Door hinge bushings?
9 replies to this topic
#1 Spooled_Starion
Spooled_Starion
  • 377 posts
Posted 13 June 2018 - 01:41 PM
My drivers door pops and creaks really bad I have to lift up on it to get it to not make a horrible noise every time I open or close it. Is there any sort of bushings or pins maybe that can help fix the door slop and stop this metal on metal sound? I keep using white lithium grease but that's only a bandaid at this point.
#2 TexasQuest
  • 8,673 posts
Posted 13 June 2018 - 06:22 PM
I had this problem so I ordered new upper and lower door hinges from mitsubishi. I'm not sure if they're still available anymore.
88 Fiji Blue -Tsi
#3 Spooled_Starion
Spooled_Starion
  • 377 posts
Posted 13 June 2018 - 09:05 PM
Do you happen to know the part number for the hinges
#4 tux
tux
  • 1,196 posts
Posted 13 June 2018 - 09:16 PM
I loaded them up with motor oil.  I think that was what the factory manual says to use.
#5 croquest87
  • 1,026 posts
Posted 13 June 2018 - 10:01 PM
Been wanting to make hardware kits for a while now to rebuild them back to new.l can pretty much reproduce any bushing pins and more on a CNC. Not sure how much interest there would be?
#6 TexasQuest
  • 8,673 posts
Posted 14 June 2018 - 05:08 PM
I still have the packages with the part numbers on them. I'll look when I get home.
88 Fiji Blue -Tsi
#7 TexasQuest
  • 8,673 posts
Posted 20 June 2018 - 10:58 PM
Sorry I got back so late, I found the part numbers for the door hinges. Driver side upper is MB296347 and driver side lower is MB296345. Hope this helps.
88 Fiji Blue -Tsi
#8 Spooled_Starion
Spooled_Starion
  • 377 posts
Posted 25 June 2018 - 07:50 PM
Thanks for the information I will see about finding some online and getting those ordered!
#9 techboy
techboy
  • 3,121 posts
Posted 25 June 2018 - 09:36 PM
Following this thread ... curious if you can still get them.  My drivers side creaks too despite being re-greased during my resto.
#10 Preludedude
Preludedude
  • 2,659 posts
Posted 25 June 2018 - 11:13 PM
Liquid wrench "white lithium" spray
It goes on thick and stays there.  Unlike wd40....
My doors were very loud and now they are silent.
