B00sted VR-4 Posted October 27, 2009 Report Share Posted October 27, 2009 Looked and hadn't found any. I know the old 4G63 is not a bad setup, but I like the plug and play and easy flashing you can do with the Evo engine. So many solid setups. Has anyone done this? I'd like to. I was going to do a 5.3 swap, but I think I want to take the car out to the road course as well. 5.3 would really hurt handling unless it was done very extensively. Link to comment Share on other sites More sharing options...
spoolinturbo Posted October 27, 2009 Report Share Posted October 27, 2009 just the evo 8 engine has been done that i know of. know evo 9/10 that i know of Link to comment Share on other sites More sharing options...
Technology Posted October 27, 2009 Report Share Posted October 27, 2009 you can't group 9's and 10's together, they are completely different. Only similarity is that they were made by mitsu and have awd. If you want to do the swap, why not get a 6 bolt out of a 1G and wire in an evo8 ecu. it's been done and works. And it's cheap. Link to comment Share on other sites More sharing options...
cali Posted October 27, 2009 Report Share Posted October 27, 2009 if you're looking for the simplicity of flashing, you can use the evo 8 ecu with a dsm 4g63... that's the setup im finshing up. Link to comment Share on other sites More sharing options...
B00sted VR-4 Posted October 28, 2009 Author Report Share Posted October 28, 2009 if you're looking for the simplicity of flashing, you can use the evo 8 ecu with a dsm 4g63... that's the setup im finshing up. I did not realize you could. I was also just thinking of improvements over the years with the engine. I know the 4G63 from back in the day is nothing to scoff out, was just looking at dealing with stuff that is a bit newer. (IE: pick up a low mileage one and do an intake, downpipe, boost controller, and not worry about blowing it up at the race days over modding it for high hp) can't beat a stock engine at track days. It's the modded guys who always blow up. Link to comment Share on other sites More sharing options...
MainstreaM Posted October 28, 2009 Report Share Posted October 28, 2009 Bill just got done with an EVO rwd bellhousing. Check out projectzerog.com Kane Link to comment Share on other sites More sharing options...
cali Posted October 28, 2009 Report Share Posted October 28, 2009 I did not realize you could. I was also just thinking of improvements over the years with the engine. I know the 4G63 from back in the day is nothing to scoff out, was just looking at dealing with stuff that is a bit newer. (IE: pick up a low mileage one and do an intake, downpipe, boost controller, and not worry about blowing it up at the race days over modding it for high hp) can't beat a stock engine at track days. It's the modded guys who always blow up. a newer evo engine would be preferable, but you will run into a lot of fitment issues with the turbo on the driver side of the car...there's just not much room. a nicely built dsm 4g63 will make plenty of power either way. the plugs are the same from the dsm wiring harness to the evo ecu...you just need to jump a few wires but it's very minimal. im using one of bill's bellhousings (for the older 4g63) with r154 tranny....would highly recommend it as his work is flawless! http://img.photobucket.com/albums/v662/jdmgalant4g63T/100_2651.jpghttp://img.photobucket.com/albums/v662/jdmgalant4g63T/Starion%20Build/s63-1.jpg Link to comment Share on other sites More sharing options...
Cobalt60 Posted October 28, 2009 Report Share Posted October 28, 2009 Cali was your Quest a manual before the conversion? And if so, how hard was it to get the R154 to fit? Also, you still had to re-organize the coolant plumbing right? Link to comment Share on other sites More sharing options...
cali Posted October 29, 2009 Report Share Posted October 29, 2009 no it was a manual. im not gonna lie it was a bit of a PITA to get it to fit...i had to take the BFH to the tunnel a few times to make it fit right.I also had to move the engine forward 2". Link to comment Share on other sites More sharing options...
rosengrant826 Posted October 29, 2009 Report Share Posted October 29, 2009 sorry to jack, but what turbo is that Link to comment Share on other sites More sharing options...
cali Posted October 30, 2009 Report Share Posted October 30, 2009 PTE 6062 Link to comment Share on other sites More sharing options...
rosengrant826 Posted October 30, 2009 Report Share Posted October 30, 2009 thanks Link to comment Share on other sites More sharing options...
Bill Hincher Posted October 30, 2009 Report Share Posted October 30, 2009 Also, you still had to re-organize the coolant plumbing right? you change the flow of coolant in the headgasket to redirect the coolant forward and then use a front outlet, I have more details if you need themhttp://www.billsautofab.com/images/frontexitcoolingsystem.JPG Link to comment Share on other sites More sharing options...
juneauto1 Posted December 28, 2009 Report Share Posted December 28, 2009 Hey can you post more details and pix of your swap, I like a quality setup that i can learn from. I have 6 bolt 4G63 no car yet. Link to comment Share on other sites More sharing options...
screemin eagle Posted January 1, 2010 Report Share Posted January 1, 2010 they actually just figured out how to flash the 98-99 dsm ecu's so you dont even need to do an evo. BFH the crap out of the tunnel then install then remove to BFH more. mine still is tight with the r154 but it works and is ok for now. when i change my clutch im gonna open up the tunnel some more and make a better tranny mount cross memeber set up Link to comment Share on other sites More sharing options...
odee Posted January 6, 2010 Report Share Posted January 6, 2010 where might one find some info on adapting this evo computer or the newer dsm computers to the 4g63 setup? I'm wanting to put a 2.4 with the 2.0 head in my quest. Trying to figure out which wiring setup is goning to be the best. thanks Link to comment Share on other sites More sharing options...
