Picture Size before Resize?
1 reply to this topic
#1 87Black_Stallion
87Black_Stallion
  • 242 posts
  • Interests:Hitting 88mph!
Posted 19 October 2010 - 08:40 PM
What is the picture size before the forum resizes them to be smaller?
87 Black Stallion - 5 Speed - Rebuilt Bottom End - Balance Shaft Eliminator - Jet Valve Eliminator - A/C Delete - Abs Delete w/ Star Orion Abs Line - Charcoal Canister Delete - 2.5 Catless Exhaust - Stock Twin Tip Muffler - KDM Small Turbo Discharge Pipe - KDM AHP - TEP Ovcp w/ Turbo-Xs Bov - 14.5psi Boost Restrictor Pill - 1G Maf - Delphi Injectors - GM 110 Alternator - Optima Red Top - Dual Charging Wire - MK1 EGR Block Off - Accel Yellow Coil - Anti Roll Over Valve - Eibach Lowering Springs - 8 Way Front Struts - Kyb Gr2 Rear Struts - Stebani Short Shifter - 89 ECU - 89 Airdam - 89 Starion Rear Shoulder Belts - 89 Rear Seats - 83 Stallion 2 Piece Pulley - Rodded Radiator - Wix Oil Filter - Rotella T6 5w40 Full Synthetic.
#2 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 20 October 2010 - 03:58 PM
It is a little over 950 x xxx. I resize everthing to 950 wide before i upload them.
