Is an 86 to 89 ECU upgrade worth it?
10 replies to this topic
#1 fang988
fang988
  • 209 posts
Posted 30 August 2016 - 11:54 AM
Im still a noob. Sorry, it wont let me post in the noob section.
So i am about to purchase an 89 ECU, but i sudden'y remembered swapping this ECU will not be as easy as an 87. So i took the the forums ans found this post. http://www.starquest...howtopic=28050.
They talked about doing this swap but never answered some important questions. Will i need to get the 88-89 injectors? what kind of performance gains will this net? Is it worth it?  Can someone also explain what exactly was written down for the diagrams that were listed, they look like hieroglyphics on my device.
#2 speedyquest
speedyquest
  • 4,152 posts
Posted 30 August 2016 - 12:03 PM
I'm by no means an expert but here are my thoughts.
You will definitely need 87 or higher injectors if you switch to the 88-89 ecu. The reason for this is that 86 and earlier used two injectors that are the same size and they take turns firing. Later models use a small and large injector that turn on and off based on load and rpm.
As for what kind of performance gain you can expect, right off the bat not much. What swapping the ecu will do for you is give you better fuel maps. So if you will only be changing your wiring and ecu no you won't get a sudden improvement.
Lastly you need to understand that swapping from the 86 and earlier fuel setup and the newer 87+ setup isn't a simple matter of just swapping your ecu. The wiring harnesses differ, you will need wire in different sensors and modify your cars harness. Unless your comfortable with wiring and have a fair knowledge of the wiring diagrams of the car you will have quite the road ahead of you to finish this properly.
Whatever you decide good luck!
#3 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 30 August 2016 - 12:27 PM
with the 86 ecu system you can only get about 12psi before you hit "fuel cut" but the 88-89 systems can get up around 18psi i believe so you would be able to run more boost so you would see a improvement that way. but 12psi is about what i would call the limits of a stock 12a turbo, maybe 15psi if you were at the track or something.
also with the 88-89 system you would be able to use a MAFT.
2005 Acura RL SH-AWD
#4 fang988
fang988
  • 209 posts
Posted 30 August 2016 - 02:42 PM
So would getting an 87 - 89 wire harness solve most of the hassle?
#5 speedyquest
speedyquest
  • 4,152 posts
Posted 30 August 2016 - 03:03 PM
Not really. Its a great start though because you'll need plugs and wiring from it.
#6 creakyjoints
creakyjoints
  • 1,939 posts
Posted 30 August 2016 - 03:33 PM
MAP sensor for 86 I understand is no longer available. That is a very good reason to switch. You could also use 87 parts to do the same.
#7 scott87star
scott87star
  • 4,999 posts
Posted 30 August 2016 - 04:45 PM
Just go straight to a standalone, by the time you work out all the details you still have a prehistoric ECU that you can't tune and standalones have gotten very reasonable.  I sell them but if I didn't my advice would be the same and you certainly don't have to buy one from me.  Dealers are everywhere.
#8 importwarrior
  • 18,295 posts
Posted 30 August 2016 - 07:43 PM
you can get it from another source but if you get an aftermarket ECU from Scott you will get support from scott better then any other place.
#9 fang988
fang988
  • 209 posts
Posted 30 August 2016 - 08:48 PM
Yeah, my plan was to get my car running right first. Use my MPI moddified stock intake mani with one of your kits and then upgrade that intake mani to another one some time in the future. What kind of work needs to be done to run one of your megaspuirt kits on an 86?
#10 scott87star
scott87star
  • 4,999 posts
Posted 31 August 2016 - 01:23 PM
Is your wiring in good shape?  I've done a couple of 86 plug and play systems.  It just changes where the IAT is pinned into the harness which is invisible to you.
#11 fang988
fang988
  • 209 posts
Posted 31 August 2016 - 06:06 PM
Not sure. Ill contact you when i am financially able to move forward. (may be a while) I decided that i will just deal with the 86 ecu untill i am able to run MS.
