IntercooledFlatty Posted April 7, 2015 Report Share Posted April 7, 2015 (edited) This 86' Flatty started out as an automatic car so the trans tunnel is a lil larger than the 5 speeds. After several 2.6l set up's i got really aggravated and decided this will be the V8 swap i've always wanted to do. The cross-member was altered as well as the oil pan, but the stock steering is all in place, for now, with plans later down the road to do a rack. The motor mounts are solid, the trans mount uses the stock brace altered with a 904 insulated mount. Shifter is a B&M hammer. Rear end is stock with 3.90's. Exhaust is block hugger headers with true duals to the rear flowing through a 2 in/2 out muffler with a built in X pipe. The motor is a 67' 318 craigslist buy. I was told it had about 6 k on it and after opening it up it sure looks the part. It came with an Edelbrock intake and chrome valve covers, and supposedly an Edelbrock cam. Not bad for $150 bucks http://www.26liter.us/forum/Smileys/Lots_O_Smileys/thumbsup.gif it has 302 casting Indy heads with a comp cam xe262-he kit. Trans is out a 70 Dart built with a trans-go 2 kit, but changing to a full manual forward pattern. Ignition is a HEI set up vac. advance with MSD wires and coil. Carb. is a Holley Street Avenger, prob too big but i already had it. Mr. Gasket electric fuel pump with regulator that is using the factory hard lines to and fro adapted to steel braided lines. Air intake is a tube and a K&N. Cooling is handled by a 1/2JZ Radiator with dual 10" fans using a thermostat and override switch.Gauges are Autometer mechanical oil and water, and a monster tach with a shift light. I need to figure out a led light of some sort for when the fuel tank sender sends a low fuel signal that is about 5v if i remember correctly. I'm also looking to maybe do a volt gauge from .3v to 4.8v which is what the sender sends for full/empty or whatever the exact numbers are http://www.26liter.us/forum/Smileys/Lots_O_Smileys/laughing11.gifRear seat is eliminated and a box is in it's place to store the amps, wires, emergency stuff, etc. Edited August 4, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
speedyquest Posted April 7, 2015 Report Share Posted April 7, 2015 Do dat copy paste son Link to comment Share on other sites More sharing options...
screemin eagle Posted April 8, 2015 Report Share Posted April 8, 2015 That guy Gary keeps purging me. Can't be seein yo stuffs my ninja Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted April 9, 2015 Author Report Share Posted April 9, 2015 (edited) http://i154.photobucket.com/albums/s263/aiche_photos/Olive/DSC09861.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/Olivelkdjlakj_zps63dbc37f.jpgheading to the paint shophttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/IMG_20130726_110351_458_zpsc0fdc372.jpg Edited August 4, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted April 9, 2015 Author Report Share Posted April 9, 2015 (edited) http://i154.photobucket.com/albums/s263/aiche_photos/Olive/GuideCoat_zpsb0d6de18.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/cured_zpsa0b76dd5.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/IMG_20130827_203359_107_zps6567b5d2.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/IMG_20131117_114229_572_zps481ddfe7.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/roll_zps4613d93c.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/Sealer_zps21bcd1e1.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/paint_zps0384d1dc.jpg Edited August 4, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
speedyquest Posted April 9, 2015 Report Share Posted April 9, 2015 Post dat contentz hur! Link to comment Share on other sites More sharing options...
screemin eagle Posted April 10, 2015 Report Share Posted April 10, 2015 I try but I never get the email approvals. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted April 10, 2015 Report Share Posted April 10, 2015 Hood spacers are winning the show ! Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted April 13, 2015 Author Report Share Posted April 13, 2015 (edited) http://i154.photobucket.com/albums/s263/aiche_photos/Olive/paint6_zps57b59cf0.jpghome http://i154.photobucket.com/albums/s263/aiche_photos/Olive/home_zpsaf06994b.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/DSC01266_zps4e43915b.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/DSC01272_zps9bb012ec.jpghttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/DSC01282_zps38039d1b.jpg Edited August 4, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted June 17, 2015 Author Report Share Posted June 17, 2015 http://i.imgur.com/7IXF2gV.jpghttp://i.imgur.com/nUCHclc.jpghttp://i.imgur.com/WLbULW5.jpgyo B, what do you think ?http://i.imgur.com/8PgIxVq.jpg Link to comment Share on other sites More sharing options...
slowquest Posted June 17, 2015 Report Share Posted June 17, 2015 I asked a question over on 2.6, but haven't seen a response yet..... I'll ask again here. What, if anything, did you do to the crossmember and what oil pan did you use? I've currently got an LA sitting in one and can't get it back as far as i'd like, due to the pan hitting the crossmember. I'm using an early 70's car center/front sump pan. Looks easy enough to get the clearance, but thought i'd ask someone who's been there. Link to comment Share on other sites More sharing options...
GINASQ Posted June 18, 2015 Report Share Posted June 18, 2015 I got the same issue as far as signing up again. Can we get that content though? Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted June 23, 2015 Author Report Share Posted June 23, 2015 I was hoping to get pics and post em for you doods but things have been crazy the last 6 months. i'm still not finished with her as i need to change the idle arm bushing and put in the manual valve body. i've been showing her but really haven't driver her much, she is quick we cut the cross member, angled it back around the pan using 2x3, and modded the pan like project conquistador using the half round pipe but i really think the pan didn't need it, it would have been close tho. with solid mounts ( truck mounts ) nothing is going anywhere. the headers are summit block huggers with the #7 modded to fit around the steering box. easy fix. the motor is as far back as we could get it with enough room for the dizzy. it also sits nice and low with the cross member out of the way. i built this to have fun as a street cruiser, cruise night, something different toy, BUT, if i were to do another , i will definitely cut the fire wall and run a rack and full length headers. found onehttp://i154.photobucket.com/albums/s263/aiche_photos/Olive/ready_zpsf9067bb4.jpg Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted June 23, 2015 Author Report Share Posted June 23, 2015 (edited) http://i.imgur.com/knRCmHf.jpghttp://i.imgur.com/GCzbAvt.jpghttp://i.imgur.com/apn8qgK.jpghttp://i.imgur.com/Uihimbi.gifthe Dood approves http://i.imgur.com/cSsPifs.jpghttp://i.imgur.com/lq2pX9r.jpghttp://i.imgur.com/eo00WGa.jpg Edited August 4, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
slowquest Posted June 23, 2015 Report Share Posted June 23, 2015 (edited) How are the solid mounts? I've tossed around that idea a lot, but can't pull the trigger on it, afraid of it being too harsh. I already cut the crossmember and doesn't look like i'm going to have to mod the pan any. Only issue is the drain plug being on the back of the sump is VERY close to the crossmember now. Also, I know yours was an original auto car, did you have to clearance anything at all? Mine is a manual, and the 727 seems huge sitting in there. Hits in multiple places. Edited June 23, 2015 by slowquest Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted June 24, 2015 Author Report Share Posted June 24, 2015 no prob with the solid mounts. i actually love feeling everything and it rides nice too. kyb's all around with eibach's and poly bushings. we moved the drain plug i cut some of the extended mounts on the trans body that the factory uses ti lift/move them around so it fit much better but there was one spot of the tunnel i used a bfh to massage it in. i run a 904. it's tight in there with the dual exhaust http://i154.photobucket.com/albums/s263/aiche_photos/Olive/olivemorotin2_zpsd5da8ce9.jpg Link to comment Share on other sites More sharing options...
natedog_37 Posted June 25, 2015 Report Share Posted June 25, 2015 Nice. There was a artical some where on the net that showed how to install a 360 with little work. Always wanted to do it. Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted July 16, 2015 Author Report Share Posted July 16, 2015 (edited) http://www.flickrive...ics/3622284792/ http://starquest.i-x.net/viewtopic.php?t=799&sid=556074df0bdc02c0077cc87ca7632329 Edited July 16, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
Crazy larry Posted July 16, 2015 Report Share Posted July 16, 2015 Were is Ted Wagners 340 beast? Flatty Mopars Rule!!!! Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted July 22, 2015 Author Report Share Posted July 22, 2015 Were is Ted Wagners 340 beast? Flatty Mopars Rule!!!! it was at Carlisle not too long ago, and i agree on the flattyZ Link to comment Share on other sites More sharing options...
slowquest Posted July 26, 2015 Report Share Posted July 26, 2015 http://i154.photobucket.com/albums/s263/aiche_photos/Olive/DSC09864.jpg any chance of getting a better pic of this area? Mainly the header mod. Link to comment Share on other sites More sharing options...
440Quest Posted July 26, 2015 Report Share Posted July 26, 2015 Very nice. I am planning a 408 stroker swap. Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted August 4, 2015 Author Report Share Posted August 4, 2015 (edited) hangin' out with some Moparshttp://i.imgur.com/tCPPqxq.jpghttp://i.imgur.com/b8HxBfR.jpg Edited September 29, 2015 by IntercooledFlatty Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted September 30, 2015 Author Report Share Posted September 30, 2015 http://i.imgur.com/WrOHddR.jpg Link to comment Share on other sites More sharing options...
jdl007 Posted October 5, 2015 Report Share Posted October 5, 2015 Did you have to raise the center section of the hood to make clearance for the carb and air filter ?? I have the Ford small block with injection, and would like to go with carburation. But not sure it will clear a stock 83 hood ?? Thanks..........Jerry- Link to comment Share on other sites More sharing options...
