jayro Posted August 11, 2010 Report Share Posted August 11, 2010 ok i was doint tps isc reset. and i put the mulimeter on the 20v setting. i put the prongs on terminal 3&4 and i got a reading of 4.23. i put it to terminal 1 and 2 and i got a reading of .69. so i used termial 1 and 2 and put the tps to .50 is this right? i chcked the ohm's of the tps and got 6.2k is this right?? Link to comment Share on other sites More sharing options...
Starfighterpilot Posted August 11, 2010 Report Share Posted August 11, 2010 (edited) Perhaps you should review the below link to find out how to do the TPS & ISC and what the acceptable results are. http://starquest.i-x.net/viewtopic.php?t=907 For What It's Worth. KEN Edited August 11, 2010 by Starfighterpilot Link to comment Share on other sites More sharing options...
nicksquest Posted August 12, 2010 Report Share Posted August 12, 2010 ok i was doint tps isc reset. and i put the mulimeter on the 20v setting. i put the prongs on terminal 3&4 and i got a reading of 4.23. i put it to terminal 1 and 2 and i got a reading of .69. so i used termial 1 and 2 and put the tps to .50 is this right? i chcked the ohm's of the tps and got 6.2k is this right??put the black on to a ground and the red one on the wire that is green w/yellow stripe and it should read between .48 -.52 i think! just did this last week. read what he^ said to it helps alot. Link to comment Share on other sites More sharing options...
