1st Gen. Eclipse CD/Tape/AMP install Procedure.
9 replies to this topic
#1 Juggary
Juggary
  • 258 posts
Posted 15 May 2002 - 11:03 AM
Here is a step by step instruction for anyone who wants to install the 1st Generation Eclipse (90 thru 94) stereo with CD, Cassette and Amplifier on there StarQuest.
1.   Remove StarQuest stereo system from car.
2.   Install the StarQuest mounting brackets on the eclipse stereo system both CD and Cassette player.
3.   For 87 thru 89 models, remove the (2) screws that fasten the seat belt controller.
4.   The carpet is already cut in the stereo compartment just move the carpet toward both doors.  This
will provide room underneath the plastic vent.  If carpet is not cut than cut a slit and move carpet away.
5.   Manuever the harness cable to the side of plastic vent.  The connector harness must be away from
center cause you will need all the room to fit the amplifier there.
6.   Push and squeeze the seat belt controller underneath the plastic vent all the way in.  Remember there
should be no carpet there cause you moved the carpet away and all you should have is insulation.  The
seat belt controller should be as far in and flush to the plastic vent.
7.   Install the eclipse stereo system with the StarQuest front face plastic console, there should be (4)
screws.
8.   Connect the two amplifier connector to the eclipse stereo and manuever the amplifier and stereo into
the stereo location.  The connectors on the amplifier should be facing the fire wall.  This is a very tight
location. (DON'T  install all the way in cause you have'nt connected the stereo connectors yet.
9.   Now connect the (3) connectors and the antenna to the eclipse stereo system.
10. Make sure the amplifier is under the CD player and facing the right direction (Read instruction 8) and
butted up against the plastic vent right behind the seat belt controller and push stereo system as far back
as possible.  Make sure the seat belt controller wire harness cable is not behind the amplifier or else it will
not fit.
11. When eclipse stereo system is pushed as far in, there should be (1) hole per side on the stereo
bracket that will line up with one of the taped screws.  Install and fasten (1) screw for each side.  Then
screw the ground.
12. Walla, the eclipse stereo system with CD, Cassette, and amplifier is installed.  Now just re-install the
center console and covers.  Congratulation on installing the Eclipse Stereo System (Enjoy).
P.S.: Thanks to Paul, aka Paul87Quest for his help, buy giving me good instructions.
Regards,
Gerry (aka Booster & Juggary)
'88 SHP Starion with tan/black interior.
#2 NeedAStarQuest
NeedAStarQuest
  • 139 posts
  • Interests:The Quest for Boost
Posted 08 April 2003 - 09:22 PM
And the finished product.....
http://www.starquestclub.com/index.pl?boar...;num=1049854822
Thanks for the FAQ guys...and for anyone thinking about doing this..check out my pics...works great..props to Jugg and Paul for the directions!
Josh NeedAStarQuest
#3 UlrichWolf
UlrichWolf
    Mayhem....it's WHAT I DO
  • 7,087 posts
Posted 21 April 2003 - 11:50 PM
Will the DSM CDTape deck play a burned CD? (CD-R)
Tim
Oh what a tangled web we weave, when first we practice to deceive.
#4 Jeff_S.
Jeff_S.
  • 621 posts
  • Interests:87 black TSi
Posted 22 April 2003 - 12:08 AM
QUOTE
Tim
The stereo/cd/tape i have from a 92 stealth tt plays them.
I am pretty sure all the others do too.
#5 Guest_Paul87Quest_*
Guest_Paul87Quest_*
  • Guests
Posted 27 May 2003 - 07:55 AM
From my experience with the DSM player in my car, you will need to burn the cd at a lower speed...when I tried to burn at 8X, it would read error...when I burned 2X it worked....and this was with a Sony burner, and good quality media.  :-/
#6 Boosted88
Boosted88
  • 68 posts
Posted 21 July 2003 - 01:22 PM
Do you need the amp in order for the 1g stereo to work? also my 10 pin plug was cut so i am trying to re-wire a 1g dsm plug and they have different color wires. Anybody, HELP?
#7 Boosted88
Boosted88
  • 68 posts
#8 stariongirl
stariongirl
  • 551 posts
  • Interests:race prepped by skank and gutterboy
Posted 27 July 2003 - 07:22 PM
QUOTE
hello jeff s what items do i need to collect to use a 3kgt stealth stereo?
#9 Guest_Paul87Quest_*
Guest_Paul87Quest_*
  • Guests
Posted 06 April 2005 - 02:11 PM
AMP IS REQUIRED. No amp....no sound. Period. Also make sure you get the DIN plug connectors that interface the cd player and the amp.
#10 Stormhammer
Stormhammer
  • 113 posts
Posted 10 April 2005 - 06:11 PM
those pics are dead  :(
