G54B MPI EFR 7670 with T-56 Magnum build (w/ megasquirt)
47 replies to this topic
#1 damannm
damannm
  • 61 posts
Posted 16 March 2017 - 04:23 PM
I've held off on posting til I was closer to reassembly. I am mid teardown currently and just received my T-56. I will be using Bill bellhousing. I will be using Gato performance's MPI manifold, JDL design T4 divided top mount manifold, BW EFR 7670 turbo, 1K CC injectors. I will update this thread with pictures once I get home. Consider this a placeholder for things to come.
I aim to give a good detail of the tunnel modifications required for the G54B with a T-56 Magnum. I will include as much detail as possible to help future mods out. I will be using the fidanza flywheel for use with GM 10-10.4" clutches. I will give a detailed account of the measurements for those and correct hydraulic release bearing.
I expect to have a running car before the middle of next month.
Pictures will be added here:
http://imgur.com/a/RRKOH
Edited by damannm, 16 March 2017 - 08:29 PM.
#2 Chad
Chad
    noob
  • 9,182 posts
  • Interests:Starquest Fanatic
Posted 16 March 2017 - 06:40 PM
If you use a 3' socket extension to reach the top transmition to bell housing bolts, you only need to massage the passenger side of the tunnel over about 1/2 "
#3 damannm
damannm
  • 61 posts
Posted 16 March 2017 - 06:59 PM
Thanks for the info Chad. I will let you know how it goes.
#4 Chad
Chad
    noob
  • 9,182 posts
Posted 16 March 2017 - 07:04 PM
You have to loosen the motor mounts and tip the engine with a jack on the front pulley to stab the inputs haft into the clutch, but the pass side is the only place it hits the tunnel.  There are a few casting stubs to cutoff, and a sensor for the class or whatever it's called.
#5 damannm
damannm
  • 61 posts
Posted 16 March 2017 - 08:31 PM
Added imgur link where I will place all pictures.
#6 fang988
fang988
  • 209 posts
Posted 16 March 2017 - 10:25 PM
Nice
#7 Blackmount
Blackmount
  • 78 posts
Posted 17 March 2017 - 11:27 AM
I have a nice Conquest Shell I'll trade you with the tunnel cut, and professionally welded for a T56 :D Stock interior fits well even.
#8 creakyjoints
creakyjoints
  • 1,921 posts
Posted 17 March 2017 - 03:49 PM
Thought his bellhousing used g54b flywheel/clutch setup.
#9 damannm
damannm
  • 61 posts
Posted 17 March 2017 - 04:37 PM
Uses either.
#10 GINASQ
GINASQ
  • 942 posts
Posted 31 March 2017 - 06:58 PM
Any update?
-James
#11 damannm
damannm
  • 61 posts
Posted 08 April 2017 - 02:46 PM
Sorry about that, YES! I am waiting on bills bell housing and motor mounts.  Last weekend I got the front suspension rebuilt and new bearings installed. I have a few things coming in. Its spring break so I am unable to do more work on it until next weekend.
1. AiM MXS Strada. I will be using this old cluster housing and some 1/4 in. Plexiglas to get it mounted. It will fit perfectly inside the cluster hood and should look like it is supposed to be there.
2. Fuel Pump and fuel pump accessories (going to use an AEM fuel pump)
3. Bills bellhousing and motor mounts. He should be finished shortly. (I have already received the clutch I will be using)
4. The new turbo manifold.
#12 Chad
Chad
    noob
  • 9,182 posts
Posted 08 April 2017 - 05:46 PM
You using an internally gated turbo on that?  If so,why get the divided model?  Is it stainless? the color in the collector doesn't look right for stainless, which has a slight yellow hue.  A magnet check will tell.  Magnets won't stick to 3xx series stainless.  It looks nice.
#13 damannm
damannm
  • 61 posts
Posted 08 April 2017 - 06:35 PM
Chad the integrated WG on the EFR B frame series is 42 or 44mm. It is way more than the engine needs to regulate boost pressure. Plus the non-internal WG version has a larger A/R. I wanted to make sure I get a quick spool still.
The manifold is from JDL. He posted here what he uses. Which according to the site is schedule 40 stainless.
#14 damannm
damannm
  • 61 posts
Posted 08 April 2017 - 06:40 PM
Here is a better picture with flash.
Edited by damannm, 08 April 2017 - 06:41 PM.
#15 Chad
Chad
    noob
  • 9,182 posts
Posted 08 April 2017 - 07:52 PM
I knew they made them, but I've never seen a divided internal T4.  I think it was for a diesel application and the WG was a proppet type with a v-band connection on the side of the turbine.  42-44 mm should be plenty.
Yah, you can see the difference in color, the lower port on the left side, it's just a silver color on the steel flange, and the runner on the left side of the collector wall is a little yellow.
#16 tsi_tom
tsi_tom
  • 2,249 posts
Posted 08 April 2017 - 07:59 PM
That's the manifold I'm going to get.
Engine
20 over forged pistons
Stock injection system
#17 damannm
damannm
  • 61 posts
Posted 11 April 2017 - 07:42 PM
Here is the new dash.
#18 importwarrior
  • 18,153 posts
Posted 12 April 2017 - 04:31 AM
that is cool looking. i thought it would be bigger.
#19 damannm
damannm
  • 61 posts
Posted 12 April 2017 - 05:52 AM
It has a 5 inch screen.
The larger 7 inch model would not have worked with my plans. Not to mention since it is a full data logger also they cost about 1300 dollars more....
#20 88351wtsi
88351wtsi
  • 965 posts
  • Interests:My kids, music, and cars, not always in that order.
Posted 12 April 2017 - 07:28 AM
That's what she said.  Sorry couldn't resist
Nice work man. Can't wait to see the finished product
1988 Conquests
His:  Durban maroon with 351w
