Driveshaft Shop modified 6 bolt axles
9 replies to this topic
#1 Joedog
Joedog
  • 40 posts
Posted 11 August 2017 - 11:00 PM
I'm selling a set of modified 6 bolt axles from Driveshaft Shop.  I was able to run a best et of 9.46 with these.
Paid $549 to modify existing axles. Will sell for $450 plus shipping.
JOEDOGRACING.COM
1987 Conquest 4G63
1992 Talon TSi AWD
1995 Talon TSi AWD
#2 Mach 5
Mach 5
  • 435 posts
Posted 12 August 2017 - 12:12 AM
What kind of power were you running? just curious. good luck with sale!
-Jarek
Owner and Founder of Triple R Motorsports- Jarek-
-Rides-
-1987 Starion -Midnight Star - NITTO RB28/ Z33 trans/ gtx3582r build in progress
http://www.starquest...howtopic=152434
-1989 Chrysler Conquest-Track Beast Mode gtx3071r TBI 365hp 407tq @20psi- RIP
http://www.starquest...ic=151885&st=40
-1989 Pontiac Grand Prix Turbo SE- 3.1 gt4088r getrag284 Tilton twin disc
-1991 Toyota Hilux Pickup ext 3.0 WONTONPU 121hp
-1990 McLaren Turbo Grand Prix sold...
-1985 AE86 20v.. 171hp@ 8200rpm RIP
#3 mstieg
mstieg
  • 6,092 posts
Posted 12 August 2017 - 09:04 AM
What exactly did they do to em?  Why selling?
Hope you're still out there killing it!
In Progress: breakin & tune
FOR SALE:  Rear Camber plates (basic); NIB beefy U-joints(2); etc.see-->  http://www.starquest...howtopic=133262 Custom 5 guage overlay panel: http://www.starquest...pic=136703&st=0
#4 Joedog
Joedog
  • 40 posts
Posted 12 August 2017 - 08:46 PM
I'm pushing somewhere between 600-700hp
They machined the ends and then banded them so they won't explode. I was launching at 3200 rpms and pulling off 1.6-1.7 sixty foot.
I switched over to the Driveshaft Shop stage 3 axles just so I can launch higher and get some 1.5 sixty foot times.
JOEDOGRACING.COM
1987 Conquest 4G63
1992 Talon TSi AWD
1995 Talon TSi AWD
#5 Mach 5
Mach 5
  • 435 posts
Posted 13 August 2017 - 10:58 AM
good stuff!! are you still using stock wheel hub ends? I was planning on upgrading at some point as well not sure whether to go with these or what you are upgrading to... somebody could definitely use these no doubt! glws
-Rides-
#6 Joedog
Joedog
  • 40 posts
Posted 13 August 2017 - 08:12 PM
Yes everything is stock besides the axles
JOEDOGRACING.COM
1987 Conquest 4G63
1992 Talon TSi AWD
1995 Talon TSi AWD
#7 Mach 5
Mach 5
  • 435 posts
Posted 13 August 2017 - 11:35 PM
wow! that's good to know. Im more of a speed freak than anything.. roll racing, circuit. I wonder what power these would support..? the Midnight Star will be around 700hp and built for 1000 potential.. If they can handle that then I will gladly take them
-Rides-
#8 Joedog
Joedog
  • 40 posts
Posted 14 August 2017 - 10:31 AM
It's hard to say what the limit is on them. I know I was going through regular axles like crazy and these definitely did the job.
JOEDOGRACING.COM
1987 Conquest 4G63
1992 Talon TSi AWD
1995 Talon TSi AWD
#9 Mach 5
Mach 5
  • 435 posts
Posted 14 August 2017 - 11:21 AM
maybe I will call them. If they will be okay then Ill take them. I wont be launching so hopefully they will be good. I wasn't planning on running faster than a 10.0 on the track anyways ill just lower the boost and since your running 9's they should be plenty enough.. ill let you know. Thank You for answering my questions
-Jarek
-Rides-
#10 Mach 5
Mach 5
  • 435 posts
Posted 16 August 2017 - 07:41 AM
I called them... these they say are rated for 650hp... the stage 3 pro model is rated for 1000hp..
-Rides-
