Can't figure out where this connects to.
10 replies to this topic
#1 varzaman
varzaman
  • 114 posts
Posted 10 July 2018 - 07:55 PM
Hey guys,
I just reinstalled my throttle body. Trying to make sure I have everything in place.
There is this electric connector I can't find where it goes. It has a yellow with green stripe, and a yellow with blue stripe wires.
This is for a 1987 conquest.
Pictures
https://imgur.com/a/FQBysB3
Edited by varzaman, 10 July 2018 - 07:59 PM.
#2 pcristquester
pcristquester
  • 2,161 posts
Posted 10 July 2018 - 09:34 PM
It goes to the intake manifold cts that’s horizontal under the thermovalve which is under the tstat housing. It’s for the coolant temp gauge.
#3 croquest87
  • 864 posts
Posted 10 July 2018 - 10:01 PM
Very important that it goes on the correct temp sensor!  This tells ecu temperature to calculate fueling
Make sure to perform IAC TPS reset  after car is running for best results w idle and all because you had it all apart!
Edited by croquest87, 10 July 2018 - 10:05 PM.
#4 techboy
techboy
  • 3,080 posts
Posted 10 July 2018 - 10:19 PM
pcristquester is right ... however, if you replaced that sensor with a new one you might have received one with only 1 tab on it.  If so, it's OK, just plug it onto the one tab and it will still work.  There's a two tab and a single tab version of the gauge sensor out there.
#5 varzaman
varzaman
  • 114 posts
Posted 10 July 2018 - 11:17 PM
As far as I know nothing got changed. I will look in the morning.
#6 varzaman
varzaman
  • 114 posts
Posted 11 July 2018 - 12:16 AM
If I'm looking at the right place, it looks like there is already a connection there. It's a single yellow and green wire.
Could this just be an extra connector?
#7 joshtrup
joshtrup
  • 256 posts
Posted 11 July 2018 - 02:54 AM
I have an extra connector on both my running red 87 and my white 87 that im currently building. I never found a place for it to go and it looks just like that...
Rory Trup's Son
1) 1987 Chrysler Conquest Red (Runs), 2) 1987 Chrysler Conquest White (Project), 3)1969 Ford Mustang 302ci Black Jade (Runs)
1) Posted Image    2) Posted Image 3)   Posted Image
#8 TexasQuest
  • 8,611 posts
Posted 11 July 2018 - 11:35 AM
That connector is either the CTS harness or gauge cluster temp sensor harness.
88 Fiji Blue -Tsi
#9 varzaman
varzaman
  • 114 posts
Posted 11 July 2018 - 01:15 PM
Yea I think its just an extra connector. Why would I have one then? lol.
#10 Spooled_Starion
Spooled_Starion
  • 316 posts
Posted 12 July 2018 - 02:35 PM
I have that same connector as well, cant seem to find where it goes either.
Edited by Spooled_Starion, 12 July 2018 - 02:36 PM.
1987 5 speed starion. Hks Downpipe, Hks exhaust, hks intake, hks camshaft, hks pfc-fcon, hks turbo timer, trilogy injectors.
#11 tux
tux
  • 1,142 posts
Posted 13 July 2018 - 03:47 PM
*shrug* I don't have the original harness of my 87 anymore... but it's probably just spare parts
