Here you can see what I saw as I opened the garage when I got back from China after 7 weeks (I didn't leave the hood open the whole time, lol)
http://www.mitsustyle.com/photopost/data/529/medium/DSC01311.JPG
My first goal was to remove the stock engine wiring harness which I had a little bit of a hard time doing, but as you can see here, it was a success.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01319.JPG
The hard part of wiring harness removal is not the engine bay side, it's under the dash. Unless you have magic skills, you need to remove the blower motor. I should elaborate a bit on this since I had a question about it. There are three big bolts, plus the alignment ring which holds the blower to the A/C box. That has one phillips head screw. the hard-to-get-to bolt is above the alignment ring thing at the top left side of the blower, against the firewall. it can be removed without pulling the dash, as you can see in this picture, but you have to fanagle it, and I scratched the plastic housing a bit, but since no one will ever see it anyway, that doesn't matter.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01322.JPG
And this doesn't look like much but it's the top corner under the dash on the firewall - the hole where the harness used to come through. If you ever want to do a stealthy wiring setup, this is the place to go through.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01321.JPG
Here's the driver's side before harness removal, you can see the brake booster and related stuff is gone. All for ABS removal.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01312.JPG
The battery area after harness removal. Cleaning will ensue. I found the skeletal remains of a mouse that had stolen some of my hood insulation and made a nest behind the battery. I had seen some of it like when I bought the car, so I think it's been dead and riding for free since before I got it around 2002, lol.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01315.JPG
And here is the real performance machine. They don't make 'em like this anymore.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01323.JPG
I'll keep updating this thread with pics as I go. I got the intercooler mounted back in place and I need to install the brake booster, master cylinder and lines. I eliminated the ABS as well.
Edited by Technology
I got to do some more work today.
I put the brake booster back on:
http://www.mitsustyle.com/photopost/data/529/medium/DSC01340.JPG
Then the master brake cylinder, hey look, a 12mm end wrench!
http://www.mitsustyle.com/photopost/data/529/medium/DSC01341.JPG
Got the brake lines attatched - that is the <2 dollar ABS elimination kit.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01342.JPG
Then I cut the bumper support for I/C pipe clearance:
http://www.mitsustyle.com/photopost/data/529/medium/DSC01343.JPG
Here's the whole thing.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01344.JPG
Test fitting for the fuel rail. Dang it'll be tight in there, but I've got it figured out.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01345.JPG
See this? good thing the engine doesn't move back and forth!
http://www.mitsustyle.com/photopost/data/529/medium/DSC01347.JPG
I need to change my underwear:
http://www.mitsustyle.com/photopost/data/529/medium/DSC01349.JPG
I tightened up a bunch of stuff, cleaned here and there. I have to get the basic mechanical stuff done, like bleed the brakes get the intake on, sensors in, hoses and fittings for coolant done, then once that's all done I will start with the wiring harness stuff. that will be just great fun. so far the only things I need done by someone else are the cam angle sensor machined and the fuel line built.
Oh yeah, I took off the pedal extensions on the go kart and the thing hauls, but I discovered that at one point the exhaust broke off or something and was re-welded, but 180 degrees off, so the flange bolts on, but half of the exhaust port is just venting to atmo. I did a temporary fix for me and it got a little more quiet. and it needs new bearings for the front wheels, and some frame adjustment, oh well. still fun.
  • Like 1
That looks like a nice clean install. You should rotate the fuel line 90* so it fits in the round groove. That will help hold it in place and give you the needed room at the heater hose. You can also rotate the throttle cable tube downward to help with the angle when you attach it to the TB...just route the cable to come up alongside the manifold and hook it up.
Thanks for the tips, I figured out what I'm going to do with the fuel line - since both ends are banjo style, I was going to get a new line made with the stock ends for both magna and quest, but when looking, I found that they aren't bent the same, when I use the quest end on the fuel rail, it shoots back along the rail and the magna end puts the line exactly where I want it. So I'll do that, and there won't be any problems.
The reason I didn't put it in the "holder" thing was because when it was in there, it bumped into the power steering line.
As for the throttle cable, thanks for that idea also, but what can I do about the TB? the rotor is basically upside down, and will need modification to work.
Lol, I will make new power steering lines..... someday. Lemme find a job really quick though, then I will do more stuff. And I decided to keep the heater.
Got my fuel line done today, btw. Hey emagdnim, what CAS did you use? 90 or 91 style (with or without pigtail)? And what are you holding it to the head with? friction?
Dude.. wt.... is all that crap in the engine bay?
I know it's not your daily.. rip that crap out man.
Make new fuel lines while your at it.
I want to see YOUR engine bay and see how clean it looks
test fitting the fuel rail with custom line made up
http://www.mitsustyle.com/photopost/data/500/medium/DSC01357.JPG
Got the manifold bolted up with gasket and rtv.
http://www.mitsustyle.com/photopost/data/500/medium/DSC01358.JPG
New brake booster hose, and 750cc trilogy injectors.
http://www.mitsustyle.com/photopost/data/500/medium/DSC01359.JPG
Look what I got machined to fit... Oh it's snug, now I need to mod the camshaft. What a money pit.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01360.JPG
It's dark, but you can see, with the fuel rail and cas so close to the firewall, I better not have any front-to-back movement.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01361.JPG
This is kindof what it'll look like, you can see the sending and return fuel lines all in place, the dip stick tube bent and in place. I'm getting anxious to get this package with two sensors, I have to get some kind of tube for the coolant to go under the intake manifold. I had to leave my car today because I'm at an impass - I need to get my cam modded and installed, need to figure out how to hold the CAS in place, need to get the last couple sensors installed and when all that fun stuff is done, I have to figure out the wiring harness.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01362.JPG
Rotate the elbow for the throttle cable downward then it reaches the TB easily.
Just a few more things.
Now lets see your engine bay, yours must be really sweet.
Soon.Soon.Probably painting it in a week or so.
Im just saying you were ragging on my thread before and didnt give me any help to get rid of anything
I wasn't ragging on you, Hell I was seriously confused what all that crap was.
You should post pictures of your engine bay when your done with it.... Because I'm not done with mine yet, and I felt like putting the pics of its current progress was cheating on it.
Hopefully you'll step your game up before trying to call people out. :wink:
Oh, and BTW.. I'm allowed to rag on tech.. we have an understanding of R04ness... so try not to get to offended when I'm talking to him.
I can't wait for your show and tell thread.
Here's some more from today. I'll be moving my car closer to me in a few days so I'll be able to get'er done faster. yeah I said it.
This is the water neck base arear and wouldn't you know it, Chad, the man had these holes tapped for 3/4" pipe thread, and lo and behold GM made their sensors 3/4 pipe also!!!! My mind was blown when it all worked perfectly after I guessed which sensors to get.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01369.JPG
Here you can see I've ghetto rigged the throttle cable so it stays. That's what those stock-reusable zip ties are for, I tell you!
http://www.mitsustyle.com/photopost/data/529/medium/DSC01370.JPG
Here I did some goofy stuff. I rotated the throttle cable down like I was told and wow, that works great, puts it right where it should be, and the heat wrap keeps the cable from rubbing on the powersteering box, which it does indeed touch. Then I tried to figure out how to go about fitting the coolant hose for the heater core. It was running into the fuel rail so I thought, well, the thing must be like a little radiator, and mitsu would have been retarded to make it flow only one direction, so I switched the hoses. Now coolant will flow the other direction through the core. And everything back there is happy now and doesn't rub anywhere.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01371.JPG
Sorry for the blurry image, I just didn't want anyone to see the brand of my 5 bar MAP sensor. (yeah, it's mounted to a wiring harness branch but it won't get any big shocks from bumps in the road.)
http://www.mitsustyle.com/photopost/data/529/medium/DSC01372.JPG
And here I reused those nice little twist-holders to keep the vacuum line for the FPR close to the fuel rail. Things will get tidied up when I get it running.
http://www.mitsustyle.com/photopost/data/529/medium/DSC01373.JPG
But it keeps getting closer and that makes me happy. It's getting kicked out of its current storage spot because it takes up too much (otherwise empty) space and that is too much for the g-parents to handle. Oh well.
i might be wrong cause i've never taken apart or even seen how the heatercore in our starquest work, but i think if you reverse the water lines, your gonna let the hot water into you heater core, bypassing the valve on the other side and its gonna be pretty warm in your car when the engine warms up. i might wrong so someone check me on this. the valve stops the hot water from coming in on one side. if you switch them around, then there is nothing to stop the water from going through the heater core. now the water goes through the core and stops at the valve at the other end. i tihnk... :-k
Oh, well then if that's true, I'm screwed. Maybe I should just gut the dash and remove the heater core. It's the popular thing to do these days. Or maybe I could re-route them again, but it's so convenient this way.
Well, I looked up heater cores and saw that there is a valve inside, but also usually a box, and I'm sure our's has a box around it. Even if it flows backward, if the valve is closed, it won't really circulate it too much, so it might get hot, but not too bad. Oh well, we'll see. I kinda want to gut the dash anyway.
hey did you have trouble with only getting like two threads screwed down on this? the part I got has thread higher up on the screw leaving only room to get a few threads on. Just wondered if you had same issue.... yours looks like it didn't get good threadage. I got line at Napa
So the zip tie is what's holding the stock cable end on.
I have a TB just like yours.Scored it for $5 with tps.Then realized the rotor was all backwards conpared to others I seen here.Mine come off a 4.6 T-bird.The throttle cable comes at it from the front of the car.
I was just gonna get a universal throttle cable kit and make it work on the return spring hole.
But I am a long way from that yet.Don't have a Magna yet nor a running motor.
Yes;zip tie rule.My work place would fall apart without them.
Mine was threaded enough, I was able to tighten it plenty. I don't think it will have any problems, but one reason for the ABS elim is the master cyl was leaking last fall, so I got a new-used one and I wanted to see where most of my brake fluid had gone since I couldn't find a puddle. I took off the booster to empty it, thinking it had gone in there, but there was nothing in there, I dunno.
EDIT: it doesn't work like this, you have to cut off one end and put stock ends on and reflare the line.
Edit #2: the master cylinder was leaking, a new one fixed the problem.
