TopDawg_43 Posted May 20, 2014 Report Share Posted May 20, 2014 I think my ignition switch has gone out on me, causing me years of heartache. I'm thinking it's easier to by-pass that too, as appose to fixing it. Anybody have any experiance with one of those EBay starter button kits? At the same time, I'm considering a Painless Wiring kit. Any input would help. TD_43~ Link to comment Share on other sites More sharing options...
scott87star Posted May 20, 2014 Report Share Posted May 20, 2014 I put a switch and starter button in a guys car awhile back, just parts from the electronics store although the momentary starter button has to be rated for several amps. Worked great. You can use a three way toggle for the off, accessory and on part, then just push the button to run the starter. Link to comment Share on other sites More sharing options...
TopDawg_43 Posted May 21, 2014 Author Report Share Posted May 21, 2014 (edited) Found this on eBay. I think it'll get me. http://www.ebay.com/...984.m1423.l2649 Just gotta figure out where I'm gonna mount it. Edited May 21, 2014 by TopDawg_43 Link to comment Share on other sites More sharing options...
vbrad511 Posted May 21, 2014 Report Share Posted May 21, 2014 Changing the electronics end of the ignition switch is easy. 2 or 3 small screws separate it from the cylinder housing, and a wiring plug. The whole thing wouldn't take 30 minutes, including dropping the tray under the column. Link to comment Share on other sites More sharing options...
markhansenconquest Posted May 23, 2014 Report Share Posted May 23, 2014 like brad said.. fix the one u got.......some one got one n here......... Link to comment Share on other sites More sharing options...
TopDawg_43 Posted January 22, 2015 Author Report Share Posted January 22, 2015 Just FYI for whomever may run into this problem. The issue was with the ground. I think I lost some of the ground, when I moved the battery to the trunk. I got a ground wire kit, and installed it. Problem gone, starter works perfectly. Link to comment Share on other sites More sharing options...
ucw458 Posted January 22, 2015 Report Share Posted January 22, 2015 The engine needs a 4 ga chassis ground. Many forget to do that when they relocate the battery and remove the stock cables. Also many have used the wiper cancel button as a starter button. Link to comment Share on other sites More sharing options...
