Killaphil HX35 Dyno
FunkLab Meth Injection HX35 Megasquirt
53 replies to this topic
#41 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,211 posts
  • Interests:I have an announcement to make, "Turbo........ That is all".
Posted 13 July 2015 - 04:41 AM
^ I intend to find out. I'll say my 84 made 171 whp and 198 wtq on a mobile dyno at Factory MOD 2012 on about 10 psi, really heat soaked (car sat idling for atleast 30 minutes before making the pull), on a stock size TB, ebay wastegate, and not revving past 5000 rpm (with a schneider 296 cam). I know this will sound like I'm making excuses for it, but, this same dyno said a high 11 second 1G DSM was making ~250 whp. So who really knows how accurate it was.
That being said, when the car is running again it will be on a LSP 52mm TB, 2 x 120lb injectors, and E85. Then I'll crank the boost up to where the HX35W really starts to get into its efficiency range and see what it does.
Also great job on the build! :)
Posted Image   1984 Starion ES: Currently running 15psi, Stock block (ARP main and head studs rod bolts, Clevite bearings) BSEK, M28 NJV head with mechanical valve train gasket matched on intake and exhaust, Treadstone exhaust manifold and Holset HX35w with BEP turbine housing, MK1 3" stainless exhaust, Old skool HKS super BOV, 3" GM MAF with MAFT, Artinist's old 4" core intercooler, custom Aluminium hard pipes, S13/SR20 Aluminium radiator w/clutch fan, Innovate LC-1 wide band O2, `83 crank pulley with A/C removed.
   `88 5 speed trans with Stedbani short shifter, Stedbani poly trans mount and engine mounts, drilled and slotted rotors, Joly roger stainless steel braided lines(brake, clutch, oil cooler, and ABS delete).
   KYB GR2, Artinist sleeve coil-overs, MK1 poly bushings, Energy Suspension poly end links, MK1 Adjustable tension rods, Cusco front camber plates, Artinist slotted rear camber plated.
ABS, A/C, Cruise control.. deleted, Right hand drive E-brake handle.
... more to come
Feedback:
Feedback thread #1
Feedback thread #2I'm PayPal Verified
#42 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 23 October 2016 - 05:33 PM
Welp, new #'s are in
14psi pull
Here is the clutch slip
Build post is here
http://www.sqperform...hp?topic=237.30
#43 importwarrior
  • 18,111 posts
Posted 23 October 2016 - 06:04 PM
Great numbers.
I have seen the fluttering on the graph happen because the wastegate is opening and closing basically fluttering fast.
#44 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 23 October 2016 - 07:58 PM
Thats exactly what it doing. The spring in it is too small.
#45 Bradrock
Bradrock
  • 896 posts
Posted 23 October 2016 - 07:59 PM
How much boost on the 404.24 HP run?
I'm 417 area code. I'll have to look up Miller Mo. for when I have a Starion ready to tune.
Run's with scizzor's
#46 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 23 October 2016 - 08:13 PM
The 4-4500 swings are the clutch though. The pull right after that, the clutch completely let go.
#47 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 23 October 2016 - 08:18 PM
That was 24psi on 91oct with VP Octanium additive.
AFR's were 10.8-11.2 throughtout the pull. Theres a decent amount of power left on the table, with the safe tune, boost control, and slipping clutch. I could see it making another 20-30whp if I got a little more aggressive with it.
I live up near KC. I use the dyno in Miller. Super cool guys there.
#48 G54Bstore
G54Bstore
    SQC Commander
  • 5,129 posts
Posted 24 October 2016 - 02:41 PM
I'm loving the hx35 since I installed it but I had to fab up my own drain line cause I can't find any that are 7/8 Id or so.
Smoked under boost. 18 psi makes this thing a rocket. I need more fuel or octane:P
W18 Rocky White Starion
Daily Driver
#49 Mach 5
Mach 5
  • 502 posts
Posted 29 October 2016 - 04:13 PM
sweet!!
Owner and Founder of Triple R Motors aka Radical Rev Race Mods- Jarek-
-Rides-
-1987 Starion -Midnight Star - Build Progress see link
http://www.starquest...howtopic=152434
-1989 Chrysler Conquest-Track Beast Mode gtx3071r TBI 365hp 407tq @20psi- RIP
http://www.starquest...ic=151885&st=40
-1989 Pontiac Grand Prix Turbo SE- 3.1 gt4088r getrag284 Tilton twin disc
-1991 Toyota Hilux Pickup 1uz itb cp pistons kelford cams TripleR head porting/ long tubes
-1990 McLaren Turbo Grand Prix sold...
-1985 AE86 20v.. 171hp@ 8200rpm RIP
#50 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 01 November 2016 - 01:04 AM
Drill them out
#51 importwarrior
  • 18,111 posts
Posted 01 November 2016 - 04:52 AM
PHIL What A/R did you run ???
#52 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 01 November 2016 - 10:05 AM
Stock divided. 12cm I think?
#53 G54Bstore
G54Bstore
    SQC Commander
  • 5,129 posts
Posted 02 November 2016 - 01:34 PM
View PostFunky Phil, on 01 November 2016 - 01:04 AM, said:
Drill them out
Made a flange with a 1 inch pipe and hose for the drain.Like Trump says "It's huge"
Daily Driver
#54 Funky Phil
Funky Phil
    Super Pooper
  • 6,413 posts
Posted 02 November 2016 - 02:20 PM
Well then,"it'll be great!"
Also tagged with one or more of these keywords: FunkLab, Meth Injection, HX35, Megasquirt
