ScribeWorks Starion and Fire Arrow ChampCar Builds
Conquest Starion Chumpcar Road Race Endurance Build Thread Lemons Scribe Champcar Fire Arrow
43 replies to this topic
#21 Scribe
Scribe
  • 38 posts
  • Interests:Drag racing and Endurance racing
Posted 19 June 2017 - 07:09 AM
View Postcreakyjoints, on 16 June 2017 - 12:39 PM, said:
Hefty cage. Seems over kill to me for it's intended use.
The cage is definitely overkill for Chumpcar.  They only require about half the bars that are currently in the CAD model.  The CAD model is showing that the cage weighs 115 lbs.  We set a new goal to get the cage under 100 lbs, so we'll be doing a little bit analysis to see which bars are not helping as much as we think they are.  That said, our #1 priority is to make sure the cage is safe.  We will be renting seat time to other people at races in order to help keep race costs in check and we do not want anyone getting hurt in our car.
View PostFunky Phil, on 18 June 2017 - 11:27 AM, said:
You cant overkill safety.
Can you upgrade your turbine wheel? What are the specific rules regarding the turbocharger. The exhaust will be you biggest problem.
Rules say that a different/upgraded turbo would be 100 pts.  That said, if we were to upgrade the turbine, I'm not sure anyone would notice.  The tech inspectors are mainly there to make sure your car is safe and getting protested for rules violations usually falls more into the responsibility of your fellow competitors.  The top five cars at every race are sent to impound and everyone at the track can have a very close look at your car.  Protests are rarely filed these days.  However, we want to keep the car as legal as possible as we feel it already has a pretty good advantage over a lot of the cars that currently race.
Brian a.k.a. Scribe
ScribeWorks Motorsport
Facebook Page
ChampCar Forum Build Thread
Starquestclub Build Thread
#22 Scribe
Scribe
  • 38 posts
Posted 05 July 2017 - 12:45 PM
As mentioned in a previous post, we were planning to acid dip the chassis after installing the roll cage.  We decided to do the acid dip before welding the cage in.  We went this direction mainly because we wanted to be able to safely weld on the chassis, and we were having trouble getting out seam sealer in hard-to-reach places.  The acid dipping process removes the galvanizing from the metal, so you no longer have to worry about zinc oxide exposure when welding to it.  We fully stripped the car down to the bare chassis and weighed it so we could do a before and after weight comparison.  After that, it was off to International Paint Stripping.
The acid dipping process does not involve the removal of any metal.  What does come off is all of the paint, seam sealer, undercoating, dirt, glue, etc.  All that is left when you are done is bare sheet metal.  Fortunately, there is a place that does acid dipping about 15 minutes from my house!  I dropped it off on the 22nd and it was finished by the 28th.  We are pretty impressed by the result.  The chassis lost 24 lbs after acid dipping.  Some weight will be added back when we re-paint the car and weld up the seams, but that is still a significant amount of weight to lose.  We also got the hood, fenders, doors, side-skirts, and front panel acid dipped.
While the car was at International Paint Stripping, it gave me the opportunity to make some garage updates including adding an air conditioner and finally running a 220V line for the welder.  We are now all set for the roll cage, which should start coming together this weekend.
Edited by Scribe, 05 July 2017 - 12:48 PM.
Brian a.k.a. Scribe
Facebook Page
#23 randy
randy
  • 4,116 posts
Posted 05 July 2017 - 05:01 PM
Man I really like this project process that acid dipping look's great.
#24 TexasQuest
  • 9,118 posts
Posted 05 July 2017 - 08:17 PM
Wow that is awesome! Seems like a better alternative to sand blasting.
88 Fiji Blue -TSi
#25 importwarrior
  • 18,359 posts
Posted 06 July 2017 - 07:06 AM
Amazing!
#26 scott87star
scott87star
  • 5,079 posts
Posted 06 July 2017 - 08:00 AM
We'd all like to start with something so clean!
#27 creakyjoints
creakyjoints
  • 1,944 posts
Posted 07 July 2017 - 04:02 AM
How much?
#28 Scribe
Scribe
  • 38 posts
Posted 07 July 2017 - 06:16 AM
View Postcreakyjoints, on 07 July 2017 - 04:02 AM, said:
How much?
I got quotes between $1000 and $3800 for just the chassis from four different places.  The cheapest one happened to be 15 minutes from my house.
Brian a.k.a. Scribe
Facebook Page
#29 EricSQ
EricSQ
  • 358 posts
Posted 11 July 2017 - 02:20 PM
Screw painting it now.  I'd smooth it down with sand paper and Brillo pads then clearcoat it.  At least the public would quit confusing it with a Supra and start confusing it with a DeLorean  :D
1988 Chrysler Conquest Tsi (sold)____1994 Mitsubishi 3000GT SL (sold)
1987 Mitsubishi Starion (sold)_______ 1986 Mitsubishi Starion LS Swap (sold)
2015 Subaru WRX (sold)___________ 2002 Chevy Silverado Z71 (For Sale)
1991 Toyota MR2 Turbo (project)____  2000 Chevy Silverado Shortwide (DD)
#30 Scribe
Scribe
  • 38 posts
Posted 11 September 2017 - 01:54 PM
Update 09/11/17
The last few months have been a blur with little to no work done on the Starion.  Lots of work, weddings, and races.  We finally made some progress on the car over the last week or so.  The Cage Gages I had sitting around for months finally got some use as we tackled bending the main roll hoop.  The first two bends where pretty much perfect as you can see below:
The next two did not go completely according to plan and the main hoop ended up a little wider than expected.  It still fits in the car, but it's tight:
We also continued our lightweighting work by gutting the doors, separating the hood from the outer skin, and removing the trunk floor for the fuel cell.  We are debating on either leaving the hood as just the skin or adding back some of the reinforcement.
We also took apart one of the steering boxes.  The plan is to open up the hydraulic passages and grease it in order to de-power the steering system.
This week we're hoping to finish removing any excess metal from the car and get some more tubes bent up before the end of the weekend.  We are also considering removing the roof skin in order to give us better access to welding the cage.  The alternative would be to drop the cage through the floor, but it may be difficult with the main hoop fitting so tightly.
Brian a.k.a. Scribe
Facebook Page
#31 speedyquest
speedyquest
  • 4,338 posts
Posted 11 September 2017 - 02:29 PM
Looking good dude! You want it tight in there so I wouldn't worry about that at all personally. Could you actually give the measurements of the main hoop? I'd love to know what you ended up using.
#32 Bradrock
Bradrock
  • 957 posts
Posted 11 September 2017 - 07:43 PM
Thanks for the update! There may be a small market here for pre bent & notched roll cage kits. Maybe?
I'd do the acid if it was available around here. I see advantages to living in a metroploitan area like the motor city.
When I was stock car racing, if another driver protested, they had to PAY the tech crew for the teardown.
Run's with scizzor's
#33 Scribe
Scribe
  • 38 posts
Posted 12 September 2017 - 10:06 AM
Here are the measurements I used for the main hoop:
The tubing used is 1.75x0.095" A513 DOM and I'm using a 5.5 in bend radius.  The main hoop ended up being about an inch too wide, but that was from measurement error.  If you build it to these measurements, it should fit pretty well.  I have about 1 inch extra on the legs that you would need to trim down built into the measurements.  I'd recommend having more excess length than that on the legs just in case.  The main hoop will also be mounted at a 10 degree angle towards the rear.
I'd say that would be a longshot as far as kits go.  However, I'd be happy to share all of the measurements with everyone once I'm done.
Edited by Scribe, 12 September 2017 - 12:41 PM.
Brian a.k.a. Scribe
Facebook Page
#34 speedyquest
speedyquest
  • 4,338 posts
Posted 12 September 2017 - 10:34 AM
Thanks for sharing your measurements, its greatly appreciated. It will give me a great starting point for when I make mine. If you want to share your measurements for the rest of it I've love to see those too.
#35 Fuze
Fuze
    AKA @Battlemagnet
  • 2,780 posts
  • Interests:Chess Boxing
Posted 29 September 2017 - 09:43 AM
Great project! Very impressive process. I fantasize about clear-coating that acid dipped steel and leaving it as-is but the vintage livery is a cool idea.
Early on I noticed you plan to retain the stock rear ABS. That system is probably not worth the weight or extra complexity as it was always a poorly functioning system many of us just remove altogether,  resulting in better rear braking power but just my .02. Good luck and have fun!
Insta = @battlemagnet
#36 mbruneaux
mbruneaux
  • 1,484 posts
Posted 29 September 2017 - 02:59 PM
Too cool!  more on this conversion to manual steering box?
Canterbury, CT
2001 BMW 740iL - My Daily
#37 Scribe
Scribe
  • 38 posts
Posted 10 November 2017 - 10:50 AM
I'm not sure if clear coat sticks to un-finished metal.  You're not the first to suggest that!
As far as the ABS goes, it can be a very useful to have in endurance racing.  Flat-spotting tires is an easy way to ruin them.  Also, making the car easier to drive can help improve average lap time.  However, we may still remove the rear ABS.  Isolating the G-sensor and ABS controller from the harness may be a bit of a pain as we may want to sell the harness as a complete unit.  It would also be nice to remove a potential failure point and save weight.  Another option we are looking into is retrofitting the 4-wheel ABS system from a BMW E46 M3.
Our plan is to open up the hydraulic passages in an attempt remove as much resistance as possible and then coat the gearbox internals with high-temp grease.
Brian a.k.a. Scribe
Facebook Page
#38 gst4g64
gst4g64
  • 407 posts
Posted 16 November 2017 - 09:50 PM
Clear coat seems to stuck pretty well to my Cult Bad Boy
#39 Scribe
Scribe
  • 38 posts
Posted 10 April 2018 - 08:37 AM
I'm pretty overdue for an update on here.  A lot has happened since my last post.  For starters, ChumpCar changed their name to ChampCar.  It was a change to reflect that they are trying to be more professional.  I also started a new job. This job is less demanding on hours, so I should have more time to work on this project now.
A big change for me is that I am now solo on this project, as far as ownership is concerned. I decided to take my teammate to a ChampCar race in December to see how he would do and if he would like it since he has never raced a car on track.  He found out that he gets sick from the exhaust from other cars and can only drive for about 45 minutes at a time.  He decided that this limitation made this project a lot less viable for him, so he backed out.  I am currently looking for someone to replace him as a part owner as I'm not sure I can support the project by myself.  However, I already have a lot of parts and all of the materials for the roll cage, so this should not hinder progress for now.
I also finally got myself a tow rig!  The trailer is not mine, but I am currently storing it on my property and I'm allowed to use it whenever I want.
As far as updates on the Starion, I performed structural analysis on the roll cage and made some changes to it based on the results. I'll post a summary of those results in another post.  I have also continued acquiring parts for it.  Other than that, there is not too much to report.
With racing season quickly approaching and the Starion being far from being finished, I decided to purchase a nearly ready-to-run race car to race while I finish the Starion.  I'm sure some of you will be familiar with this:
It is a 1980 Plymouth Fire Arrow that was built for the SCCA ITB class.  It has the 2.6 G54B with a Webber 32/36 carb.  In order to prep it for Champcar, I need to replace the glass with polycarbonate, add a fire suppression system, and install an approved fuel cell.  I also am changing out the seat as the current one is mounted too high up and does not fit me very well.  I may also do some upgrades in the coming months, which I will document here.  The plan is to take it to the track at the end of this month.
I am hoping to post a lot more frequent updates for both cars in the coming months, so stay tuned!
Edited by Scribe, 10 April 2018 - 08:43 AM.
Brian a.k.a. Scribe
Facebook Page
#40 mbruneaux
mbruneaux
  • 1,484 posts
Posted 10 April 2018 - 10:22 AM
Please keep the updates coming!  I'd really like more info on the manual steering once it is complete.  The car should be beautiful
Canterbury, CT
Also tagged with one or more of these keywords: Conquest, Starion, Chumpcar, Road Race, Endurance, Build Thread, Lemons, Scribe, Champcar, Fire Arrow
