micron from the pump and a 10 micron before the rail. This will ensure there are no contaminants in your fuel lines. You'll be surprised how a deteriorating rubber hose can wreak havok in a fuel injector.  More common than not a misfire that you can't get rid of is because the fuel injector's screen filter is clogged or there is gunk keeping the pintle open and causing fuel to come out in globbules rather than the fine mist that it's supposed to.
I don't think I really need to elaborate on fuel injector selection, depending on your power expectations, choose a set that is slightly larger than what you need. It could save you in the long run. But I will eleborate on the type of injectors out there. Depending on the style of injector bungs you may be required to use Domestic style injectors as opposed to the more common Import style. They may look similar from a distance but their fit is worlds apart.
Take care of your fuel system.
Edited by Bag-O-Chips, 21 October 2012 - 12:07 AM.
#3 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 21 October 2012 - 12:36 AM
Intercoolers and Intercooler plumbing.
Why bigger is not always better. - At some point you will need to chill the air coming out of the mighty 12A...
Choosing and intercooler isn't entirely rocket science. There are Tube and Fin, and Bar and plate. The space is there, and the options are endless from Ebay specials to Race quality application specific units, be mindful with the type you choose. Some are direct bolt on units which emphasize on getting air to the radiator and some are universal "make it fit" type deals. Either way you go, don't forget, the Intercooler is a major part of the airflow equation that can be detrimental to your cars performance or the key to making big numbers. If your intake air temps are ice cold but your car overheats... you're not making any progress.  Intercooler core selection play a major part in this.
Keep in mind, an intercooler at it's peak efficiency will only cool boosted air as cold as the ambient temperature. You cannot expect your IAT's to be at 50* if the temperature is 80* on a summer day.
Plumbing the system is almost cut and dry, As a general tip going too big on piping diameter is not necessary. A 3" charge pipe is not only going to lose velocity, but will add a slightly noticeable amount of lag. More often than not, 2.5" is the happy median for volume and velocity on the SQ plaform.  2.125" - 2.25" is perfect for those with quick spooling turbos.
Keep couplers to a minimum! If you can possibly minimize the areas for a boostleak please do so. In the bigger picture, you should really only have 4 places for couplers. Again, be mindful with how the engine moves. Unless you have solid engine mounts, the G54 be likes to wiggle even with New engine mounts, eventually this movement will cause flex in the couplers.  The remedy for that are... flex  or hump couplers.
I'll Add more later. Coffee is wearing off and I need ZzZzZz's
Edited by Bag-O-Chips, 21 October 2012 - 12:47 AM.
#4 koyo
koyo
  • 177 posts
Posted 21 October 2012 - 07:22 AM
Bag-O-Chips
Thanks for the information of MAGNA intake!
I had a hard time does not enter information at all is in Japan.
I'm surprised at the variety of MPI! !
#5 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 21 October 2012 - 09:52 PM
Engine Management
Here's where things get complicated, The engine management unit or ECU is the heart and soul of the setup. Investing in the best you can afford is highly advised.
The majority have had success with Megasquirt, AEM, F.A.S.T., Autronic, Haltech, Electromotive, SDS, DSMlink, LinkECU and a few others I have failed to mention.
The options all the same in many instances. Making a wiring harness and obtaining sensors needed to make the conversion work are fairly easy to obtain. Some of the available EMS's have sensors built in to them. The other Main sensor that you should pay special attention to is the Knock sensor. The factory knock sensor can be made to work, but in some cases you will find it difficult to add a knock sensor. Do your best to utilize a knock sensor.
The 5 major sensors needed for any fuel injected engine to work are:
MAP/MAF - used for calculating load on the engine and and Airflow volume, Most of your fuel demands will be measured by these sensors depending on your setup.
Crank/Cam position - During the conversion procces you will need a way to tell the ECU what position the crank or cam shaft is in. With out it, the ecu won't know where in the crank rotation to fire the injector or to fire the ignition coil. This is usually done through a magnetic pickup, Hall Effect sensor, or Optical sensor.  A few examples are:
Oxygen sensor - This sensor is vital to the performance of your car. The purpose of the O2 sensor is to measure the amount of oxygen in the exhaust stream. In conjunction to the measurement of Oxygen, the ecu can determine how much fuel to add or remove in the map according to the values set in the ECU through this sensor's inputs. It is in your best interest it use a Wideband O2. Most if not all Stand alone EMS units will require an 0-5v input from a wideband for feedback. Not only that, but widebands are just more accurate.
Coolant temperature sensor - This sensor is another input that has a direct effect on fuel delivery. Warm up enrichment and fuel enrichment at optimum working temperature. With out it, the Ecu will not know if the Engine is stone cold or hotter than the breath of Hades.
Air Intake temperature sensor -This sensor functions the same as the Coolant temp sensor, The difference is it measures the temperature of air that is ingested by the engine. The ECU also uses this input to tailor the amount to fuel enriched whether to add or remove depending on what it has measured. In some cases, the IAT is also referenced by the ecu to compensate for Ignition timing advance in order to prevent pre-ignition and detonation or so commonly known as "knock"
I hope this helps the many that are leaning in the direction towards MPI. I will add more information as I go along.
-Chips
#6 speedyquest
speedyquest
  • 4,149 posts
Posted 22 October 2012 - 07:19 AM
Very good info man. I think the whole community can benefit from this.
Allen
#7 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 22 October 2012 - 01:30 PM
I can elaborate further, but i would only sound like James May.
#8 starquestJOE
starquestJOE
  • 3,537 posts
Posted 29 October 2012 - 10:46 PM
Eip only made two "race" cannons. One is on ranks 721hp car and the other is on my 464hp car
Edited by starquestJOE, 27 December 2014 - 07:05 AM.
IM STARQUEST 4 LIFE ....
88 esi-r-white-SOLD
88 tsi white 61k-SOLD
89 tsi-black-rip
87 tsi-black/red-SOLD
88 tsi yellow sold
89 tsi white parts car
88 esi-r-black-RIP
#9 obsolete
obsolete
  • 326 posts
Posted 29 October 2012 - 11:28 PM
Hey, that's not a bad thing.  By all means, keep going.
#10 ESIrType?
ESIrType?
  • 3,065 posts
  • Interests:Cheese, sloth fighting and bigfoot!
Posted 30 October 2012 - 09:08 AM
Very nice right up, and thank you for taking the time to write it. It's nice to have this in a collective place so that people thinking about switching know more what they are about to get into.
Shawn
#11 Guest_Phillip_411_*
Guest_Phillip_411_*
  • Guests
Posted 04 November 2012 - 11:49 AM
Thanks for taking the time to simplify some of the otherwise diffucult aspects of goimg MPI.  This is very beneficial. I look forward to seeing more posts like this.
Thanks,
Phillip_411
#12 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 11 December 2012 - 07:04 PM
Any time guys!
#13 polarisman14
polarisman14
    DRIFTIN'
  • 2,158 posts
  • Interests:Cars, motorcycles, snowmobiling, four-wheeling, snowboarding, golf, billiards, bowling, forums, volleyball, Boston sports teams...Anything fun and mechanical.
Posted 11 December 2012 - 08:59 PM
What may help people as an add-on to this thread is if people post up what they are using in the same order that you presented the information. That way if anyone has any questions about a specific setup they know who to go to.
I'm using the FIP Hurricane manifold, Walbro 255 fuel pump w/ a Russell inline fuel filter right off the hard line (stock hard fuel lines to 3/8" stainless), 75# injectors, Sard adjustable FPR, *DM 4" thick IC w/2.25" in/out. Inlet pipe on the turbo is 3", charge piping is all 2.25". Engine management is via MS2 set up for ignition control, AEM wideband, locked dizzy w/MSD ignition control box, all tuned by Scott@Elutions Design Bureau (scott87star). Also running a full 3" exhaust. Not running any sort of knock control right now but I will be hooking one up shortly.
Great writeup!
'89 Starion SHP...FIP MPI, 3" Exhaust, TEP Cam, Turbonetics 11021-BB T3/T4 Turbo, Treadstone Manifold, 75# injectors, Mookeeh Sway Bars, GC Coilovers, Saleen Replica Wheels, the list goes on...AND IT FINALLY RUNS!!!
http://i512.photobuc...pg?t=1339849860
#14 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 12 December 2012 - 06:21 PM
My set up is Chads Manifold, 1600cc injectors, E85, Fuelab Prodigy 140gph, or 530 lph for those used to walbro lingo., -8AN or 1/2" fuel lines - feed and return, SX fuel pressure regulator 3.5" Godspeed intercooler core with 2.5" plumbing, AEM EMS for a 1G eclipse, and a CAS for a 1G eclipse. Turbo inlet is 4" and the outlet is 2.5" , Throttle body is a 70mm Ford racing unit.
Glad to be of help!
#15 JohnnyWadd
JohnnyWadd
  • Banned
  • 8,936 posts
Posted 12 December 2012 - 10:52 PM
Glad to be of help!
price shiped to 97701?
#16 importwarrior
  • 18,294 posts
Posted 02 October 2013 - 07:39 PM
excellent write up.
#17 substock
substock
  • 3,993 posts
Posted 03 October 2013 - 07:21 AM
Very good write up with a lot of good information.
I had the manifold of chads (same as the one pictured above) and sold it, and i am still kicking myself over that.
'89 Conquest
#18 importwarrior
  • 18,294 posts
Posted 03 October 2013 - 07:52 AM
me too. wish i had it back.
#19 G54Bstore
G54Bstore
    SQC Commander
  • 5,161 posts
Posted 26 December 2014 - 01:44 PM
I had chad mod a magna for me like 8 years ago to bad I sold that. Kicking self now.
W18 Rocky White Starion
Daily Driver
#20 randy
randy
  • 4,104 posts
Posted 27 December 2014 - 05:20 AM
I have one of Chad's first mpi manifolds and fuel rail and his header still boxed up. :lol:
